Guest Andrew
The Bimmersport Dyno Thread
Customers N55 335 stage 1 in Sydney. Have been working on a stage 2 N54 but car has some ignition issues
Stage 1 E92 M3
Would a 3rd gear run give a reliable reading ? My e46 m3 which is standard as far as I know read 230 kw at the hubs on a dynapack hub dyno . Seems 30 - 40 kw too high based on other and too close to the v8 m3
Couldn't run in higher gears due to the smg wanting to change down at the run start.
2.8L M20, 14.5:1 compression with custom JE pistons, extensively modified head, custom grind cam, triple webers, E85....this is wheel kw, not corrected to flywheel-
Wow wtf thats crazy.
F'ing insane
1996 323i 320000kms blue with m52 intake, red with m50 intake
2 inch exhaust, no cat, otherwise standard
Thats a surprising result, I was of the understanding that the M50 intake made a large difference to the M52. Similar top end figures but much later in the curve.
Would an ecu remap make better use of the different inlet tracts?
Most definitely, considering the ecu is currently mapped for the intake velocities and air quantities that the smaller intake tracts provide a remap would provide the biggest improvement but as far as I am aware the obd2 ecu cant be remapped like the m50 ecu can.
Stock E46 M3 , 307hp at the hubs with 2nd gear ratio corrected to 9.2
My e30 at the moment running 12psi at a 65% tune is putting out 270hp at the wheels and has done a 13.42 at night speed on all 4 chromes. was doing 174.something km/h at the speed trap.
still in need of retune at higher boost etc but not bad for now.
Mine is now making 268.7kW, around 360hp at the wheels, 98 octane @ 18psi. Car is tuned to give it a hard time and safely handle it so has more in it if i wanted to push it (but i dont).
Weighed car and full tank and babys car seat was 1200kg on the dot.
Will find out ET when the track is finished at meremere and race at winter wars.
161.5kw atw
Hi Velocity
Standard M62tuB44
E39 540i touring
That .5 makes all the difference!
and starting rear of grid in Improved production race at Phillip Island-
dyno runs should be done in 4th or 1/1 gearing and TCF 1.00 and temp sensor hung on the wall in the dyno room
So who's the best to do m3 dyno/basic tune? And can someone give me an indication of how much?
M3 went on the Dyno today.
179.2KW ATW. K&N Panel, no cats, rebuilt vanos otherwise stock.
Should mention that was on 98 RON with a slipping clutch and boost overshoot/throttle closure through the midrange, hence the Himalaya-like torque curve . Have since replaced the clutch with a Spec 2+ and have the boost overshoot sorted out.
Nice work! Good to see you PTF Tune is giving you good numbers.
2011 f10 550i stock-  217 rwkw. Anyone else dyno'd one of these? the car was having trouble on the dyno and kept going into limp mode
2 hours ago, Ninjaspartan said:
335i Full bolt on.
 84072569_523538721620272_8586109236428144640_n.thumb.jpg.5b714fbb1c480234fc2eb8c0dbec160e.jpg
More details on the on the tune and Mods please.
Hey Sure,
-Ebay Catless downpie 3"  *Added Bellows to exhaust for less stress on the joins
-7" Front mount intercooler
-VRSF Silicone Inlets
-VRSF Aluminum oulets *Custom rear turbo outlet to fit around steeringshaft.
-Aluminium Charge Pipe with HKS BOV.
-MHD stage 2+ tune v8.1
Built Engine With
-FCP Con Rods
-JE 9.5:1 Pistons
-King Bearings
Edited by Ninjaspartan
F10 M5.
Downpipes and a tune. Everything else stock.
Now I giggle and sh*t myself at the same time. ?
Edited by lidistick
  • Like 3
Wow that is impressive, I feel so sorry for the rear tires.
  • Haha 1
I'm amazed someone buys one of those and thinks "you know what this car needs? more torque!".
Absolute madman :)
Guess you can impress/frighten people by initiating burnouts at motorway speeds haha.
  • Haha 1
