BM WORLD 1295 Report post Posted February 7, 2012 (edited) quick update its done!!!! taken a while to sort it out . but finally i can drive the car propely went to gavin's (hi-velocity) today. gavin did his magic , remapped the ecu with the new millar maf unit fitted. have had to do a bit of a overhaul on the fuel system 2 new fuel pumps, new filter , proper fuel reg fitted , got rid of the fuel dampers in the fuel lines near the engine. had all the injectors cleaned , descaled etc so all 100%. fitted a metal mesh just before the MAF unit to straighten out the air. goes really well now , sounds pretty neat. power goes flat at the top but we think maybe the exhaust is strangling it a bit. maybe in the future i might look into sorting that out. make about the same power as my 4.4L v8 but not quite the torque. enjoy the video. Edited February 8, 2012 by Brent HARTGE535i 1 Quote Share this post Link to post Share on other sites
Michael. 2313 Report post Posted February 7, 2012 Good stuff Brent Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2153 Report post Posted February 7, 2012 (edited) sorry wheres the vid? sounds like a good result though which is always what you want! will have to get brendan to bring me over and meet you next time im up and check it out! edit: eyes now opened Edited February 8, 2012 by _Ethrty-Andy_ Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted April 21, 2012 couple of videos from the bmw club track day in taupo in may first time in a while for my car on the track with all the mods and tunning done etc was handy being able to rev to 7000rpm , also decent torque out of the corners preformed quite well. also marty was there with his turbo e28 , but my camera battery went flat so missed filming him from behind was spitting flames at me etc http://www.youtube.com/watch?v=A5_xH5xWvPw...;feature=relmfu another video from my freinds smart phone in HD and turn up the volume e30 m3 ,e30 325is ,2002 , turbo e28 , e28 m5 etc Quote Share this post Link to post Share on other sites
Michael. 2313 Report post Posted April 21, 2012 Awesome Brent, Love the sound of your fine machine! Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted August 8, 2014 (edited) a bit of a update to long project etc . just fitted some headers to the e28 , they are modified e34 M5 headers ,have been off and on a few times to get the correct shape etc to fit around the steering box etc.... not a lot of space in a e28 , subframe has to be lowered , engine lifted etc to get them in there and there are about 3-4 nuts that are really hard to get to , having to use small spanners etc , modified spanners. also a complete new exhaust system made. larger pipe than the previous sports system that was designed for a m30 engine not a M88 engine . sounds a bit different now looking forward to the next track day at puke in a week etc.. Edited August 8, 2014 by Brent HARTGE535i 2 Quote Share this post Link to post Share on other sites
charles28 142 Report post Posted August 8, 2014 Nicely done there man Quote Share this post Link to post Share on other sites
zero 1162 Report post Posted August 28, 2014 Will you do another dyno run? Be interesting to see and hear the difference..... Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted August 29, 2014 yes will be soonish Quote Share this post Link to post Share on other sites
Ahmedsinc 414 Report post Posted August 29, 2014 Mmmmm, plumbing!! How did the large case -> medium case swap go man? Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted August 29, 2014 yes easy swap , just bolts in on these e28's , same axles and driveshaft etc Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted October 7, 2014 took the car in for a dyno run today to see what its health is like after the new headers and exhaust system. has made good improvements through the rev range from abnout 3000rpm up etc running a bit lean though and there is some pinging , so back in for a remap so here's a before and after dyno run results car pulls really well , need to sort some bigger ,wider rubber in the rear now Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted October 7, 2014 http://youtu.be/AC-1o4k1g9I http://youtu.be/2A7Vl_zCg-Q http://youtu.be/vwNasFAerXs?t=3m Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted November 12, 2014 (edited) small update , had the car with gavin at hi velocity had the ecu remapped to suit the new headers and exhaust sorted out the dips in the midrange , fueling and timming sorted etc runs a bit smoother now , pulls strong from 3k rpm all the way to 7k rpm now doesn't flatten out like it used to at about 6000rpm etc peak torque around 4500rpm to 5500rpm peak kw around 204rwkw , but saw 211rwkw but that is maybe not refigured etc ?? pretty happy with the result std m30 535i engine make around 110-120rwkw std m88 engine around 150-160rwkw so not bad improvement over stock. making similer power to a well set up e36 or e46 3.2L M3 engine but at about 6000rpm not 7000rpm just need to sort some better rubber now :S Edited November 12, 2014 by Brent HARTGE535i 2 Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted November 12, 2014 not officially back , uses someone elses dyno for jobs like this Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted April 14, 2015 quick update , swapped out the 540i e34 302mm by 28mm front brakes for some e31 850ci calipers 324mm by 30mm discs and pads from a e38 740i stops nice anybody want some e34 540i front brakes for there e28 e24 e34 etc 1 Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted April 9, 2016 after 11.5 years , she is gone now to a new home. :( Quote Share this post Link to post Share on other sites
M M 250 Report post Posted April 9, 2016 I'll never forget my ride in that car. Made me hurry up with doing my swap. Quote Share this post Link to post Share on other sites
kiwi535 538 Report post Posted April 9, 2016 so whats next Brent? Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted April 9, 2016 so whats next Brent? not sure what do you suggest that can compete Quote Share this post Link to post Share on other sites
Ahmedsinc 414 Report post Posted April 9, 2016 Never thought I'd se the day where you let that one go mate Something with an S62 flavour would be the only real successor I can think of, maybe an M5 wagon? Quote Share this post Link to post Share on other sites
kiwi535 538 Report post Posted April 9, 2016 not sure what do you suggest that can compete been thinkin about that myself.I think you had a sweet setup there good compromise weight to power.Depends what you want i suppose,Everything has a compromise element. For myself i think a nice manual 635 would do the trick,perhaps with,as you have suggested before a slightly hot rodded M30 Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2153 Report post Posted April 9, 2016 http://www.trademe.co.nz/motors/used-cars/tvr/auction-959174752.htm 2 Quote Share this post Link to post Share on other sites
polley 916 Report post Posted April 9, 2016 http://www.trademe.co.nz/motors/used-cars/tvr/auction-959174752.htm Looks horrendous. Quote Share this post Link to post Share on other sites
Olaf 3426 Report post Posted April 9, 2016 "all TVRs should be registered as pre-production prototypes". Yes, something with a BMW V8 I reckon. 1 Quote Share this post Link to post Share on other sites
