Kepes 231 Report post Posted March 28, 2014 On the topic of O2 sensors... my 1987 325i (pfl) doesn't seem to have one at all. Does that sound normal or did they all have them from factory? Thanks Quote Share this post Link to post Share on other sites
e30ftw 435 Report post Posted March 29, 2014 VANOS Seal reaplacement - On a single Vanos M52, I have the new seals. I don't really get what the Besian Systems write up wants me to do with 2 seals - It says insert the o-ring into the piston groove, then it says insert the Teflon seal into the groove. They don't look like they will go ontop of eachother or are they supposed to?? Help I'm half way through haha Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted March 29, 2014 On the topic of O2 sensors... my 1987 325i (pfl) doesn't seem to have one at all. Does that sound normal or did they all have them from factory? Thanks only jap ones will have them , and not needed anyway Quote Share this post Link to post Share on other sites
Allanw 1081 Report post Posted March 29, 2014 VANOS Seal reaplacement - On a single Vanos M52, I have the new seals. I don't really get what the Besian Systems write up wants me to do with 2 seals - It says insert the o-ring into the piston groove, then it says insert the Teflon seal into the groove. They don't look like they will go ontop of eachother or are they supposed to?? Help I'm half way through haha They did on our M54 - O ring inside, teflon over the top - it may need a stretch slightly. The pistons fell out because the orings were so hard, then the newly sealed ones were failry tight to get in, and move. The O ring will flatten out a fair bit, into the square groove (shouldn't go hard, like the shitty genuine ones though!) Quote Share this post Link to post Share on other sites
Allanw 1081 Report post Posted March 29, 2014 On the topic of O2 sensors... my 1987 325i (pfl) doesn't seem to have one at all. Does that sound normal or did they all have them from factory? Thanks Yep - No emmisions gear on Dads NZ New 90' 325i SE - no O2 sensor, not even a charcoal cannister, not cats nothing! Quote Share this post Link to post Share on other sites
e30ftw 435 Report post Posted March 29, 2014 They did on our M54 - O ring inside, teflon over the top - it may need a stretch slightly. The pistons fell out because the orings were so hard, then the newly sealed ones were failry tight to get in, and move. The O ring will flatten out a fair bit, into the square groove (shouldn't go hard, like the shitty genuine ones though!) Sorted it, I had only cut and removed the teflon outer ring on the old one, didn't notice the o'ring underneath it. Mine too slid right out, nice and tight now can't wait to see how it goes tomorrow Quote Share this post Link to post Share on other sites
Allanw 1081 Report post Posted March 29, 2014 Sorted it, I had only cut and removed the teflon outer ring on the old one, didn't notice the o'ring underneath it. Mine too slid right out, nice and tight now can't wait to see how it goes tomorrow GOOD! The old O ring would have been so flat and hard that it would have looked like part of the piston, right? Quote Share this post Link to post Share on other sites
e30ftw 435 Report post Posted March 30, 2014 GOOD! The old O ring would have been so flat and hard that it would have looked like part of the piston, right? Yep it did. Sure got me.. I've replaced everything now and went for a drive but it seems real hesitant now. Wasn't the improvement I was hoping for Quote Share this post Link to post Share on other sites
e30ftw 435 Report post Posted March 31, 2014 Hmm true, wasn't aware it needed some bedding in. I replaced a whole bunch though, Coolant temp sensor, Intake air temp sensor, Cam position sensor, VANOS seals, Oil / Coolant change and cleaned out the ICV. It's idling better but seems quite sluggish. Knowing me I probably missed something somewhere.. Quote Share this post Link to post Share on other sites
slybma 38 Report post Posted March 31, 2014 My adjustable suspension for the E30 arrived today and I tested the rears and the car still wont sit low. Even without the collars in with the springs the car still sits too high, there has been a fair bit of weight removed from the back but surely there's a way to get the tire to tuck in the guard. Has anyone had any success with a certain spring? Quote Share this post Link to post Share on other sites
euroriffic 630 Report post Posted March 31, 2014 Cutties work well Quote Share this post Link to post Share on other sites
slybma 38 Report post Posted March 31, 2014 Haha ya ill call that plan B Quote Share this post Link to post Share on other sites
euroriffic 630 Report post Posted March 31, 2014 (edited) What brand did you get? And can you use the shock to compress the spring, making it lower and harder ? Edited March 31, 2014 by euroriffic Quote Share this post Link to post Share on other sites
slybma 38 Report post Posted March 31, 2014 I got XYZs but because ive done the five stud swap in using a set designed for a compact e36 which is more than likely my issue Quote Share this post Link to post Share on other sites
Etwenty1 45 Report post Posted March 31, 2014 Replaced the front left hub on an e46 last night - left the strut on the car. When installing the new one I did a check measure of the strut stub sticking out the bottom. hard up It was 53mm on the pass side but 58mm on the drivers side. Is this normal? maybe pre-camber for sloping road? Quote Share this post Link to post Share on other sites
cliffdunedin 8 Report post Posted April 2, 2014 Hey guys, how big is the single Vanos ring? I bought one from Beisan and when it arrived it looked a little bit big to me, id say the circumference is about a golf ball (maybe a little bigger) don't wanna pull it too bits and discover it's wrong haha Quote Share this post Link to post Share on other sites
KwS 2450 Report post Posted April 14, 2014 Hey, What viscosity is good for an E36 M3 3.0? Internet says everything, and the owners handbook is vague. Its running Motul 300V 15W50 which i think is FAR too thick (vanos rattles when warm). My old BMWs (all M52B25) LOVED Valvoline Synpower 5W40, would this be OK? Quote Share this post Link to post Share on other sites
euroriffic 630 Report post Posted April 14, 2014 Also running 10/60 castrol edge as recommended. Or go see BMW and get the stuff they use Quote Share this post Link to post Share on other sites
KwS 2450 Report post Posted April 14, 2014 Nothing definitive anywhere, there is recommendation from 0W* all the way up to 15W*. My vanos is silent when cold, but the higher the oil temp, the noisier it gets. Its not major, but it is noticeable. Probably needs some new seals after the 205,000km its done. Oil was changed 1000KM or so ago. Also, The chain tensioner is spring, not hydraulic, isnt it? Ive used Edge in previous cars, with no ill effects, but i noted an improvement in running/noise when changing all three of my M52 powered BMWs to the Synpower. Never had a proper ///M engine before though. As a general rule of thumb, with all my previous cars, the higher the performance the thinner the oil used. TOO MANY OPTIONS! Quote Share this post Link to post Share on other sites
yng_750 247 Report post Posted April 14, 2014 This^ high performance engines often use thinner oil but the viscosity isnt nearly as important as shear strength, thermal stability amd zinc content just to name a few Quote Share this post Link to post Share on other sites
KwS 2450 Report post Posted April 15, 2014 Im aware of this, it was a generalization from my previous 40 cars. Quote Share this post Link to post Share on other sites
twisted 45 Report post Posted April 15, 2014 Couple of issues: 1. Weird electrical issues when ign set to on. Rev counter goes nuts even though engine not running, headlight adjusters cycling through each setting and injectors pulsing. I'm thinking faulty ign switch, but have no other symptoms. Thoughts? 2. Tried to start car before and it backfired in manifold and blew the cap for the ccv valve off. So need to replace ccv valve now. Could this be caused by issue 1? Im thinking excess fuel caused by injectors pulsing etc causing backfire? Sent from my HTC_PN071 using Tapatalk Quote Share this post Link to post Share on other sites
yng_750 247 Report post Posted April 15, 2014 Fix first issue. It may cure the second. Also.helps to know what sort of car you have Quote Share this post Link to post Share on other sites
twisted 45 Report post Posted April 15, 2014 It's an m52. Sent from my HTC_PN071 using Tapatalk Quote Share this post Link to post Share on other sites
twisted 45 Report post Posted April 15, 2014 In an e39 Sent from my HTC_PN071 using Tapatalk Quote Share this post Link to post Share on other sites
