Deek9000 5 Report post Posted August 19, 2024 Hi there, First time BMW owner and it’s a Japanese import so has plate brackets fitted accordingly. I’m keen to replace the standard plates with black slims or euros but am curious to hear from anyone who’s done the same and what you’d recommend. Prefer a clean look without the Japanese brackets. If I remove them, what are the options to fit new ones? It looks like there’s an indent at the rear for where the plate should go (without the bracket). Is this the Euro size? And for the front, there will be holes from where the bracket was fitted but could I get these patched up/filled and then attach any size plate (black slim, ideally) to the front? Or should I instead be looking for a replacement bracket that fits the pre drilled holes front and back and then source plate sizes to fit those? Apologies if this has been asked before, I couldn’t find a definitive guide on this topic. Thanks in advance Quote Share this post Link to post Share on other sites
Eagle 1787 Report post Posted August 19, 2024 3M VBH tape 1 Quote Share this post Link to post Share on other sites
balancerider 847 Report post Posted August 19, 2024 Good on you for getting rid of the Japanese plate frames! If you are going to run a full sized europlate on the front you can buy the plinth that comes on the euro market cars (see below image). If you're going to pick the mini plates then I wouldn't bother and just drill holes in the plate to match the existing ones in bumper front and rear (you may need to fill the lower pair of holes) Quote Share this post Link to post Share on other sites
KwS 2450 Report post Posted August 19, 2024 An alternative is to get a plate frame for your sized plate and attach that to the car (they usually have multiple screw hole options) and then fit the plate into it. A bit tidier than just sticking it to the bumper without the plinth. Quote Share this post Link to post Share on other sites
E30 325i Rag-Top 3043 Report post Posted August 19, 2024 As above Euro plinth or full plate frame to mount it properly to the bumper. Bolting or taping it straight to the plastic bumper just looks huckery imho. The front radar under the plate, which I see you’ve got from your photo, is also very temperamental with where the plate is positioned so worth doing properly. 1 Quote Share this post Link to post Share on other sites
Deek9000 5 Report post Posted August 19, 2024 11 hours ago, balancerider said: Good on you for getting rid of the Japanese plate frames! If you are going to run a full sized europlate on the front you can buy the plinth that comes on the euro market cars (see below image). If you're going to pick the mini plates then I wouldn't bother and just drill holes in the plate to match the existing ones in bumper front and rear (you may need to fill the lower pair of holes) Thank you. Do you know of any retailers that sell the plinths in NZ? All I can find are “plate surrounds” which add a frame around the plate. like this https://www.autographics.co.nz/product/european-number-plate-holder/ Quote Share this post Link to post Share on other sites
Deek9000 5 Report post Posted August 19, 2024 40 minutes ago, E30 325i Rag-Top said: As above Euro plinth or full plate frame to mount it properly to the bumper. Bolting or taping it straight to the plastic bumper just looks huckery imho. The front radar under the plate, which I see you’ve got from your photo, is also very temperamental with where the plate is positioned so worth doing properly. Thank you. Yes, was thinking of putting the plate over the top two holes and fill in the lower ones at the front. Should keep the plate well away from the radar. Do you know of any retailers that sell the plinths in NZ? All I can find are “plate surrounds” which add a frame around the plate. like this https://www.autographics.co.nz/product/european-number-plate-holder/ Quote Share this post Link to post Share on other sites
Olaf 3426 Report post Posted August 19, 2024 11 hours ago, Eagle said: 3M VBH tape This - 100% Quote Share this post Link to post Share on other sites
Vass 1083 Report post Posted August 19, 2024 Just ordered black slim plates for mine. Planning to just trim the jap brackets to size and go with that. Luckily I don't have the issue of any screw holes remaining visible on the E46. Quote Share this post Link to post Share on other sites
Deek9000 5 Report post Posted August 19, 2024 9 minutes ago, Olaf said: This - 100% If it’s strong enough to hold the plates securely, isn’t it going to be a nightmare to remove when you (or future owner) decide to change the plates? genuinely curious, have you changed the plates since and how did you get the tape off? Quote Share this post Link to post Share on other sites
Deek9000 5 Report post Posted August 19, 2024 4 minutes ago, Vass said: Just ordered black slim plates for mine. Planning to just trim the jap brackets to size and go with that. Luckily I don't have the issue of any screw holes remaining visible on the E46. Hadn’t thought of that! I’d be keen to see the results after you’re done! Quote Share this post Link to post Share on other sites
Vass 1083 Report post Posted August 19, 2024 1 hour ago, Deek9000 said: Hadn’t thought of that! I’d be keen to see the results after you’re done! Yeah I'll post it up once done. I've already trimmed the front one once as the Japanese plinth was protruding beyond the standard plate as well. Moved the plate up to line up with a protruding edge, added a couple of rivet nuts to hold in the new position and trimmed off the plastic protruding beyond the bottom edge of the plate. Before After The rear bracket will be a bit trickier as the bracket doesn't seem to have enough thickness to add in new rivnuts where I would want them but will figure something out. Double sided tape option doesn't really appeal to me. Quote Share this post Link to post Share on other sites
charles28 142 Report post Posted August 19, 2024 I went with double sided 3m tape. 2 Quote Share this post Link to post Share on other sites
KwS 2450 Report post Posted August 20, 2024 May i present a counter argument though? Plate frames 😄 1 Quote Share this post Link to post Share on other sites
Eagle 1787 Report post Posted August 20, 2024 10 hours ago, Deek9000 said: If it’s strong enough to hold the plates securely, isn’t it going to be a nightmare to remove when you (or future owner) decide to change the plates? genuinely curious, have you changed the plates since and how did you get the tape off? Its the same process as removing car emblems, you use dental floss to cut it behind the tape and solvent, caramel wheel etc to remove the reminder. Changing plates isnt very common once everything is tidy looking. Quote Share this post Link to post Share on other sites
balancerider 847 Report post Posted August 20, 2024 12 hours ago, Deek9000 said: Thank you. Do you know of any retailers that sell the plinths in NZ? All I can find are “plate surrounds” which add a frame around the plate. like this https://www.autographics.co.nz/product/european-number-plate-holder/ RealOEM is a great asset for BMW part numbers. https://spareto.com/oe/51138054576 Quote Share this post Link to post Share on other sites
Deek9000 5 Report post Posted August 20, 2024 11 hours ago, Vass said: Yeah I'll post it up once done. I've already trimmed the front one once as the Japanese plinth was protruding beyond the standard plate as well. Moved the plate up to line up with a protruding edge, added a couple of rivet nuts to hold in the new position and trimmed off the plastic protruding beyond the bottom edge of the plate. Before After The rear bracket will be a bit trickier as the bracket doesn't seem to have enough thickness to add in new rivnuts where I would want them but will figure something out. Double sided tape option doesn't really appeal to me. Very tidy. Looks like the bracket in your case forms part of the bumper panel, looks great after the trim! Is the rear same as mine with two bolts in the bracket? Quote Share this post Link to post Share on other sites
Deek9000 5 Report post Posted August 20, 2024 11 hours ago, charles28 said: I went with double sided 3m tape. Same on the back, and do you have a pic? Quote Share this post Link to post Share on other sites
Deek9000 5 Report post Posted August 20, 2024 9 hours ago, KwS said: May i present a counter argument though? Plate frames 😄 Looks good! Did you use existing drill holes to attach the frame? And did you go for euros front and back? Quote Share this post Link to post Share on other sites
Deek9000 5 Report post Posted August 20, 2024 3 hours ago, Eagle said: It’s the same process as removing car emblems, you use dental floss to cut it behind the tape and solvent, caramel wheel etc to remove the reminder. Changing plates isnt very common once everything is tidy looking. Makes sense. I’ll trust bolts over tape, but can see why tape’s a good route for some. 1 Quote Share this post Link to post Share on other sites
Deek9000 5 Report post Posted August 20, 2024 1 hour ago, balancerider said: RealOEM is a great asset for BMW part numbers. https://spareto.com/oe/51138054576 That’s really helpful, cheers! The mount is for front only or front and back? Quote Share this post Link to post Share on other sites
m325i 732 Report post Posted August 20, 2024 On 8/20/2024 at 7:50 AM, E30 325i Rag-Top said: As above Euro plinth or full plate frame to mount it properly to the bumper. Bolting or taping it straight to the plastic bumper just looks huckery imho. Depends on the model of car, but generally disagree. (E46 M3 has a nice plinth I admit). While I have used tape in the past with success, I found the curved front of F80 doesn't stick the corners well, (I tried like 3 types of tape). I found good success with these. Quote Share this post Link to post Share on other sites
balancerider 847 Report post Posted August 20, 2024 12 hours ago, Deek9000 said: That’s really helpful, cheers! The mount is for front only or front and back? Plinth only needed for the front - the rear plate recess is nice and flat. I personally think the black small plates are a bit 'scene' (although YMMV and apparently they are hard for the fixed speed cameras to see!) and they don't have plate surrounds available due to the small size. Europlates + plate surround is the cleanest option for me. 1 1 Quote Share this post Link to post Share on other sites
Vass 1083 Report post Posted August 21, 2024 16 hours ago, Deek9000 said: Very tidy. Looks like the bracket in your case forms part of the bumper panel, looks great after the trim! Is the rear same as mine with two bolts in the bracket? Yeah the rear is exactly the same as yours. So far I've trimmed off the bit that was protruding beyond the top edge of the plate. Once the slim plate arrives I'll trim off whatever is protruding beyond the bottom, or try to move it up somehow. Unfortunately it seems to only have a thickening where the existing rivnuts are and the rest of the plinth is a very thin slab of plastic so probably not possible to add extra rivnuts where I would want them. Quote Share this post Link to post Share on other sites
Eagle 1787 Report post Posted August 21, 2024 20 hours ago, Deek9000 said: Makes sense. I’ll trust bolts over tape, but can see why tape’s a good route for some. As long as tidy its a mostly the same tidy result. Tape just easy and i use it for a lot of other things. My Jap E36 Ti had the rear plate bracket rivetted into the boot from the inside so tape was the natural choice after cutting it out and filling the holes. 1 Quote Share this post Link to post Share on other sites
