aja540i 1925 Report post Posted September 22, 2020 (edited) Picked up my newest old toy today, 1998 e39 530d touring, ex Ireland import, 197k Miles, no wof, no reg, started a list of what needs doing to turn it into a road legal, reliable tow mule, 1) EVERYTHING!! will start with a thorough cleaning inside and out and go from there.... Edited September 22, 2020 by aja540i 7 1 Quote Share this post Link to post Share on other sites
balancerider 845 Report post Posted September 22, 2020 Great choice - spotted this TM auction and hoped that a bimmersporter would buy it! Quote Share this post Link to post Share on other sites
BreakMyWindow 1995 Report post Posted September 22, 2020 Let the fun begin! Quote Share this post Link to post Share on other sites
aja540i 1925 Report post Posted September 22, 2020 Not sure that fun is the best choice of words but something will begin! Just reading through the service history, came to nz around 2003, has had 4 sets of front brake rotors and 3 skims!! Will start with basics, wof issues, polish headlights, slow leak in tyre, etc, then check on swirl flaps, egr, and turbo. It smokes like hell when its cold, nice blue oil smoke, so that will need sorting.... 1 Quote Share this post Link to post Share on other sites
Eagle 1787 Report post Posted September 22, 2020 Iirc the transmissions in these aren't that strong either. Quote Share this post Link to post Share on other sites
E30 325i Rag-Top 3043 Report post Posted September 22, 2020 15 hours ago, aja540i said: It smokes like hell when its cold, nice blue oil smoke, so that will need sorting.... I would look at your CCV to see if it’s the old loo-roll design, or the newer cyclone type, and how clean it all is. Sounds like it’s been neglected in terms of servicing, and when that’s all clogged up it dumps a lot of oil from the crankcase into the inlet making for the lovely blue smoke you describe. 1 Quote Share this post Link to post Share on other sites
polley 916 Report post Posted September 23, 2020 (edited) 3 hours ago, Eagle said: Iirc the transmissions in these aren't that strong either. So people say. But my engines been remapped, done burnouts all through town, and use it for towing my drift car around on big heavy tandem trailers up and down the kaimais and it hasn't given a single ounce of trouble. How ever I'm not under the illusion it will last for ever either ? Edited September 23, 2020 by polley Quote Share this post Link to post Share on other sites
BreakMyWindow 1995 Report post Posted September 23, 2020 I'd like to donate to the cause, I've got a set of facelift corner tail lights I'll give to you next coffee meeting @aja540i 2 Quote Share this post Link to post Share on other sites
aja540i 1925 Report post Posted September 23, 2020 4 hours ago, E30 325i Rag-Top said: I would look at your CCV to see if it’s the old loo-roll design, or the newer cyclone type, and how clean it all is. Sounds like it’s been neglected in terms of servicing, and when that’s all clogged up it dumps a lot of oil from the crankcase into the inlet making for the lovely blue smoke you describe. Thats what I am assuming, it has had a lot of oil changes but not much else in terms of maintenance. It will also be interesting to count the swirl flaps..... 1 Quote Share this post Link to post Share on other sites
aja540i 1925 Report post Posted September 23, 2020 35 minutes ago, BreakMyWindow said: I'd like to donate to the cause, I've got a set of facelift corner tail lights I'll give to you next coffee meeting @aja540i awesome thanks, when its all legal you can take it for a spin! Quote Share this post Link to post Share on other sites
aja540i 1925 Report post Posted September 23, 2020 2 hours ago, polley said: So people say. But my engines been remapped, done burnouts all through town, and use it for towing my drift car around on big heavy tandem trailers up and down the kaimais and it hasn't given a single ounce of trouble. How ever I'm not under the illusion it will last for ever either ? I am aware they can die, but it is doing everything it should at the moment so I will give it a service and hope for the best! 1 Quote Share this post Link to post Share on other sites
aja540i 1925 Report post Posted September 23, 2020 (edited) Started on the most pressing issue, there is an issue with the selector / key link cable and it won't release the key when in park, so the key can't be turned off and removed, removed centre console and steering column covers to sort it. Bonus cassette in the stereo!! Plays right through, both sides! Interior is absolutely filthy but not in bad shape otherwise. Edit: fixed, interlink cable adjusted, keys turns off and can be removed! Edited September 23, 2020 by aja540i Quote Share this post Link to post Share on other sites
Eagle 1787 Report post Posted September 23, 2020 5 hours ago, polley said: So people say. But my engines been remapped, done burnouts all through town, and use it for towing my drift car around on big heavy tandem trailers up and down the kaimais and it hasn't given a single ounce of trouble. How ever I'm not under the illusion it will last for ever either ? Thought you would have that manual box in it by now. Quote Share this post Link to post Share on other sites
Allanw 1081 Report post Posted September 23, 2020 Is that the same colour as your old 540i Touring? Also, you didn't tell everyone that you got out of trouble for buying this, by letting your Mrs buy a Lambo ? Works for me though - I can keep the Defender a bit longer, right? ? Quote Share this post Link to post Share on other sites
aja540i 1925 Report post Posted September 23, 2020 8 hours ago, E30 325i Rag-Top said: I would look at your CCV to see if it’s the old loo-roll design, or the newer cyclone type, and how clean it all is. Sounds like it’s been neglected in terms of servicing, and when that’s all clogged up it dumps a lot of oil from the crankcase into the inlet making for the lovely blue smoke you describe. Definitely the old type, possibly the original part from1998, black, crunchy, foul smelling mess! 2ill upgrade to the new design part. Still has the egr and I can't see but I'm guessing the swirl flaps as well. 1 Quote Share this post Link to post Share on other sites
aja540i 1925 Report post Posted September 23, 2020 1 minute ago, Allanw said: Is that the same colour as your old 540i Touring? Also, you didn't tell everyone that you got out of trouble for buying this, by letting your Mrs buy a Lambo ? Works for me though - I can keep the Defender a bit longer, right? ? no, the 540 was Biarritz Blau, this is Orient blau, quite a bit darker. Yes the Mrs is distracted by her Lamborghini for now, but I suspect this will come up again in the future!! Have you finished the Defender yet? Quote Share this post Link to post Share on other sites
Allanw 1081 Report post Posted September 23, 2020 10 hours ago, aja540i said: no, the 540 was Biarritz Blau, this is Orient blau, quite a bit darker. Yes the Mrs is distracted by her Lamborghini for now, but I suspect this will come up again in the future!! Have you finished the Defender yet? Ummm... no. These things take time ? Quote Share this post Link to post Share on other sites
E30 325i Rag-Top 3043 Report post Posted September 24, 2020 16 hours ago, aja540i said: Definitely the old type, possibly the original part from1998, black, crunchy, foul smelling mess! 2ill upgrade to the new design part. Still has the egr and I can't see but I'm guessing the swirl flaps as well. That's not good. They get pretty gunky between services, even if you change them often. Easy fix though, so not too bad. Swirl flaps are a pain because the only way you can get to them is to take the manifold off (good opportunity to de-gunk that bit as well though).. if you have a spare wing mirror you might be able to see up underneath whether the flaps are still fitted or been blanked off. Tbh I think the 3.0ltr diesel flaps are much more robust than the 2.0ltr ones. It's not an expensive or difficult job for peace of mind though. Quote Share this post Link to post Share on other sites
polley 916 Report post Posted September 24, 2020 I checked my swirl flaps on my 3l after hearing so much crap about them and mine were perfectly fine, no play or anything. And that was at 200k. I did remove them however for piece of mind, lost a bit of low down punch as a result of it. Quote Share this post Link to post Share on other sites
aja540i 1925 Report post Posted September 24, 2020 Old vs new! At some stage I will replace it with the cyclone type, but this will do for now. 1 Quote Share this post Link to post Share on other sites
BreakMyWindow 1995 Report post Posted September 24, 2020 Is all the suspension original? Quote Share this post Link to post Share on other sites
aja540i 1925 Report post Posted September 24, 2020 It appears that it has had a set of shocks, but about 10 years ago! No evidence of any other suspension work....handles like 22 year old suspension. I will start on those bits once it is road legal. Quote Share this post Link to post Share on other sites
qube 3570 Report post Posted September 24, 2020 isnt it funny that the condition of suspension components are basically not a requirement for roadworthiness? 1 Quote Share this post Link to post Share on other sites
BreakMyWindow 1995 Report post Posted September 24, 2020 They are, a thorough wof inspector will call you out on worn bushes and ball joints however as long as the shocks aren't leaking they seem to get through when in reality the shocks are pretty much poked before 100,000kms. Quote Share this post Link to post Share on other sites
Michael. 2313 Report post Posted September 25, 2020 Awesome. Quote Share this post Link to post Share on other sites
