Lachie 1 Report post Posted September 5, 2014 (edited) Hi guys, I sold my old Avus E39 last year but got the itch again a couple of months ago. Bought a low KM but but rough looking and running Silverstone one with huge potential. Got Vanos done by Graeme at BM Workshop and although that solved one problem (extremely well, he's a magician) it presented another one being a more guttural noise from within. Long story short, it looks like I can either do a repair with the risk of throwing a rod out the side of the block at any point or replace the motor. What I'd like to do is a find another S62 to drop in there. Problem is of course, I'm on a tight budget.... Does anyone of any S62s out there for a good price? Can do a good deal on jewellery in return (wife's a jeweller). How much would your mrs love you?? Not only are you selling an engine but you're getting her jewellery. Amazing opportunity! Cheers guys, Lachie Edited September 5, 2014 by Lachie Quote Share this post Link to post Share on other sites
BreakMyWindow 1921 Report post Posted September 5, 2014 (edited) Jooles and I went to look at that Silverstone blue M5 earlier this year. Indeed had a very concerning knocking sound from the sump area. Has the mechanic removed the upper and lower oilpans to confirm spun bearing(s) ? usually when they start to knock the damage is already done and will have more than likely damaged the very expensive crankshaft. The longer it's driven the more that spun bearing(s) eat away at the perfectly machined bearing journal finish on the crank. You're probably going to want to look at sourcing a motor o'seas...... Good luck!! Edited September 5, 2014 by BreakMyWindow Quote Share this post Link to post Share on other sites
Lachie 1 Report post Posted September 5, 2014 (edited) Yep sump removed, indeed it is a crankshaft issue so that's why I'm thinking I might quit while I'm ahead and get a fresh motor. Have had a look overseas, bloody expensive.... Might concentrate on getting it looking pretty then re-visit motor issue. Edited September 5, 2014 by Lachie Quote Share this post Link to post Share on other sites
Eagle 1732 Report post Posted September 5, 2014 Wow someone actually bought it Quote Share this post Link to post Share on other sites
M5V8 337 Report post Posted September 5, 2014 Would it be easier to source a e90 m3 v8? Maybe more around? Quote Share this post Link to post Share on other sites
Lachie 1 Report post Posted September 5, 2014 I thought about that but apparently they're a bit problematic. Unlike the S62 of course..... Quote Share this post Link to post Share on other sites
FIAT 131R 223 Report post Posted September 5, 2014 Would an M62 non vanos be of interest. I have a 6 speed manual gearbox, driveshaft, diff, diff cradle etc etc to go with it Quote Share this post Link to post Share on other sites
Lachie 1 Report post Posted September 5, 2014 On 9/5/2014 at 5:11 AM, FIAT 131R said: Would an M62 non vanos be of interest. I have a 6 speed manual gearbox, driveshaft, diff, diff cradle etc etc to go with it Thank you, might power up if anything though. Quote Share this post Link to post Share on other sites
BreakMyWindow 1921 Report post Posted September 8, 2014 This sounds like a cost effective option : http://www.ecstuning.com/BMW-E39-M5-S62_5.0L/Engine/Mechanical/ES2225985/ Quote Share this post Link to post Share on other sites
westy 614 Report post Posted September 8, 2014 LS2 Quote Share this post Link to post Share on other sites
E30 325i Rag-Top 2995 Report post Posted September 8, 2014 How badly marked is the crank? Is it possible to get the crank journals re-ground and then over-sized bearing shells fitted. Always used to be an economic way or repairing an engine - provided you did the strip down and re-build yourself. Quote Share this post Link to post Share on other sites
sonic_attack 89 Report post Posted September 8, 2014 It would seem madness to not be able to knock a bit off the crank and reshell it. Surely thats an option? Quote Share this post Link to post Share on other sites
Allanw 1073 Report post Posted September 8, 2014 anything is repairable (with enough skill/money etc). I once brought a Suzuki Van for Dad with a run big end... the guy who I brought it off (it was his Dairy van) went to all the effort of stripping the engine down, put a new pair of bearing shells in, then sealed EVERYTHING back together with red silicone. Including the head gasket. When he fitted the new bearing shells, not only did he not clean up/grind the crank, but he left the old shells in with it!!!! It didn't run too quietly! So we had a crank that had worn about 5mm off the journal, and was a lovely blue colour. We had the crank spray-welded up to the right diameter and then ground it back to the right size. Worst case is something similar for the S62, but I'd have thought like said above - grind to suit oversize shells and reassemble (with a supercharger for efficiency and safety etc). Quote Share this post Link to post Share on other sites
hybrid 1045 Report post Posted September 8, 2014 Dont be scared off by a few sounds within. Give HellBM a phone, for either repairing it .. or he has a s62 there if that doesnt work out. Quote Share this post Link to post Share on other sites
M3_Power 636 Report post Posted September 9, 2014 (edited) ^ I can't see Ray selling that low km facelift S62 at all Josh ... that's his back up motor or another secret build haha!! Good luck to the OP with finding a replacement. They are becoming quite rare these S62s .. and rightly so given how brilliant it is. Edited September 9, 2014 by M3_Power 1 Quote Share this post Link to post Share on other sites
jeffbebe 1560 Report post Posted September 9, 2014 I've looked into it. I reckon best bet is to import a whole car from the UK. You should be able to land one with a decent engine for sub $20K including shipping and tax and you could make a decent chunk of that back parting everything you don't need. Quote Share this post Link to post Share on other sites
BreakMyWindow 1921 Report post Posted September 9, 2014 Lachie, are there fine pieces of metal stuck to the oil filter? Quote Share this post Link to post Share on other sites
HELLBM 1625 Report post Posted September 9, 2014 Had a weak moment and offered my spare S62 for this dilemma ($6000).Nothing came of it. Thankfully that generous offer passed otherwise I`d be kicking myself when the time comes to use it in another Hellbm Project. 5 Quote Share this post Link to post Share on other sites
jeffbebe 1560 Report post Posted September 9, 2014 (edited) $6K! Ray, that's a steal.... Lucky you didn't offer that to me or you might be down one S62 right now!! Edit: Also a pity Lachie didn't check the boards before buying that Silverstone one. He might not be in the predicament he's in... Should have kept the Avus one, Lachie! I see it now and again and the new owner has done a great job restoring it! Looks mint!! Edited September 9, 2014 by jeffbebe 1 Quote Share this post Link to post Share on other sites
M3_Power 636 Report post Posted September 9, 2014 Holy crap Ray ... that's a steal .... Good to hear you are keeping it!! Quote Share this post Link to post Share on other sites
hybrid 1045 Report post Posted September 9, 2014 haha im out of touch on the whos asked who and whos got what goss .... dam house reno Quote Share this post Link to post Share on other sites
Tristan 338 Report post Posted September 12, 2014 FWIW E90 V8 in ChCH at a wrecker for $12k ish Quote Share this post Link to post Share on other sites
BreakMyWindow 1921 Report post Posted September 12, 2014 The s65 is not suited to the e39 imo - lacks torque down low. Plus it'd be a lot more extra work getting it to talk to older electronics. Quote Share this post Link to post Share on other sites
hybrid 1045 Report post Posted September 12, 2014 On 9/12/2014 at 6:37 PM, BreakMyWindow said: The s65 is not suited to the e39 imo - lacks torque down low. Plus it'd be a lot more extra work getting it to talk to older electronics. Not impossible ... but very very hard yes. Lots of different sensors types and the digital side of things talks true CAN not LIN bus. Quote Share this post Link to post Share on other sites
Lachie 1 Report post Posted October 1, 2014 (edited) Ha I disappear for a few weeks and I've missed all the action. Yep should've kept the Avus one, was a great car. I'm glad to hear he's minted it. Ray's deal was very tempting but add to that re-ringed Vanos units and swapping engines, it added up pretty quickly so decided to do shells with BM Workshop for a very reasonable price (Graeme has been fantastic once again). I'm happy to resurrect what is otherwise a good, low KM S62. Thanks all for your advice, I'm just looking forward to be driving one again. Need a new rear boot lid (Kiwi one) and front bumper if anyone knows of any sitting around. Edited October 1, 2014 by Lachie 1 Quote Share this post Link to post Share on other sites
