Driftit 2246 Report post Posted October 14, 2020 I'm curious if your brakes are the same that are on the 135i. And what BMW would quote for that car. Quote Share this post Link to post Share on other sites
leichtbau 525 Report post Posted October 14, 2020 50 minutes ago, Driftit said: I'm curious if your brakes are the same that are on the 135i. And what BMW would quote for that car. It's all the same part sharing really, see https://www.bimmerworld.com/About-Us/F30-M-Sport-Brakes/ Genuinely surprised to see that the retrofit kits run a differently sized disc and pad for the same caliper though, but you can run the same larger discs and pads in the S2NH option blue calipers, as the caliper and mount is the same. I'd be shocked if there wasn't multitudes of off the shelf pads on offer if you ran the brembo caliper part number past a competent brake specialist, some proper two piece rotors and not bmw pads would be a great option instead of getting tucked for stock garbage at the stealership, but that's a thread for another day. 3 Quote Share this post Link to post Share on other sites
LTK 1 Report post Posted October 14, 2020 Thanks for all the replies to my question. It has been very helpful. I'm now leaning towards the auto and have driven 2013 models of both an Edition 30 and an M-Sport. Quite liked the M-Sport but not sure whether I'm committing myself to high ongoing service costs based on some of the comments above. Thanks again for your advice. Quote Share this post Link to post Share on other sites
Herbmiester 947 Report post Posted October 14, 2020 3 hours ago, LTK said: Thanks for all the replies to my question. It has been very helpful. I'm now leaning towards the auto and have driven 2013 models of both an Edition 30 and an M-Sport. Quite liked the M-Sport but not sure whether I'm committing myself to high ongoing service costs based on some of the comments above. Thanks again for your advice. Maintenance is the key, servicing costs are not onerous but higher than something like a Toyota Corolla. The Transmission will need a filter and fluid change every 70-100k and other wise its just normal servicing. As to the brakes look for standard brakes as opposed to the Blue brakes and even then you will find the rotors will last for a number of years and the pads can be changed for less expensive but just a good aftermarket pieces. Quote Share this post Link to post Share on other sites
kiwi535 538 Report post Posted October 15, 2020 23 hours ago, Herbmiester said: Not sure what rush hour traffic you drive in but my experience with a manual is; clutch in clutch out repeat a thousand times, all the while wearing it out prematurely. As to putting an auto into neutral there is no need, all the modern autos are designed to deal with the rigors of stop start traffic and as the torque converter is operating at slow speed with only minor slip the heat is far from excessive. As to DSG gearboxes my wife's Skoda is at 220k of which a great deal is city commuting and there are no issues. I am pretty sure a manual gearbox will have had a new clutch or two if it had to do that amount of rush hour crawling. Auto transmissions like most mechanical devices if serviced regularly present few problems. And yes we know BMW's sealed for life statement is wrong. And FWIW I have a manual again and I enjoy driving it, but it cant compare performance wise to a modern auto like a ZF8HP. Your comment re Ford vs Holden makes little sense apart from reinforcing how much you dislike them because they are not European. .I had absolutely no issues with daily driving an e34 535 manual for many years .The ONLY time i had trouble with it was stop go traffic for may many minutes.A 535 has qite a tall first gear(relative to other cars) and the clutch was really quite tough.By the end of the traffic jam my left leg was really tired and sore.I dont think that tricling along pushing clutch in and out will have much wear.Stop and go may be.A 320d will have a very light clutch compared to a 535,and the diesel at idle is very strong .My 120 d was also manual,and again i had no trouble with it.I would still prefer a manual even though my last two modern cars have been autos. Quote Share this post Link to post Share on other sites
leichtbau 525 Report post Posted October 15, 2020 13 minutes ago, kiwi535 said: .I had absolutely no issues with daily driving an e34 535 manual for many years .The ONLY time i had trouble with it was stop go traffic for may many minutes.A 535 has qite a tall first gear(relative to other cars) and the clutch was really quite tough.By the end of the traffic jam my left leg was really tired and sore.I dont think that tricling along pushing clutch in and out will have much wear.Stop and go may be.A 320d will have a very light clutch compared to a 535,and the diesel at idle is very strong .My 120 d was also manual,and again i had no trouble with it.I would still prefer a manual even though my last two modern cars have been autos. I heard a similar thing in the High Court of New Zealand once, the presiding judge described council's argument as "very deleterious to your case." Quote Share this post Link to post Share on other sites
Herbmiester 947 Report post Posted October 15, 2020 11 hours ago, kiwi535 said: .I had absolutely no issues with daily driving an e34 535 manual for many years .The ONLY time i had trouble with it was stop go traffic for may many minutes.A 535 has qite a tall first gear(relative to other cars) and the clutch was really quite tough.By the end of the traffic jam my left leg was really tired and sore.I dont think that tricling along pushing clutch in and out will have much wear.Stop and go may be.A 320d will have a very light clutch compared to a 535,and the diesel at idle is very strong .My 120 d was also manual,and again i had no trouble with it.I would still prefer a manual even though my last two modern cars have been autos. Yes stop start is the killer and the main reason I dont drive a manual as my primary vehicle any more. It just about unavoidable in the Hutt to Wellington Crawl. Quote Share this post Link to post Share on other sites
Driftit 2246 Report post Posted October 15, 2020 On 10/14/2020 at 11:21 PM, leichtbau said: It's all the same part sharing really, see https://www.bimmerworld.com/About-Us/F30-M-Sport-Brakes/ Genuinely surprised to see that the retrofit kits run a differently sized disc and pad for the same caliper though, but you can run the same larger discs and pads in the S2NH option blue calipers, as the caliper and mount is the same. I'd be shocked if there wasn't multitudes of off the shelf pads on offer if you ran the brembo caliper part number past a competent brake specialist, some proper two piece rotors and not bmw pads would be a great option instead of getting tucked for stock garbage at the stealership, but that's a thread for another day. That is actually a really good guide. Quote Share this post Link to post Share on other sites
MilesP 13 Report post Posted October 16, 2020 I have been doing a fair bit of research specifically around the timing chain issues. It seems to me that any of the cars fitted with the N47 can have it go at any time but its clear as mud as to when they improved the issues aside from the cars that are fitted with the B47. So if you buy a 320d make sure it has a service history and make sure it hasn't been serviced in line with the factory recommended intervals. Quote Share this post Link to post Share on other sites
LTK 1 Report post Posted October 16, 2020 1 hour ago, MilesP said: I have been doing a fair bit of research specifically around the timing chain issues. It seems to me that any of the cars fitted with the N47 can have it go at any time but its clear as mud as to when they improved the issues aside from the cars that are fitted with the B47. So if you buy a 320d make sure it has a service history and make sure it hasn't been serviced in line with the factory recommended intervals. So, I'm looking at 2013 320D M-Sport. Imported from Japan with N47 with about 95k on the clock. I haven't seen the service history yet and I'm not sure the dealer will have it. Do you think I'm risking expensive repairs with that car? I'm planning on getting a pre-purchase inspection done at Auckland City BMW. Are they likely to be able to give an indications whether the timing chain is likely to cause issues or is there no real way of knowing? Quote Share this post Link to post Share on other sites
qube 3570 Report post Posted October 16, 2020 9 minutes ago, LTK said: So, I'm looking at 2013 320D M-Sport. Imported from Japan with N47 with about 95k on the clock. I haven't seen the service history yet and I'm not sure the dealer will have it. Do you think I'm risking expensive repairs with that car? --> yes I'm planning on getting a pre-purchase inspection done at Auckland City BMW. Are they likely to be able to give an indications whether the timing chain is likely to cause issues or is there no real way of knowing? --> no got a link to the car you're looking at? Quote Share this post Link to post Share on other sites
LTK 1 Report post Posted October 16, 2020 4 minutes ago, qube said: got a link to the car you're looking at? https://www.eurocars.co.nz/vehicle/2013-BMW-320D/3331?s=1 Quote Share this post Link to post Share on other sites
qube 3570 Report post Posted October 16, 2020 looks like a nice example, cheapest Msport on the market atm it seems. Ive bought a car from them before. The battery died within a couple months and they organised a new one to be installed and coded when I called and told them about it. The car I got was a very low mileage 325i wagon, like 4x,xxx kms but the suspension was really bad so ended up spending about 2000 to replace it all. Makes me wonder if they know what they are importing.. (I assume most dealers dont really care, its a pure numbers game anyway) Regarding your one, since its at almost 100,000kms I suspect it will need some work but pretty much it will be the same story whichever one you buy thats for sale currently unless its privately owned with service history (unlikely, as most of the ones I see for sale are fresh imports). You are taking a risk which ever one you buy so either have deep pockets with enough spare change to cover the bills or prepare to get it sorted after you buy it for peace of mind. I would budget $2-3000 for "everything". Otherwise you could get mechanical warranty and wait for things to die and claim it. Either way, its suddenly going from a 20k car to a 23k car pretty much. 1 Quote Share this post Link to post Share on other sites
LTK 1 Report post Posted October 16, 2020 4 minutes ago, qube said: looks like a nice example, cheapest Msport on the market atm it seems. Ive bought a car from them before. The battery died within a couple months and they organised a new one to be installed and coded when I called and told them about it. The car I got was a very low mileage 325i wagon, like 4x,xxx kms but the suspension was really bad so ended up spending about 2000 to replace it all. Makes me wonder if they know what they are importing.. (I assume most dealers dont really care, its a pure numbers game anyway) Regarding your one, since its at almost 100,000kms I suspect it will need some work but pretty much it will be the same story whichever one you buy thats for sale currently unless its privately owned with service history (unlikely, as most of the ones I see for sale are fresh imports). You are taking a risk which ever one you buy so either have deep pockets with enough spare change to cover the bills or prepare to get it sorted after you buy it for peace of mind. I would budget $2-3000 for "everything". Otherwise you could get mechanical warranty and wait for things to die and claim it. Either way, its suddenly going from a 20k car to a 23k car pretty much. Thanks Qube. I appreciate you taking the time to have a look and giving me that feedback. The joys of buying a second hand car I guess - difficult to know if any problems will arise. 1 Quote Share this post Link to post Share on other sites
E30 325i Rag-Top 3043 Report post Posted October 16, 2020 1 hour ago, LTK said: https://www.eurocars.co.nz/vehicle/2013-BMW-320D/3331?s=1 M-sport models do look a lot better in the F30 shape in my opinion, good colour as well - I think the dark greys suit the M-Sport look. Good news is that this car does not have the more expensive M-Sport brake option (blue //M calipers) that was mentioned above as being expensive to update the pads. Wheels are also smaller size than most of the NZ new vehicles (18s v 19s) so tyres should be a little more costly when / if they need to be replaced, they might also be non-run flats which would be a bit cheaper again to replace. Being Jap import it has got the alcantara (man made suede) interior rather than leather, but to me it is still a nice interior and hard wearing. Buying any used car at around 100,000kms is always a bit of a gamble, even with homework and checking everything out there is still a risk as many problems can come up without any warning signs. So as Qube says, keep a bit of budget back for maintenance or problems. Plan for the worst, but hope for the best, as they say. Quote Share this post Link to post Share on other sites
balancerider 847 Report post Posted October 16, 2020 3 hours ago, LTK said: https://www.eurocars.co.nz/vehicle/2013-BMW-320D/3331?s=1 would tend to steer clear of that dealer...quality of their stock is often poor, cheap =/ good value Quote Share this post Link to post Share on other sites
kiwi535 538 Report post Posted October 16, 2020 13 hours ago, Herbmiester said: Yes stop start is the killer and the main reason I dont drive a manual as my primary vehicle any more. It just about unavoidable in the Hutt to Wellington Crawl. to be fair, i go the other direction in the morning.Much less traffic Quote Share this post Link to post Share on other sites
Herbmiester 947 Report post Posted October 16, 2020 21 minutes ago, kiwi535 said: to be fair, i go the other direction in the morning.Much less traffic Your the lucky one I used to do that in the 90's so much less traffic. Anything after 7am these days is a nightmare. Quote Share this post Link to post Share on other sites
Navin 180 Report post Posted October 16, 2020 I was a die hard manual fan for a long time, 25+ cars prior to my old 135i were all manuals until I found myself needing to commute to the city daily.....not worth it. Bright side is I got a chance to learn how good modern autos are. Last auto I drove long term before my current zf8 was probably my BJ Familia 14 years ago. 1 Quote Share this post Link to post Share on other sites
