zero 1162 Report post Posted August 29, 2016 17 minutes ago, M3AN said: I wouldn't recommend using an adjustable crescent spanner for anything. But yes, get a proper (cheap) 32mm spanner and rubber mallet. Fair comment. Its just what I had available at the time. Quote Share this post Link to post Share on other sites
huff3r 347 Report post Posted September 11, 2016 Adding to the list, spring compressors to go with my 100a gasless mig and engine crane. - Manawatu Quote Share this post Link to post Share on other sites
Vinu Chandrakumar 7 Report post Posted October 4, 2016 (edited) Hey, guys, I am after a front wheel bearing install tool for a E30 looks something like this: anyone know where i could hire one at all. Cheers, Vinu Edited October 4, 2016 by Vinu Chandrakumar Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted October 4, 2016 Normally just get the complete bearing hub for the E30 - about 10mins to replace. 1 Quote Share this post Link to post Share on other sites
Lucan 196 Report post Posted January 4, 2017 Anyone in Auckland have a load leveler I can borrow? Removing M20 shortly and then in with the M30. Quote Share this post Link to post Share on other sites
sweetm3 181 Report post Posted January 24, 2017 Hi guys Would like to borrow a Air/Fuel ratio meter/gauge for my E36 Happy to pay ? Cheers Quote Share this post Link to post Share on other sites
NakiTouring 54 Report post Posted May 17, 2017 People, does anyone have a N series rear crank seal removal / install tool kit I can rent? Happy to pay a suitable bond too. Thanks. Quote Share this post Link to post Share on other sites
qube 3570 Report post Posted May 27, 2017 Anyone have a ball joint/tie rod remover tool around auckland? Quote Share this post Link to post Share on other sites
aja540i 1925 Report post Posted May 27, 2017 19 minutes ago, qube said: Anyone have a ball joint/tie rod remover tool around auckland? Yes. PM me. Quote Share this post Link to post Share on other sites
qube 3570 Report post Posted June 20, 2017 looking for bushing tool to use on the rear suspension upgrade in the E39 if anyone has please let me know Quote Share this post Link to post Share on other sites
eliongater 718 Report post Posted June 23, 2017 Does anyone have a compression tester suitable for an m54 in Wellington I can borrow? Quote Share this post Link to post Share on other sites
qube 3570 Report post Posted July 5, 2017 On 6/20/2017 at 6:50 PM, qube said: looking for bushing tool to use on the rear suspension upgrade in the E39 if anyone has please let me know anyone in akl? Quote Share this post Link to post Share on other sites
zero 1162 Report post Posted July 5, 2017 6 minutes ago, qube said: anyone in akl? I have a homemade jobby which is just big washers and a long bolt. Quote Share this post Link to post Share on other sites
qube 3570 Report post Posted July 5, 2017 51 minutes ago, zero said: I have a homemade jobby which is just big washers and a long bolt. does it work okay? haha Quote Share this post Link to post Share on other sites
zero 1162 Report post Posted July 5, 2017 8 minutes ago, qube said: does it work okay? haha Works okay for a free homemade one. Which bushings are you replacing, and are the suspension parts off the car? 1 Quote Share this post Link to post Share on other sites
qube 3570 Report post Posted July 5, 2017 Just now, zero said: Works okay for a free homemade one. Which bushings are you replacing, and are the suspension parts off the car? all of the rear they will be coming off this weekend. can i come grab it off you sometime? Quote Share this post Link to post Share on other sites
zero 1162 Report post Posted July 5, 2017 3 minutes ago, qube said: all of the rear they will be coming off this weekend. can i come grab it off you sometime? If you are doing subframe bushings you will probably want a press as my tool is more for the smaller bushings. You are welcome to bring your stuff around and I'll help you remove as many bushings as we can. You can bring around by hex key you borrowed last time too. 2 Quote Share this post Link to post Share on other sites
NakiTouring 54 Report post Posted July 5, 2017 13 hours ago, zero said: You can bring around by hex key you borrowed last time too. Haha, once bitten, twice shy... Quote Share this post Link to post Share on other sites
qube 3570 Report post Posted July 6, 2017 21 hours ago, zero said: If you are doing subframe bushings you will probably want a press as my tool is more for the smaller bushings. You are welcome to bring your stuff around and I'll help you remove as many bushings as we can. You can bring around by hex key you borrowed last time too. will flick u a txt nathan Quote Share this post Link to post Share on other sites
qube 3570 Report post Posted July 6, 2017 Need something like this or or any home made thing that will do the trick. let me know if anyone has something. its for the main ball joint in the rear suspension so i cant bring it to yours nathan unless i bring the whole car haha Quote Share this post Link to post Share on other sites
zero 1162 Report post Posted July 7, 2017 Here it is in action installing a subframe bushing. Don't mind the rags, they are just there to avoid scratching the freshly painted subframe. Send me a text if you want to borrow it. 1 Quote Share this post Link to post Share on other sites
qube 3570 Report post Posted August 29, 2017 Anyone have a airbag reset tool for an E39? Asking on behalf of a friend. Have done some work on the passenger seat and the light came on. Pretty sure nothing wrong just needs to be reset. Cheers Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted August 29, 2017 What did you do to the seat ? Quote Share this post Link to post Share on other sites
qube 3570 Report post Posted August 29, 2017 1 hour ago, *Glenn* said: What did you do to the seat ? fixed the issue with the backrest twisting Quote Share this post Link to post Share on other sites
Gabe79 410 Report post Posted August 29, 2017 (edited) 45 minutes ago, qube said: Anyone have a airbag reset tool for an E39? Asking on behalf of a friend. Have done some work on the passenger seat and the light came on. Pretty sure nothing wrong just needs to be reset. Cheers PA Soft/BMW Scanner should be able to reset that. I haven't done it myself, but would be happy to give it a go for you. Edited August 29, 2017 by Gabe79 1 Quote Share this post Link to post Share on other sites
