Jacko 2341 Report post Posted March 12, 2018 (edited) Cant decide on changing all the gearbox seals (input/output/selector) when ive got the box out of the 130, or just leaving them. Cars at 230k, no leaks... If it aint broke, dont fix it Vs. Im balls deep already, whats a lil deeper. Thoughts? Edited March 12, 2018 by Jacko Quote Share this post Link to post Share on other sites
allan 295 Report post Posted March 12, 2018 Ok lets say the box did have an oil leak and it was the in put shaft. what would it cost to 1 take the box out, replace the input shaft and any other seals concerned,guessing its a manual. Where you are more than half way their now with the box out etc. A dare sight easier to replace them now as it is only the cost of the seals and labour if you aren't fitting them yourself. Also bet you will be pissed off if not long after you discover an oil puddle on your garage floor which turns out to be trans fluid. 1 Quote Share this post Link to post Share on other sites
M3AN 4183 Report post Posted March 12, 2018 (edited) Allan's right @Jacko, for the sake of a few bucks do the seals whilst it's out. Edited March 12, 2018 by M3AN 1 Quote Share this post Link to post Share on other sites
Jacko 2341 Report post Posted March 13, 2018 Looking through the workshop manual replacing the rear crank seal is an involved process! I cant find the loctite product anywhere Injector (2) contains the sealing compound Loctite, manufacturer's number 128357. Bottle (3) contains the primer Loctite, manufacturer's number 171000. Any ideas on an equivalent? Quote Share this post Link to post Share on other sites
M3AN 4183 Report post Posted March 13, 2018 2 hours ago, Jacko said: Any ideas on an equivalent? None sorry. Give them a call in Aus and ask, maybe they'll know? http://www.loctite.com.au/2956_AUS_HTML.htm Quote Share this post Link to post Share on other sites
eliongater 718 Report post Posted March 18, 2018 Can anyone tell me if an e46 rear hub/bearing is supposed to have a dust cover? I seem to have gotten it in my head that it should, but can’t find a PN on real OEM and the dust cover I have (front I assume) won’t fit. Quote Share this post Link to post Share on other sites
qube 3570 Report post Posted March 18, 2018 only the fronts have the covers and the rears dont. See my photos below: 1 Quote Share this post Link to post Share on other sites
eliongater 718 Report post Posted March 18, 2018 1 hour ago, qube said: only the fronts have the covers and the rears dont. See my photos below: Thanks, I better get my rc caps fixed if I don’t want exposed nuts Quote Share this post Link to post Share on other sites
gjm 3300 Report post Posted March 19, 2018 Less of a question, more a request for confirmation: Do all E46 coupes come with split-folding rear seats? TIA. Quote Share this post Link to post Share on other sites
qube 3570 Report post Posted March 19, 2018 All e46 coupes come with 40/60 folding seats. cold weather package option also includes ski bag thru the centre armrest thing 1 Quote Share this post Link to post Share on other sites
gjm 3300 Report post Posted March 19, 2018 42 minutes ago, qube said: All e46 coupes come with 40/60 folding seats. cold weather package option also includes ski bag thru the centre armrest thing Ta. Quote Share this post Link to post Share on other sites
gjm 3300 Report post Posted March 23, 2018 What's the considered opinion on 'getting away with something..'? I'm talking about the third brake light on a 1990 E30. An identical car from 1989 doesn't need one, but a 1990 does. Am I fooling myself if I think we might 'get away' with not fitting the 3rd brake light to the (new) bootlid for the Baur? Quote Share this post Link to post Share on other sites
M3AN 4183 Report post Posted March 24, 2018 2 hours ago, gjm said: What's the considered opinion on 'getting away with something..'? I'm talking about the third brake light on a 1990 E30. An identical car from 1989 doesn't need one, but a 1990 does. Am I fooling myself if I think we might 'get away' with not fitting the 3rd brake light to the (new) bootlid for the Baur? Well, if you get a WoF then you've "got away" with it for at least 6 months. Can't hurt to try. It's not like you're going to get pulled over by a cop or anything. 1 Quote Share this post Link to post Share on other sites
Jacko 2341 Report post Posted March 27, 2018 (edited) Anyone come across a "sticky shift" in an e9x? The 330 occasionally wants to get stuck in 2nd/3rd when slowly accelerating, and wont kick down, itll bog the engine to the point of nearly stalling. Its intermittent, and being more forceful with the go pedal solves it, just annoying when creeping in traffic. No fault codes are logged. Edited March 27, 2018 by Jacko Quote Share this post Link to post Share on other sites
Palazzo 533 Report post Posted March 27, 2018 Does anyone know the correct oil filter internal diameter for an M52B28? I got two suggested, one is a 27 (or 28mm) and the other 40 (or 43, can't remember now). '96 E36. Quote Share this post Link to post Share on other sites
nick496 273 Report post Posted March 27, 2018 52 minutes ago, Palazzo said: Does anyone know the correct oil filter internal diameter for an M52B28? I got two suggested, one is a 27 (or 28mm) and the other 40 (or 43, can't remember now). '96 E36. It will depend on if you have a plastic cap or metal cap on your oil filter housing. I'm not 100%, but I think the plastic housing is the larger internal diameter. Quote Share this post Link to post Share on other sites
gjm 3300 Report post Posted April 17, 2018 On 3/24/2018 at 1:32 PM, M3AN said: Well, if you get a WoF then you've "got away" with it for at least 6 months. Can't hurt to try. It's not like you're going to get pulled over by a cop or anything. Got the WoF... 2 Quote Share this post Link to post Share on other sites
gjm 3300 Report post Posted May 12, 2018 1990 E30 318i - rear disc or drum brakes? (Or could they have either...?) Car is about 120km away so I can't pop out and have a look, and RealOEM doesn't suggest one way or the other. Quote Share this post Link to post Share on other sites
nick496 273 Report post Posted May 12, 2018 6 hours ago, gjm said: 1990 E30 318i - rear disc or drum brakes? (Or could they have either...?) Car is about 120km away so I can't pop out and have a look, and RealOEM doesn't suggest one way or the other. I believe either is possible. My old 318i was a 1990 and had rear disk brakes though. Surely it's not a hard question to ask? Quote Share this post Link to post Share on other sites
gjm 3300 Report post Posted May 12, 2018 10 hours ago, nick496 said: Surely it's not a hard question to ask? <chuckes> You might be surprised! 1 Quote Share this post Link to post Share on other sites
Kepes 231 Report post Posted May 31, 2018 E30 - I've got a new sunroof seal. Being a pre-facelift it comes from the factory with a 2 piece seal. I'm replacing it with the 1 piece seal from the facelift. Where should the 2 ends of the seal meet? Is there a spot that's better than others? Or if anyone with a facelift could please tell me where they join from the factory, I would really appreciate it. Thanks :~) Quote Share this post Link to post Share on other sites
nick496 273 Report post Posted May 31, 2018 16 minutes ago, Kepes said: E30 - I've got a new sunroof seal. Being a pre-facelift it comes from the factory with a 2 piece seal. I'm replacing it with the 1 piece seal from the facelift. Where should the 2 ends of the seal meet? Is there a spot that's better than others? Or if anyone with a facelift could please tell me where they join from the factory, I would really appreciate it. Thanks :~) I'm not sure if it's the correct spot, but I had mine meet in the middle at the rear. 1 Quote Share this post Link to post Share on other sites
gjm 3300 Report post Posted May 31, 2018 1 hour ago, Kepes said: E30 - I've got a new sunroof seal. Being a pre-facelift it comes from the factory with a 2 piece seal. I'm replacing it with the 1 piece seal from the facelift. Where should the 2 ends of the seal meet? Is there a spot that's better than others? Or if anyone with a facelift could please tell me where they join from the factory, I would really appreciate it. 1 hour ago, nick496 said: I'm not sure if it's the correct spot, but I had mine meet in the middle at the rear. I think the two-piece seal is joined on the sides, a couple of inches back from the front edge. Perhaps have the single strip join in the same location? A seal at the back could be susceptible to having water pushed towards the back of the opening panel, and possibly collecting where the seal join is. Maybe. 1 Quote Share this post Link to post Share on other sites
Kepes 231 Report post Posted May 31, 2018 (edited) 16 minutes ago, gjm said: I think the two-piece seal is joined on the sides, a couple of inches back from the front edge. Perhaps have the single strip join in the same location? A seal at the back could be susceptible to having water pushed towards the back of the opening panel, and possibly collecting where the seal join is. Maybe. Yup, you're right about where the two-piece comes together. Good logic regarding the one-piece (I thought to join it there too) however I think the back, in the middle, is the correct spot. A guy on E30 facebook group said that's where his comes together too. 1 hour ago, nick496 said: I'm not sure if it's the correct spot, but I had mine meet in the middle at the rear. Cheers Nick! Edited May 31, 2018 by Kepes Quote Share this post Link to post Share on other sites
eliongater 718 Report post Posted June 8, 2018 Can anyone identify this engine? It's either an m30 or m90. 4148346 35 6e a 356ea Quote Share this post Link to post Share on other sites
