sonic_attack 89 Report post Posted July 16, 2014 Yeah I got the cover off thats all cool. Just have to work out what I'm bypassing and to what. Quote Share this post Link to post Share on other sites
Etwenty1 45 Report post Posted July 16, 2014 Did the flange beak off the pump or part of the valve? Quote Share this post Link to post Share on other sites
sonic_attack 89 Report post Posted July 16, 2014 I'd call it the flange. There's around 3mm left on the pump itself to clamp onto. :-/ Quote Share this post Link to post Share on other sites
Etwenty1 45 Report post Posted July 16, 2014 Mine broke off same place, can't remember how I bypassed it but it wasn't hard just trace the hoses Quote Share this post Link to post Share on other sites
sonic_attack 89 Report post Posted July 16, 2014 As far as I can tell I'm broke on #22. Pic looks a little odd though, doesn't have the short hose that connects #22 to #21 at the pump? Quote Share this post Link to post Share on other sites
sonic_attack 89 Report post Posted July 16, 2014 Alright. I'm armed with a screwdriver and a 5/8 deep socket. Ready to do corrective surgery on an octopus, in the dark.. Quote Share this post Link to post Share on other sites
sonic_attack 89 Report post Posted July 16, 2014 Well that was painless. Quick 'n dirty wheelnut blockoff treatment. A few laps of the hood (Grafton/Newmarket) shows no coolant loss, or heater for that matter... pffft. Quote Share this post Link to post Share on other sites
yng_750 247 Report post Posted July 16, 2014 Hope thats a lock stud. Dont want it getting pinched Quote Share this post Link to post Share on other sites
sonic_attack 89 Report post Posted July 16, 2014 lol. It IS a locker! I just hope it doesn't fall out. I just replaced all that coolant less than a month ago! Quote Share this post Link to post Share on other sites
m325i 732 Report post Posted July 23, 2014 If I wanted to get my rear wheel repaired, does any one know what 'easy to find' wheel would fit so I can drive around for a day or 2? To re-phrase; what wheel spec can fit the rear of an e46 m3? Cheers N Quote Share this post Link to post Share on other sites
handgrenade 189 Report post Posted July 24, 2014 hi guys, installed an intake couple days back and its running fine .. however when I was pulling out the factory airbox, the airbox had some random hose plugged into the bottom of the box. was a dry hose, diameter 15-20mm. I am assuming it is the crank case ventilation hose ..? is it okay to leave it open, or is it time to mount a catch can somewhere? Quote Share this post Link to post Share on other sites
euroriffic 630 Report post Posted July 24, 2014 That's for the emissions recirculating pump down by the ac compressor. I'm sure it'll be fine just hanging out. I'm guessing I pumps unburnt gases back into the intake Quote Share this post Link to post Share on other sites
yng_750 247 Report post Posted July 24, 2014 If its right at the bottom of the filter box it may be a drain incase of water ingestion. Quote Share this post Link to post Share on other sites
louistan3 1 Report post Posted July 24, 2014 Would a broken viscous fan cause a loss of power on a 320i e30? It seems like ive got no torque at all even at low gears. Sent from my SM-N9005 using Tapatalk Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2153 Report post Posted July 24, 2014 Would a broken viscous fan cause a loss of power on a 320i e30? It seems like ive got no torque at all even at low gears. Sent from my SM-N9005 using Tapatalk Nope definately not. if its a 320i auto is probably acting completely normal lol Quote Share this post Link to post Share on other sites
euroriffic 630 Report post Posted July 24, 2014 Bahahaha so true andy!! Quote Share this post Link to post Share on other sites
louistan3 1 Report post Posted July 24, 2014 Haha but this is worse than the normal and its manual. Like I can barely get up a hill even on 2nd. Sent from my SM-N9005 using Tapatalk Quote Share this post Link to post Share on other sites
euroriffic 630 Report post Posted July 24, 2014 I'd try checking spark plugs and the dizzy cap for crud Quote Share this post Link to post Share on other sites
KwS 2450 Report post Posted July 24, 2014 (edited) hi guys, installed an intake couple days back and its running fine .. however when I was pulling out the factory airbox, the airbox had some random hose plugged into the bottom of the box. was a dry hose, diameter 15-20mm. I am assuming it is the crank case ventilation hose ..? is it okay to leave it open, or is it time to mount a catch can somewhere? it is indeed for the air pump. Technically should be filtered air, but as it pumps air from that pipe into the exhaust it shouldnt matter much (might shorten the life of the pump though). Its pipe 10 (diagram is from my own pre-evo, but should be similar) http://realoem.com/bmw/showparts.do?model=BF92&mospid=47432&btnr=11_1335&hg=11&fg=50 Edited July 24, 2014 by KwS Quote Share this post Link to post Share on other sites
handgrenade 189 Report post Posted July 24, 2014 it is indeed for the air pump. Technically should be filtered air, but as it pumps air from that pipe into the exhaust it shouldnt matter much (might shorten the life of the pump though). Its pipe 10 (diagram is from my own pre-evo, but should be similar) http://realoem.com/bmw/showparts.do?model=BF92&mospid=47432&btnr=11_1335&hg=11&fg=50 I can hack up an old filter and fit it?? If that would help? Quote Share this post Link to post Share on other sites
KwS 2450 Report post Posted July 24, 2014 id either get one of those wee breather filters, or maybe some fine mesh and stick it over the opening. The pump only runs for a period of time on a cold start, otherwise it should be off. Quote Share this post Link to post Share on other sites
Gaz 1077 Report post Posted July 24, 2014 If I wanted to get my rear wheel repaired, does any one know what 'easy to find' wheel would fit so I can drive around for a day or 2? To re-phrase; what wheel spec can fit the rear of an e46 m3? Cheers N Pretty much anything 5 series. I believe the rear of an e46 m3 is 18x9 et26 Quote Share this post Link to post Share on other sites
louistan3 1 Report post Posted August 4, 2014 Anyone have a photo of a dizzy cap for an e30 m20b20 with the numbering per port so I can check if I have mine right? Dizzy is the one kn the side not the front. Circular one. Sent from my SM-N9005 using Tapatalk Quote Share this post Link to post Share on other sites
KwS 2450 Report post Posted August 4, 2014 (edited) Some caps have the numbers moulded into them. Maybe hit it with brake cleaner and see if this one does? Otherwise this might help (i didnt add the arrow, so ignore it unless relevant), Edited August 4, 2014 by KwS Quote Share this post Link to post Share on other sites
louistan3 1 Report post Posted August 5, 2014 Thanks KwS! Out of curiosity.. where did you get this? Sent from my SM-N9005 using Tapatalk Quote Share this post Link to post Share on other sites
