huff3r
E30 320i Racecar
Just bought a BMW 320i off trademe to turn in to a racecar at tech. I'm doing the motorsport course at WINTEC, so i figured it would be a good project and a great way to get into racing. So far all i've doneis replace the thermostat while i wait for space in the panel shop at tech.
Dyno tested with the faulty thermostat at a measly 73kw at the wheels, but hopefully putting in a pod filter soon. Pics to come later
Flux said:
Mike McDonalds brother?
Nope....
Got some pics of my car today...
A little bit of rust to deal with but no biggie..
Edited by huff3r
73kW is pretty bloody good for an old stock 320
That was with a stuffed thermostat... it was running really rich, around 0.7 Llambda... So it should have maybe 5 more kws now... :D
It was real well looked after too... cambelts every 40,00kms, services every 2000kms...
Thats awesome! Even better that you can do it as part of your course.
Keep us updated!
Sweet would be awesome to build something like that at tech.
BTW. A pod filter is not always an upgrade. A few BMW forums have proven the stock box with a panel filter to be the best. Have a play around.
Got the sunroof out at tech today... the mounting bracket was pretty rusty, so i guess thats where my water leak is....
Common problem!
Time for an update...
Removed windscreen... now needs a new one thanks to some improper removal techniques
Fixed rust in right rear door, just needs painting. In the process of fixing all other rust.
Finally got the sunroof bracket out.... found a huge amount of rust under a huge amount of silicone sealant....
Hopefully the car will be done soon so i can get racing this year!
More updates....
Fabricated cold airbox... still working on air ducts...
Holes drilled in the floor ready to begin constructing rollcage
All rust fixed, patched, bogged, rust proofed and painted
Left rear door back together
did you just fabricate a custom air box or use a template from somewhere?
keen for pics on that!
Just fabricated one... its only 1mm mild steel so i dont know if it'll do anything, and its waaay more complicated than it should be... just clears the alternator belt too.
I think it's actually a little too short, as it isn't indenting the heatshielding under the bonnet, so maybe too much clearance?
I'll post some pics up soon... mayb tuesday
nice
Edited by tastic
hey nice going with your e30..by any chance when can you get pics up for your cold air box ? wanted to see how you done it
Got some pics of the airbox now... and got the front laterals of the cage almost done... so stoked im finally gettn somewhere :D
Cold Air Box with Pod Filter
I think its a little low... so working on a solution
Cold Air Box without filter....
A little more complicated than it needs to be
New Project : Lid for Cold Air Box
Hopefully this will help it to stay "Cold".... wouldnt be a good CAI without the "cold" bit :D
Would anyone be able to tell me whether anything i do to the car to make it up to e30 class spec would require a cert? or is it all covered through the authority card? ie. my roll cage, seats, harnesses, springs + shocks and wheels...
some people have been certed, I think most people aren't. Mine doesnt and I've got all you've mentioned above. I'm unsure what would require a cert exactly.
Yeah... most people i know reckon i dont need one... but im not sure where they r gettn their info from, and i need the car road legal soon so if i needed a cert for something i would need that done first so... mayb i shud talk to vtnz....
No cert required for the mods we do for the race series, Authority card covers the cage, belts and braided brake lines. You should have no trouble getting wof.
Sweet, now i just have to wait a week til tech re-opens so i can finish my cage... and get some seats :D.... i was a little worried cos its a bit hard to move a car thats not road legal to wellington without a trailer
I guess it must be about time for an update... i've done just a little work..
- Cage is practically done (waiting on homologation)
- Picked up seats last week
- Picked up suspension this week
Cage front view
Door View
Test fitting seats
The seats fit pretty well, so i'm stoked... just need to drill some holes to mount the back of the rails
cool - good to see progress.
Boy I'd hate to climb in with side intrusion bars meeting that high and on such an angle. I love my inverted style.
Edited by bmw3
Boy I'd hate to climb in with side intrusion bars meeting that high and on such an angle. I love my invented style.
Yep, its practically impossible with the old steering wheel... but safety first :D lol
