bravo 35 Report post Posted July 8, 2009 No. But pre f/l has chrome around the windows, f/l is black. You can swap them (the trims) over - but is a bit of a PITA. The doors themselves are EXACTLY the same. Quote Share this post Link to post Share on other sites
e30plz 1 Report post Posted July 8, 2009 Black>Chrome, So all good. Shot boss. Quote Share this post Link to post Share on other sites
Antallica 23 Report post Posted July 8, 2009 Quick question, My E36 has eaten half its coolant, what do I replace it with? Anything specific? Quote Share this post Link to post Share on other sites
bravo 35 Report post Posted July 8, 2009 Coolant. You need to find the source of the loss, but in the meantime, just fill it up with antifreeze. You can buy the Nulon stuff from Repco or similar, or if you can get to BMW, their coolant is the correct stuff and costs about the same. The correct mix is about 50% antifreeze, 50% distilled water, but for top-ups straight anti freeze or straight water will do until you get it fixed. Just don't leave it for too long util you fix it in case you cook the motor. Quote Share this post Link to post Share on other sites
DRTDVL 0 Report post Posted July 8, 2009 Coolant. You need to find the source of the loss, but in the meantime, just fill it up with antifreeze. You can buy the Nulon stuff from Repco or similar, or if you can get to BMW, their coolant is the correct stuff and costs about the same. The correct mix is about 50% antifreeze, 50% distilled water, but for top-ups straight anti freeze or straight water will do until you get it fixed. Just don't leave it for too long util you fix it in case you cook the motor. Doesn't the antifreeze/water mix depend on the conditions you live in? if your not in freezing conditions you can run a higher % of water to allow better heat transferance from the metal of the engine to the "coolent" of the car? Quote Share this post Link to post Share on other sites
Mike 1 Report post Posted July 8, 2009 (edited) Yeah, but only really in extremes. 50/50 or 60/40 water/antifreeze should be fine for most of NZ. Edited July 8, 2009 by Mike Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted July 8, 2009 We use 50% 50% with genuine coolant Quote Share this post Link to post Share on other sites
Nobimmer 694 Report post Posted July 12, 2009 What is the thread size for the 2 holes next to the oil filter housing that you connect the oil cooler lines to? Just need some plugs to block off the oil cooler. Or can I just get an oil filter housing without the plugs in it? Where do I get the plugs from other than Enzed or the like. Cheers Ashkan. Quote Share this post Link to post Share on other sites
laadeelaa 0 Report post Posted July 12, 2009 What is the thread size for the 2 holes next to the oil filter housing that you connect the oil cooler lines to? Just need some plugs to block off the oil cooler. Or can I just get an oil filter housing without the plugs in it? Where do I get the plugs from other than Enzed or the like. Cheers Ashkan. Use the oil filter fitting from a 320i, they don't have oil coolers. Quote Share this post Link to post Share on other sites
bravo 35 Report post Posted July 12, 2009 Woah! Check out the brain on Emily! Hanging out too much with e30 owners. She be right dude. Quote Share this post Link to post Share on other sites
Nobimmer 694 Report post Posted July 12, 2009 Awesome Quote Share this post Link to post Share on other sites
JFry 1 Report post Posted July 21, 2009 My '97 320i is missing the brake duct on the passenger side, noticed this when I was looking for the external temp sensor. I am wondering if this is just a bolt in part (seems to be, from looking at the other duct), and if they will be different between m-sport and non m-sport cars because the front bumpers are slightly different? Thanks Jeff Quote Share this post Link to post Share on other sites
Mark 178 Report post Posted July 21, 2009 Yes, "bolt in" and yes they are different between M bumpers and non-M bumpers. Quote Share this post Link to post Share on other sites
JFry 1 Report post Posted July 21, 2009 Cheers for that. Quote Share this post Link to post Share on other sites
_BRS_ 209 Report post Posted July 21, 2009 I have a quick question, i need a new right rear electric window motor. Do i have to get a specific RIGHT rear window motor or can the left and right be swapped over and vise versa. -Blair Quote Share this post Link to post Share on other sites
brockie123 31 Report post Posted July 21, 2009 pretty sure they are different.. i can't member exactly.. but pretty sure you need the proper one. Quote Share this post Link to post Share on other sites
Nobimmer 694 Report post Posted July 21, 2009 I have one sitting in the door waiting to be stripped. If ya have no luck finding one in a coupe weeks then it's yours. Quote Share this post Link to post Share on other sites
_BRS_ 209 Report post Posted July 21, 2009 I have one sitting in the door waiting to be stripped. If ya have no luck finding one in a coupe weeks then it's yours.sweet as man, will let you know, possibly just take it anyway. Quote Share this post Link to post Share on other sites
Nobimmer 694 Report post Posted July 21, 2009 Sweet, if you are up these ways before then- come rip it out yourself. I just don't have the time atm. Quote Share this post Link to post Share on other sites
snolan 0 Report post Posted August 10, 2009 I have a BMW E30 1990 M40 engined car, the oil service light has just come on, a part from changing the oil filter and oil is there anything else I should be doing for a regular service? Also, any idea how much oil I need and is there any particular difference between brands of filters? Cheers Quote Share this post Link to post Share on other sites
greenday-rulz21 6 Report post Posted August 10, 2009 Bentley_Inspection_II_Check_List.pdf Bentley_Inspection_I_Check_List.pdf Bentley_Oil_Service_Check_List.pdf Quote Share this post Link to post Share on other sites
snolan 0 Report post Posted August 12, 2009 Awesome, any ideas on oil quantity though? Quote Share this post Link to post Share on other sites
Cale 36 Report post Posted August 12, 2009 According to the manual... With oil filter change: 4L W/out: 3.75L Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted August 12, 2009 According to the manual... With oil filter change: 4L W/out: 3.75L [/quote + or - .25 Litres Quote Share this post Link to post Share on other sites
snolan 0 Report post Posted August 12, 2009 cheers guys, makes that cheaper! Quote Share this post Link to post Share on other sites
