pommy 33 Report post Posted March 7, 2013 I hope you guy's don't mind. I thought rather than start a new thread, I would tail onto this thread. As I would like to finish the thread with a good ending!! I have purchased the Cab of James, and have been quite busy with it in the last four weeks! and thought its about time for an update. - first on the list was a full groom - wof & reg - Manual Conversion @ HellBM (Thanks Ray car drives so much better now!) - New roof installed. attachment=42589:SAM_0155_Converted.JPG][quote name='pommy' date='Mar 7 2013, 08:36 PM' Quote Share this post Link to post Share on other sites
pommy 33 Report post Posted March 7, 2013 (edited) http://download.cnet.com/Image-Resizer-Pow...4-10905400.htmlGLHF with finishing it off, great potential quote] Cheers for that. yes has potential I will enjoy every minute.[/ Edited March 7, 2013 by pommy Quote Share this post Link to post Share on other sites
pommy 33 Report post Posted March 10, 2013 Epic Fail!!! will have to purchase new bumper now. Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2153 Report post Posted March 10, 2013 (edited) Epic Fail!!! will have to purchase new bumper now. that should be fixable? looks like it needed a repaint anyways. if your kit is like the real one, that part is seperate from the bumper Edited March 10, 2013 by _Ethrty-Andy_ Quote Share this post Link to post Share on other sites
Lucan 196 Report post Posted March 10, 2013 (edited) Looks like fiberglass, is fixable though Edited March 10, 2013 by Lucan Quote Share this post Link to post Share on other sites
pommy 33 Report post Posted March 14, 2013 Hope it can be fixed. Yes the bottom part is separate! Will take off and get some quotes. Quote Share this post Link to post Share on other sites
pommy 33 Report post Posted March 14, 2013 Anyone installed a convertible roof before & wants to give me a hand? Quote Share this post Link to post Share on other sites
pommy 33 Report post Posted May 10, 2013 well it's been a while since any updates so thought I had better post some! now winter is here I plan on really getting into this now: plans: New roof installed - new windows all round (have imported from Germany) - full brake upgrade - new front window seal strip as currently window is ready to pop out! - re upolster the seats - try and fix fuel gauge for some reason just cant find the fault! any suggestions? - respray in same colour - new stainless exhaust - full sound system upgrade. Quote Share this post Link to post Share on other sites
pommy 33 Report post Posted May 10, 2013 (edited) some more pics. installed front window strip (what a Ba$%ard to install) and have had Ray install new rear drive shaft as this was damaged for some reason! resprayed the bottom front end black over the oil cooler make it look a bit cleaner whilst the front bumber is off! thanks to Ray from HellBM for your help so far, there has been some regular visits lol! Edited May 10, 2013 by pommy Quote Share this post Link to post Share on other sites
mynbmr 225 Report post Posted May 10, 2013 :mellow:Sorry just saw this, who the hell fixed your bottom bumper? Txt me on 0272417328. We maybe able to safe it for you. Cheers Hans Quote Share this post Link to post Share on other sites
pommy 33 Report post Posted May 10, 2013 :mellow:Sorry just saw this, who the hell fixed your bottom bumper? Txt me on 0272417328. We maybe able to safe it for you. Cheers Hans Lol its my first go at Fibreglassing it does'nt look to bad now will post updated pic! lot's of sanding. Quote Share this post Link to post Share on other sites
Michael. 2313 Report post Posted May 10, 2013 I have the same ramps as you by the looks. I welded some 500mm steel plates 1/3 way up to smooth the accent and reduce that nasty angle to avoid any scraping of the front bumper. Quote Share this post Link to post Share on other sites
Lucan 196 Report post Posted May 10, 2013 Whats wrong with the fuel guage? If its showing incorrect level, take out the cluster and sand the terminals on the back of the fuel gauge once its removed. Or replace it. Quote Share this post Link to post Share on other sites
pommy 33 Report post Posted May 11, 2013 Whats wrong with the fuel guage? If its showing incorrect level, take out the cluster and sand the terminals on the back of the fuel gauge once its removed. Or replace it. It's not working atall! I have taken it out sanded the nut and terminals changed the float. Still not working! Quote Share this post Link to post Share on other sites
Cab 148 Report post Posted May 12, 2013 Could be a fuse? Swap your hazard light fuse with your fuel gauge one (if it is the problem), or buy a new fuse Quote Share this post Link to post Share on other sites
pommy 33 Report post Posted May 13, 2013 Thanks I have replaced all fuses! But will try the swap. Need to fix this cant keep guessing anymore. Quote Share this post Link to post Share on other sites
pommy 33 Report post Posted May 13, 2013 Also if anybody has any ideas as to why none of my electric windows are working? Have checked fuses. Cheers. Quote Share this post Link to post Share on other sites
BM WORLD 1298 Report post Posted May 13, 2013 Also if anybody has any ideas as to why none of my electric windows are working? Have checked fuses. Cheers. make sure window resetable fuse switch is plug in and pushed in Quote Share this post Link to post Share on other sites
pommy 33 Report post Posted May 13, 2013 Oh yes. Is that the switch top right corner next to gear knob? I think it is that however have had all the console out! And cannot find the two spade bit connectors that plug into the switch? Any other ideas cheers guys. Quote Share this post Link to post Share on other sites
tcbaurpower 5 Report post Posted May 13, 2013 Have you removed the drivers side dash panel under steering wheel. Was there a switch on the panel that you also removed? This is common in an e28 and when you unplug the switch all windows will stop working. Maybe a similar switch...? Quote Share this post Link to post Share on other sites
pommy 33 Report post Posted May 14, 2013 The panel was off when I purchased the car! I cant see any dangling wires, only the headlight adjuster. Quote Share this post Link to post Share on other sites
BM WORLD 1298 Report post Posted May 14, 2013 The panel was off when I purchased the car! I cant see any dangling wires, only the headlight adjuster. will be left of the steering wheel . or behind the radio heater panel . 2 very big heavy gauge wires . green i think Quote Share this post Link to post Share on other sites
pommy 33 Report post Posted May 17, 2013 Thanks Brent I will check. Quote Share this post Link to post Share on other sites
Cab 148 Report post Posted May 18, 2013 It could also be as simple as checking you havent accidentally pressed the window lock button if you're still keen I wouldnt mind coming to check this out next week some time Quote Share this post Link to post Share on other sites
pommy 33 Report post Posted May 18, 2013 Thanks. There is no wire(spade conections to be seen anywhere have had the carpet up!) so cant connect to the switch! Yeah sounds good, just give us a text first! What day was you thinking? Cheers. Quote Share this post Link to post Share on other sites
