adro 1114 Report post Posted February 10 237,800km New fuel cap that was in the parts stash installed. Think it's an amazon job but seems to fit fine. Copied @Vass and got one of these air scoops. Was logging a trip I had done previously to compare intake temps but got side tracked by one of the 02 sensors reading higher than the other? Is this normal? Also got a final stage resistor as my fan pulses sometimes when its cranked up, but man it's a pain to install. I aborted the first try as i couldnt locate the top screw and ran out of time. Will try again tonight. 1 Quote Share this post Link to post Share on other sites
adro 1114 Report post Posted February 11 Gave this final stage resistor another shot. Think I need a neck massage now. Got it done though. Old one dated 02 was quite different to the new one and it was a bit of a mission to get the new one in. So much so i was double checking part numbers to make sure this was the correct one. This is the top screw that is perpendicular to the steering column requiring (in my case) a cut down T20 driver Also replaced the rear glass switch and put the fuse back in. So far it's been behaving but I'm not holding my breath. 1 Quote Share this post Link to post Share on other sites
adro 1114 Report post Posted March 24 (edited) 239,000km glad to say no more pulsing for the HVAC. Over the hill this weekend getting filthy. I’ve taken out the exhaust flap switch as it wasn’t working and the car was a bit loud for my liking at the lower revs. Iv plugged the vac lines together and now the butterfly is closed shut. Have ordered a new switch but in the meantime it’s nice having it a bit quieter. I’m not sure when it failed but I felt it was louder than usual ages ago but didn’t realise there’s actually a solenoid that operates the exhaust flap, not just vacuum. Post gravel road wash I clay’d the entire car and applied a ceramic coating. A mate had sent me the last of a bottle of this hydro G9 to try out. Looking forward to seeing how this performs over winter. Got a new exhaust flap solenoid. Hooked it up and it’s working! Really happy with how it sounds now. Nice and quiet at low revs but sounds hearty after 3000rpm. in case anyone else is looking for it. It’s just below the tail light on the exhaust side. Edited April 9 by adro 7 Quote Share this post Link to post Share on other sites
adro 1114 Report post Posted April 14 (edited) 239600km Diff oil service. Edited April 14 by adro 1 Quote Share this post Link to post Share on other sites
adro 1114 Report post Posted April 25 240,200km Just returned from a school holiday trip down to Nelson. Ticked over 240k on the way and averaged around 10L/100km although it's not exactly a huge amount of km's from Wellington to Nelson but a nice open road drive with some hills and some twisties. Had terrible weather on the way down but lovely on the way home. 7 Quote Share this post Link to post Share on other sites
