gjm 3300 Report post Posted May 28, 2019 Miss M would like bluetooth connectivity for her car. There are options that retain the stock headunit, but many $$$ seem to be involved. I've even seen one where the cassette mechanism is replaced by a bluetooth unit. Simpler and quicker is an aftermarket unit. Anyone fitted one? I know it requires a single DIN adapter to fit the larger 'hole' the BMW unit uses - any good sources for that? Quote Share this post Link to post Share on other sites
Olaf 3426 Report post Posted May 28, 2019 Aliexpress? https://www.aliexpress.com/item/one-din-Fascia-For-BMW-3-Series-E46-1998-2005-CD-DVD-Stereo-Radio-Panel-Dash/32849302159.html I've only changed factory units. Prefer the linked lighting, ergonomics, and cool features like speed-related auto volume control... 1 Quote Share this post Link to post Share on other sites
gjm 3300 Report post Posted May 28, 2019 I'd not yet looked at Ali - but if it is a viable option then could be the way we go. Have a new JVC Bluetooth headunit coming at some point. Will keep the BMW one, of course - can always swap it back in when the time comes for Miss M to part ways with her (current? Latest?) 318i. Quote Share this post Link to post Share on other sites
qube 3570 Report post Posted May 28, 2019 https://www.trademe.co.nz/2163784198 $20 locally in nz if you dont want to wait 3 weeks 2 Quote Share this post Link to post Share on other sites
scottr 11 Report post Posted May 29, 2019 i have one of those android double din original style units which works a treat, between 3-400 nzd from aliexpress. relocating the heater controls lower can be a painwithout the proper bracket. prior to that i had a grom which worked by plugging into the CD changer lead in the boot, but itwas a fairly average experience. think that was 90 bucks from trademe at the time. 1 Quote Share this post Link to post Share on other sites
gjm 3300 Report post Posted May 29, 2019 2 hours ago, qube said: https://www.trademe.co.nz/2163784198 $20 locally in nz if you dont want to wait 3 weeks Not going to be much difference in price to ordering from Ali, either. The unit we've got for 'er ladyship is also available from Jonvy: https://www.jonvy.co.nz/index.php?route=product/product&product_id=7721 Nothing flash or fancy. But should do the job. Sadly the radio is unlikely to work. The car originally had the radio antenna in the windscreen, and when the screen was replaced (prior to our ownership) the new screen had no such connectivity. Ho hum. Unlikely to be a problem. Quote Share this post Link to post Share on other sites
Olaf 3426 Report post Posted May 29, 2019 Get a shark fin antenna, cable it up, job done! Quote Share this post Link to post Share on other sites
Olaf 3426 Report post Posted May 29, 2019 ... mind you, do the yoof of today listen to FM? ? Quote Share this post Link to post Share on other sites
gjm 3300 Report post Posted May 29, 2019 55 minutes ago, Olaf said: ... mind you, do the yoof of today listen to FM? ? Spotify streaming seems to be the way, these days... 1 Quote Share this post Link to post Share on other sites
Neal 576 Report post Posted May 29, 2019 4 hours ago, Olaf said: Get a shark fin antenna, cable it up, job done! Most of the shark fin aerials where for car phone kits . I don’t think they cover fm frequency’s. I did however reuse mine as a Bluetooth aerial when I removed my jap phone cradle and retrofit a ULF for handsfree and voice commands. the old analogue tv aerials which sit between the body and rear bumper may work be an option . I’d connect it to the rear radio antenna behind the lh c pillar trim. It needs to be powered via 12 volts to its white wire. fm antenna is normally built into rear window btw 1 Quote Share this post Link to post Share on other sites
Olaf 3426 Report post Posted May 29, 2019 6 hours ago, Neal said: Most of the shark fin aerials where for car phone kits . I don’t think they cover fm frequency’s. fm antenna is normally built into rear window btw On my e46 Touring, the FM antenna is in the side window. I had thought the shark fin on my e60 was for radio duties (FM, Tel, Satellite radio & GPS)... I used to puzzle how the FM wavelength was effectively catered to by such a small stub! 1/16th wave folded dipole? ?. As you say - FM is in the glass and the shark fin is the diverity antenna. I found this on Aliexpress whilst googling... https://www.aliexpress.com/i/32919244671.html not convinced it'd be effective, looks like it's a cosmetic update to existing bee-sting antennas. Ahh the bee-sting. Sometimes I miss my Golf GTi MKII. Quote Share this post Link to post Share on other sites
Gaz 1077 Report post Posted May 30, 2019 Does the car have a CD stacker in the boot? Have seen them replaced with bluetooth module Quote Share this post Link to post Share on other sites
gjm 3300 Report post Posted May 30, 2019 1 hour ago, Gaz said: Does the car have a CD stacker in the boot? Have seen them replaced with bluetooth module Don't think it does, but I'll see if we can check later. Quote Share this post Link to post Share on other sites
Eagle 1787 Report post Posted May 30, 2019 Single din headunits with those fascias always look out of place on BMW's. The way @qube did it for his E39 was ok though. Id just get a dynavin etc clone and be done with it, they are only a couple of hundred more and have much many more features, even if dont use all of it its surely helps when you sell the car. 2 Quote Share this post Link to post Share on other sites
gjm 3300 Report post Posted May 30, 2019 1 hour ago, Eagle said: Single din headunits with those fascias always look out of place on BMW's. The way @qube did it for his E39 was ok though. Id just get a dynavin etc clone and be done with it, they are only a couple of hundred more and have much many more features, even if dont use all of it its surely helps when you sell the car. The Dynavins are nice, but the N7 (for the E46) is $1k++. I expect a clone would be much cheaper, but it's sadly not going to compare to the $80 for a bluetooth headunit, plus a bit for a fitting kit. Appearances would be more important if it wasn't a student car - resale value is likely to be measured in the very, very low $000s, if not $00s! Personally I'd like an Android-enabled Dynavin-type solution, but Miss M just wants bluetooth connectivity. ?♂️ Quote Share this post Link to post Share on other sites
qube 3570 Report post Posted May 30, 2019 I had thought about the option of maintaining the factory stereo + climate control at the top area and where the cubby hole flap door is, mount a sony/jvc unit behind it and close the door. Super stealth. Cant remember if there is enough depth for a headunit behind there, its been a while since i've opened up an e46 console.. Quote Share this post Link to post Share on other sites
hunter 413 Report post Posted June 1, 2019 if you go mechless (no cd / tape ) Bluetooth an d usb only, the units can be smaller. I had a very nice single DIN Alpine in my e46. re Bluetooth only units try these guys https://gromaudio.com/store/all-bmws.html - I just installed one in my E39 and it's easy to do ith good results whilst retaining the factory look and feel. Other option is Eonon Android unit, effectively a Dynavin "clone" they seem well reviewed and you get a lot of functionality, and up to date android OS. 1 Quote Share this post Link to post Share on other sites
gjm 3300 Report post Posted June 1, 2019 (edited) 2 hours ago, hunter said: if you go mechless (no cd / tape ) Bluetooth an d usb only, the units can be smaller. I had a very nice single DIN Alpine in my e46. re Bluetooth only units try these guys https://gromaudio.com/store/all-bmws.html - I just installed one in my E39 and it's easy to do ith good results whilst retaining the factory look and feel. Other option is Eonon Android unit, effectively a Dynavin "clone" they seem well reviewed and you get a lot of functionality, and up to date android OS. This might work... Retains stock appearance.https://gromaudio.com/store/bt3_adapters/bmw-mini-98-05-bluetooth-adapter-car-kit-behind-the-radio-connector.html I'll investigate Eonon. For Miss M it'll need to work with Apple (which it may well do) - I see it's Android-based. Edit: This looks funky! https://www.eonon.com/Android-Car-GPS/Vehicle-Specific-GPS/BMW-E46-Android-8-Octa-Core-4GB-RAM-Car-Radio-GPS-Navigation-System7Inch-1-Din-Multimedia-Car-DVD-CD-Player-Support-Bluetooth-WiFi-4GDongle.html Edited June 1, 2019 by gjm 1 Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2153 Report post Posted June 2, 2019 pretty sure the aerial is in the rear glass not the front, with all the modules behind the C Pillar trim. maybe i am thinking of E38/E39 tho. but even on E46 cabby they have a whip antannea abd the wagons are in the left side window so... 1 Quote Share this post Link to post Share on other sites
gjm 3300 Report post Posted June 2, 2019 15 minutes ago, _ethrty-Andy_ said: pretty sure the aerial is in the rear glass not the front, with all the modules behind the C Pillar trim. maybe i am thinking of E38/E39 tho. but even on E46 cabby they have a whip antannea abd the wagons are in the left side window so... Could be! To be honest, I kinda assumed something based on sparse knowledge. You're not the only person who has said that, so there must be another reason why the radio part isn't working. Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2153 Report post Posted June 2, 2019 11 minutes ago, gjm said: Could be! To be honest, I kinda assumed something based on sparse knowledge. You're not the only person who has said that, so there must be another reason why the radio part isn't working. i dont recall trying it. i didnt really drive that car about all that much. 1 Quote Share this post Link to post Share on other sites
gjm 3300 Report post Posted June 2, 2019 42 minutes ago, _ethrty-Andy_ said: i dont recall trying it. i didnt really drive that car about all that much. No worries. Hardly a real issue! Quote Share this post Link to post Share on other sites
scottr 11 Report post Posted June 3, 2019 e46 antenna is in the rear glass., believe the antenna amp is in the C pilar as well. The grom works, it's cheap and cheerful but has limitaitons. For example mine never seemed to turn off when the car turned off and the phone would stay connected to it. There may be clones on aliexpress (haven't looked) for cheaper still. 1 Quote Share this post Link to post Share on other sites
qube 3570 Report post Posted June 4, 2019 https://www.trademe.co.nz/2175597811 this works decent and you dont need to get anything else like headunit/cover plate/adapters etc. plug and play for music, bluetooth calling etc through the factory stereo 3 Quote Share this post Link to post Share on other sites
gjm 3300 Report post Posted June 5, 2019 (edited) On 6/4/2019 at 3:32 PM, qube said: https://www.trademe.co.nz/2175597811 this works decent and you dont need to get anything else like headunit/cover plate/adapters etc. plug and play for music, bluetooth calling etc through the factory stereo Cool! Looks like a cheaper and locally available Grom-type solution. Am I right in thinking it connects to the back of the existing radio, and USB, microphone, auxiliary wires (whatever) are run to the glovebox or wherever suits? Edited June 5, 2019 by gjm Quote Share this post Link to post Share on other sites
