duvey 245 Report post Posted March 20, 2016 That diff looks great. Quote Share this post Link to post Share on other sites
zero 1162 Report post Posted March 21, 2016 The best brakes for the money are e36 m3 with pagid pads. What is your opinion of using the e46 330i discs instead of the e36 m3 discs? Would they be better brakes for the money? Quote Share this post Link to post Share on other sites
hybrid 1045 Report post Posted March 21, 2016 e36 m3 are floating where as e46 330i are solid. There is a weight advantage with the e36 m3 discs which counts quite a bit on unsprung weight. while slightly larger the 330 ones have pretty much effect pad wear surface. 1 Quote Share this post Link to post Share on other sites
KwS 2450 Report post Posted March 21, 2016 are the early 3.0 disks floating, or only the evo ones? Quote Share this post Link to post Share on other sites
zero 1162 Report post Posted March 21, 2016 e36 m3 are floating where as e46 330i are solid. There is a weight advantage with the e36 m3 discs which counts quite a bit on unsprung weight. while slightly larger the 330 ones have pretty much effect pad wear surface. Thanks for that. Very helpful information. Quote Share this post Link to post Share on other sites
E30 325i Rag-Top 3043 Report post Posted March 23, 2016 are the early 3.0 disks floating, or only the evo ones? Pretty sure M3 3.0 are solid and only the 3.2 Evo are floating. Definately different part numbers. Quote Share this post Link to post Share on other sites
HaNs 226 Report post Posted March 23, 2016 Went for DTC70 front pads and HPPLUS rear pads, both from Hawk. Racetech stock them. Quote Share this post Link to post Share on other sites
HaNs 226 Report post Posted April 9, 2016 Little bit of progress. Hopefully start on cage anzac weekend Quote Share this post Link to post Share on other sites
richard 384 Report post Posted April 9, 2016 where did you get your steering boss kit from Quote Share this post Link to post Share on other sites
HaNs 226 Report post Posted April 9, 2016 where did you get your steering boss kit from BC Direct in Christchurch. Call Codie there and say I sent you. Wheel came from them. I'm using a push button on a telephone cord for the horn as I couldn't work out the slip ring and make it work. Have also ordered XYZ coil overs and hard race camber arms Quote Share this post Link to post Share on other sites
HaNs 226 Report post Posted April 23, 2016 Got some XZY coil overs and hard race camber arms. Also dropped it off for cage today. 1 Quote Share this post Link to post Share on other sites
Michael. 2313 Report post Posted April 23, 2016 Exciting. Quote Share this post Link to post Share on other sites
duvey 245 Report post Posted April 23, 2016 Awesome. Quote Share this post Link to post Share on other sites
HaNs 226 Report post Posted September 18, 2016 Cage is getting there 7 Quote Share this post Link to post Share on other sites
RedRocketTi 131 Report post Posted September 20, 2016 Loving those CF door cards! Have you done anything to the engine as far as track reliability? Oil cooler or baffled sump? One thing I noticed after tracking my Ti with the m52b28 was after a 15 min session around Ruapuna I would come in and have some tappet noise, it went away however but I noticed it mainly after coming in after a hot session. Loving that rear diffuser!!! Cant wait to see more of this build! Quote Share this post Link to post Share on other sites
HaNs 226 Report post Posted September 24, 2016 On Tuesday, September 20, 2016 at 3:58 PM, RedRocketTi said: Loving those CF door cards! Have you done anything to the engine as far as track reliability? Oil cooler or baffled sump? One thing I noticed after tracking my Ti with the m52b28 was after a 15 min session around Ruapuna I would come in and have some tappet noise, it went away however but I noticed it mainly after coming in after a hot session. Loving that rear diffuser!!! Cant wait to see more of this build! Yes got a hard motorsport baffle going in. Have the same issue with noise after a session. Will go to a thicker oil next time. Quote Share this post Link to post Share on other sites
HaNs 226 Report post Posted September 24, 2016 2 Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted September 24, 2016 On 9/20/2016 at 3:58 PM, RedRocketTi said: Loving those CF door cards! Have you done anything to the engine as far as track reliability? Oil cooler or baffled sump? One thing I noticed after tracking my Ti with the m52b28 was after a 15 min session around Ruapuna I would come in and have some tappet noise, it went away however but I noticed it mainly after coming in after a hot session. Loving that rear diffuser!!! Cant wait to see more of this build! I get no valve train noise at all after driving hard for extended track days or extended sprinted road trips in mine using ELF 5w30 full synthetic Euro4 oil.... mind you the motor in mine is not a sludged up import and I only use genuine oil filters Quote Share this post Link to post Share on other sites
zero 1162 Report post Posted September 24, 2016 2 hours ago, *Glenn* said: I get no valve train noise at all after driving hard for extended track days or extended sprinted road trips in mine using ELF 5w30 full synthetic Euro4 oil.... mind you the motor in mine is not a sludged up import and I only use genuine oil filters Hey Glenn, what do you think of the 'mann' and 'mahle' oil filters? They are meant to be the best according to the internets. I use ryco but I'm looking at switching if there is a better alternative. Quote Share this post Link to post Share on other sites
Daniel0663 30 Report post Posted September 27, 2016 Build is coming along real nicely hans! Quote Share this post Link to post Share on other sites
HaNs 226 Report post Posted November 10, 2016 Out of paint shop at last! 6 Quote Share this post Link to post Share on other sites
BreakMyWindow 1995 Report post Posted November 11, 2016 Inspiration for Joole's and my 2kcup car right here in this thread. Quote Share this post Link to post Share on other sites
Daniel0663 30 Report post Posted November 11, 2016 Great stuff Hans, ready to run this summer? Quote Share this post Link to post Share on other sites
HaNs 226 Report post Posted November 11, 2016 2 minutes ago, Daniel0663 said: Great stuff Hans, ready to run this summer? Yeh.. just when. Really just needs to be bolted together then corner weighted Quote Share this post Link to post Share on other sites
Garett 103 Report post Posted November 11, 2016 Coming together man starting to look like a real race car...exciting! Quote Share this post Link to post Share on other sites
