Vinu Chandrakumar 7 Report post Posted March 9, 2022 (edited) Hi all, Have found myself another E30 after a few years of not owning one, my first 4 cylinder. Can anyone help me out and tell me what these pipes are: Also seems like my cooling system is from an M20, Does anyone have an M40 radiator lying around. Great to be back on the forums, thanks in advance. Vinu Edited March 9, 2022 by Vinu Chandrakumar Quote Share this post Link to post Share on other sites
Palazzo 498 Report post Posted March 9, 2022 Aren’t they the heater pipes from memory? Quote Share this post Link to post Share on other sites
Vinu Chandrakumar 7 Report post Posted March 9, 2022 (edited) 1 hour ago, Palazzo said: Aren’t they the heater pipes from memory? Yep, just checked if my heater works. It doesn't. Edited March 9, 2022 by Vinu Chandrakumar Quote Share this post Link to post Share on other sites
aja540i 1909 Report post Posted March 9, 2022 There's a good chance your heater has a leak and a previous owner couldn't be bothered taking the dash out! 3 Quote Share this post Link to post Share on other sites
Eagle 1767 Report post Posted March 9, 2022 Hard to see where the hose goes as its covered, but it looks to have been bypassed probably due to heater core leak Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted March 9, 2022 have heater core and valve if needed 1 Quote Share this post Link to post Share on other sites
Vinu Chandrakumar 7 Report post Posted March 10, 2022 16 hours ago, aja540i said: There's a good chance your heater has a leak and a previous owner couldn't be bothered taking the dash out! Does it require taking the whole dash out? That's gonna be fun. Quote Share this post Link to post Share on other sites
Vinu Chandrakumar 7 Report post Posted March 10, 2022 11 hours ago, BM WORLD said: have heater core and valve if needed Good to know, how much will it run me? Quote Share this post Link to post Share on other sites
325iRod 144 Report post Posted March 10, 2022 Here's a pretty good diy video for heater core 2 Quote Share this post Link to post Share on other sites
Olaf 3409 Report post Posted March 10, 2022 (edited) 9 hours ago, Vinu Chandrakumar said: Does it require taking the whole dash out? That's gonna be fun. No. It's a somewhat shitty job. Remove glovebox, remove centre console, unbolt brake booster etc. Install a new heater core, you don't want to do that again if a used part fails! I got new OEM M40 radiator from Abel Smith Radiators in Wellington. It's been in 3 years and 4 months, trouble-free. Be sure to get Genuine BMW Coolant and some deionised water. PS - you'll want to check out (and perhaps replace) your thermostat, clear the bleed bolt etc, perhaps new bolts. Disconnected rotted heater may indicate some cooling system neglect. Edited March 10, 2022 by Olaf added postscript 1 Quote Share this post Link to post Share on other sites
E30 325i Rag-Top 3018 Report post Posted March 10, 2022 Unless you’re going to replace all of it.. core pipe, matrix, hoses, etc. I would plumb it back in to find exactly what is leaking, and where from. I thought I was staring down the barrel of pulling it all out when at the last minute I found the leak was from one of the pipes coming through the firewall (those ends sticking out corrode and don’t seal against the rubber hose). Cleaned it up with sand paper a bit of sealant for good measure and was all good. It helps that coolant is bright green so you can see it easier! 3 Quote Share this post Link to post Share on other sites
nick496 271 Report post Posted March 11, 2022 Yeah, I'd go with Jon's advise on testing where the leak is coming from. I'd add to his notes, that it's worth removing the center console, and glovebox, and putting down some towels to try catch whatever comes out Hopefully it's just a dribble, and you don't end up with something like so 1 Quote Share this post Link to post Share on other sites
KwS 2447 Report post Posted March 11, 2022 Even better is to borrow/buy a pressure tester and pressure test the heater core with just plain water in it. 1 Quote Share this post Link to post Share on other sites
Vinu Chandrakumar 7 Report post Posted March 11, 2022 On 3/10/2022 at 9:20 PM, 325iRod said: Here's a pretty good diy video for heater core 16 hours ago, Olaf said: No. It's a somewhat shitty job. Remove glovebox, remove centre console, unbolt brake booster etc. Install a new heater core, you don't want to do that again if a used part fails! I got new OEM M40 radiator from Abel Smith Radiators in Wellington. It's been in 3 years and 4 months, trouble-free. Be sure to get Genuine BMW Coolant and some deionised water. PS - you'll want to check out (and perhaps replace) your thermostat, clear the bleed bolt etc, perhaps new bolts. Disconnected rotted heater may indicate some cooling system neglect. 13 hours ago, E30 325i Rag-Top said: Unless you’re going to replace all of it.. core pipe, matrix, hoses, etc. I would plumb it back in to find exactly what is leaking, and where from. I thought I was staring down the barrel of pulling it all out when at the last minute I found the leak was from one of the pipes coming through the firewall (those ends sticking out corrode and don’t seal against the rubber hose). Cleaned it up with sand paper a bit of sealant for good measure and was all good. It helps that coolant is bright green so you can see it easier! 4 hours ago, nick496 said: Yeah, I'd go with Jon's advise on testing where the leak is coming from. I'd add to his notes, that it's worth removing the center console, and glovebox, and putting down some towels to try catch whatever comes out Hopefully it's just a dribble, and you don't end up with something like so 4 hours ago, KwS said: Even better is to borrow/buy a pressure tester and pressure test the heater core with just plain water in it. Thanks for all the tips guys have sorted the correct radiator, new too. Gonna plumb everything back up and find out where my leak is actually coming from, then get to either replacing or fixing the necessary parts. 1 Quote Share this post Link to post Share on other sites
