AN E30 Fan 1 Report post Posted July 1, 2012 (edited) How long did you run it for ? was it missing ? No more than a few mins, temperature gauge was still in the blue. All the rad hoses are warm apart from the bottom one(?), nope it wasn't missing it was running fine Edited July 1, 2012 by AJ_D Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted July 1, 2012 Start it again and try running it longer. You may have flooded it...give it full throttle and try starting it. Quote Share this post Link to post Share on other sites
AN E30 Fan 1 Report post Posted July 1, 2012 False alarm, battery was dead thats why it wasn't starting. Still white smoke coming out the back but that could be because it has no muffler and it hasn't been running in the last month. Going to take it for a quick drive to see if it overheats or uses any water Quote Share this post Link to post Share on other sites
cliffdunedin 8 Report post Posted July 1, 2012 I have a random beep that happens now and then, i have had a search and found the OBC memory 3 beeps... anyone know if this is the same thing? Cheers Quote Share this post Link to post Share on other sites
Lucan 196 Report post Posted July 1, 2012 battery was dead Batteries hate you. Quote Share this post Link to post Share on other sites
turbolizard 38 Report post Posted July 1, 2012 I have a random beep that happens now and then, i have had a search and found the OBC memory 3 beeps... anyone know if this is the same thing? CheersOBC will beep for an ice warning when outdoor temperature drops below 3 degrees. It does it again if it warms up and then drops through 3 degrees again. Is that it? Quote Share this post Link to post Share on other sites
cliffdunedin 8 Report post Posted July 1, 2012 Thanks heaps! That sounds more than likely the cause seeing as the temperature down here has been in the negatives the past week. Cheers Quote Share this post Link to post Share on other sites
_Matt_ 42 Report post Posted July 3, 2012 what's this noise? happens every start up. Quote Share this post Link to post Share on other sites
euroriffic 630 Report post Posted July 3, 2012 My car makes a Similar sort of sound, it's the rev counter moving on mine. Could be starter motor sticking. Where does the noise come from? Quote Share this post Link to post Share on other sites
dubman 39 Report post Posted July 3, 2012 is there a way to clean/rinse the insides of a headlamp? Mine has some water residue in there, wondering the best way to clean it without taking it apart. I dried it with a dehumidifier after water got into them, but there's a bit of a white residue in them Thanks Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2153 Report post Posted July 3, 2012 is there a way to clean/rinse the insides of a headlamp? Mine has some water residue in there, wondering the best way to clean it without taking it apart. I dried it with a dehumidifier after water got into them, but there's a bit of a white residue in them Thanks assume you mean E30? you can take the lamp off the bracket and remove the plastic bulb holder then rinse all you like under a tap etc. but the water in there before would be because its not sealing properly, the only two joins on a facelift lamp are around the glass/plastic intersection and also the bulbholder/lamp body. you could put another layer of silicon around the glass? carefull not to make it too thick or the chrome ring wont go back on. could do the same on the bulb holder touhg may be a bitch to change the bulbs at a later date Quote Share this post Link to post Share on other sites
dubman 39 Report post Posted July 3, 2012 thanks Andy, will give it a go they are new and weren't stored correctly lol Quote Share this post Link to post Share on other sites
gouba 0 Report post Posted July 5, 2012 e30 coupe has a dull whining noise that comes from the front left wheel, increases with speed. At speed it disappears when turning right (say a long right turn on the motorway) I'm guessing the wheel bearing needs replacing? this right? Quote Share this post Link to post Share on other sites
dubman 39 Report post Posted July 5, 2012 http://www.bimmersport.co.nz/forums/index....hl=wheel++noise might help you out a bit Quote Share this post Link to post Share on other sites
gouba 0 Report post Posted July 5, 2012 ah sweet! how much did it roughly cost you for a new wheel bearing to be fitted? Quote Share this post Link to post Share on other sites
dubman 39 Report post Posted July 5, 2012 PM'd Quote Share this post Link to post Share on other sites
antil33t 90 Report post Posted July 5, 2012 yes most nz new cars have 80amp instead of the 140amp that the jap imports have have one if needed 021433600 I think it's 520i's that have those, my car has a 140a and it's NZ new. in the manual it seems to suggest that 520i have the smaller size. Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted July 5, 2012 I think it's 520i's that have those, my car has a 140a and it's NZ new. in the manual it seems to suggest that 520i have the smaller size. no some 328i nz new i have wrecked have 80ampsmaybe yours was upgraded , or being a e34 instead of a e36 Quote Share this post Link to post Share on other sites
dubman 39 Report post Posted July 9, 2012 any tips on pressing in the connector pipe to the block? the o-ring is making it very tuff, especially with the tight space and little leverage dish washing liquid to lube? Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted July 9, 2012 ^^^ yup that'll do Quote Share this post Link to post Share on other sites
byza213 1 Report post Posted July 10, 2012 e39 service is due where to take it around central Auckland or north shore? Quote Share this post Link to post Share on other sites
antil33t 90 Report post Posted July 13, 2012 E34 Touring M50NV. Driving home, temperature gauge slowly goes up to about 3 1/4 mark. Stopped turned the car off, checked the engine - no leaks or steam... radiator stone cold, top pipe hot, bottom pipe cold. Heater still working well. Thermostat replaced about a month ago.. Possibly failed again? Maybe water-pump? Blocked radiator looking likely. Annoying... will figure it out tomorrow. Quote Share this post Link to post Share on other sites
cliffdunedin 8 Report post Posted July 13, 2012 ^^^ Not an air lock!? Quote Share this post Link to post Share on other sites
antil33t 90 Report post Posted July 14, 2012 Doubt you can magically get air locks? lol Might try that first... Quote Share this post Link to post Share on other sites
byza213 1 Report post Posted July 17, 2012 my e30 is sputtering when i give it some gas ? any thoughts have changed spark plugs , oil , filter etc what to check? car drives fine otherwise just a strong misfire going well i put my foot down its a 318i Quote Share this post Link to post Share on other sites
