|ncary 0 Report post Posted June 1, 2010 5-6 weeks minimum. Exams are on in 2 weeks. Then working all holidays ha. Doing a few other things too, like LSD shimming, E36 rack, and new booster and MC. Quote Share this post Link to post Share on other sites
Sammy J 1 Report post Posted June 1, 2010 We will have epic pics and videos of twin tech ones battling it out after the uni holidays.. need to study but to many e30's to play with. Im sure Incary will agree Quote Share this post Link to post Share on other sites
APT 205 Report post Posted June 1, 2010 Did you get that Setup out of that Black e30 on trademe? Quote Share this post Link to post Share on other sites
oscar90 0 Report post Posted June 1, 2010 Sounds epic haha Quote Share this post Link to post Share on other sites
|ncary 0 Report post Posted June 1, 2010 Sure did. Straight swap. Engine and all related bits for my engine and all related bits. I have: Alloy Rad Driveshaft hoops Shortened driveshaft. Gearbox mount Engine mounts Loom, ECU, AFM etc BOV and intercooler and piping etc etc etc The only tradeoff is we have to put the M20 in his car and get it running. And that's the story morning glory. Quote Share this post Link to post Share on other sites
JiB 2 Report post Posted June 1, 2010 (edited) I am definitely not envious of the wiring ahead of you! But it's gonna be reasonably awesome once the coupe's powered by little boosted Japanese horses. What's the weight difference between the stuff going in and the stff going out? Changing your front spring rates/dropping a ARB size? We will have epic pics and videos of twin tech ones battling it out after the uni holidays.. need to study but to many e30's to play with. Gonna keep the cage green to differentiate them? I'm thankful my to-do list on the touring is reasonably small, got exams in a fortnight too Edited June 1, 2010 by JiB Quote Share this post Link to post Share on other sites
|ncary 0 Report post Posted June 1, 2010 Wiring won't be bad, soooo much/many info/wiring diagrams/write ups for the SR it's insane! For the complicated fuse box wiring, we have a fantastic contact who is a SR wiring master. But at this stage it's a fingers crossed kind of thing ahaa. Scales are heading to the workshop this weekend to weigh both engines. I'll have a relatively accurate set of total masses of these 2 engines which should interest a few people here, and I tell you what, after swinging both engines on the engine hoist the M20 is in a different league of momentum.... I'm hoping for a for a 30% reduction (dreamer maybe, we'll see, but the mass centralisation of this motor is much better than a long iron 6, so that counts also). The current place where the engine sits is much, much too far forward for my liking. But it's the only place it can sit due to the shifter set up... it can't move, and the gearbox is ridiculously long. Eg: So where the motor sits on the brilliantly made mounts is where it must go for now, until summer at least when a shifter linkage, brake booster reduction/relocation and custom oil pan can be made. We are hoping to get it back 20-25cm. Will be more depending on legalities of firewall modification. So currently cylinders 1-2-3-4 are where the previous 2-3-4-5 were. But wow that vertical all-alloy block looks sexual, and full of promise. And yes haha, big front sway is already out, less camber coming, and I'll get a second set of springs which are more suited to the track. Probably followed by a rear sway delete after the excessive power oversteer this will achieve hahaha! Quote Share this post Link to post Share on other sites
tibbs.james 1 Report post Posted June 3, 2010 Excellent Henry ! This will be a fantastic combination So how long until you get the boost bug and end up doing injectors, turbo and engine management upgrades ? Quote Share this post Link to post Share on other sites
oscar90 0 Report post Posted June 3, 2010 in to say... 6 Months or less..? place your bets...rad power to match rad suspension Quote Share this post Link to post Share on other sites
|ncary 0 Report post Posted June 6, 2010 Amazing combination for sure.. Cannot wait to hit some downhill corners and long sweepers with an even-better balanced car.. For a few weeks at least it will remain the stock 220hp or whatever it is. T28BB and injectors are on the to-do list. Aiming for hmmmmm maybe 200rwkw. Maybe less. Depending on how well the relatively soft suspension handles the power at runapuna. Some pics! Threads are sh*t without pics. Loom needs tiding, but apart from that the engine looks to be in great condition. It was purchased from Falsgrave engine importers here in chch for 3000. Done only 80,000km apparently!!! Spot the M20's. And so much for 75D solid engine mounts! I've crushed the f**k out of mine ahaa. Quote Share this post Link to post Share on other sites
Sammy J 1 Report post Posted June 6, 2010 Correction, it's only done 60k Quote Share this post Link to post Share on other sites
JiB 2 Report post Posted June 6, 2010 I've got the Ireland Engineering for motor and box (well, I guess Sammy does now) but they're still good. I don't think I drive anywhere near as hard or as much as you do though! Oh man, you're gonna love the aftermarket support available for SR's. P.S. Is one of those M20's mine? Quote Share this post Link to post Share on other sites
antil33t 90 Report post Posted June 6, 2010 Last time I was in Christchurch. I went in Mr Henry's car and I got a VERY sore back... Is my back going to be broken once this engine is fitted? that SR20 looks uber clean Quote Share this post Link to post Share on other sites
e30plz 1 Report post Posted June 6, 2010 Awsum. Quote Share this post Link to post Share on other sites
e30ftw 435 Report post Posted June 6, 2010 Make a copy of the mounts for engine and box and i'll give you a cookie? Quote Share this post Link to post Share on other sites
e30plz 1 Report post Posted June 6, 2010 (edited) ^+1, lots of cookies. Edited June 6, 2010 by skrillz Quote Share this post Link to post Share on other sites
Nobimmer 694 Report post Posted June 6, 2010 Wait. Is there more incest going on? Quote Share this post Link to post Share on other sites
Sammy J 1 Report post Posted June 6, 2010 Gotta love the incest. Quote Share this post Link to post Share on other sites
|ncary 0 Report post Posted June 6, 2010 Ha yes Jono, your new M20 is the bottom left one. Don't take offense to the floor storage system Hmmm the mounts are quite simple, would be very easy to replicate.. Will explore for all interested after this exam study which is owning my life currently. And yes, 60,000km! Should be very trouble free for a long time. Quote Share this post Link to post Share on other sites
AN E30 Fan 1 Report post Posted June 6, 2010 Wait. Is there more incest going on? From what I gather... Sammy and JiB swapped cars, So Graham's Old touring is returning to Auckland after 2 or so months in Christchurch... F*** I love this thread. Your car Henry, is going to be brillant once its finished. I can't wait for vids Quote Share this post Link to post Share on other sites
tibbs.james 1 Report post Posted June 7, 2010 Henry, you may remember i told you all about nistune ? I have got it setup on my 300zx now and I have a little experience with it and calibrating new injectors and such. It will fit your ECU and the circuit board is about $350 if you want to come check it out let me know. With some engine management remapping and a fuel pressure regulator you might be able to hit 200kw without doing turbo or injectors and just a really decent remap and increase of base fuel pressure. you should even be able to get a tune online for a stock sr20 and then it would be very cheap to have tweaked on a Dyno. if you wish for a turbo upgrade I even have a good cond Garret T3 with a .63 exhaust housing which would give you sh*t loads of top end on a SR20 as its a popular upgrade for RB engines. give me rides in your car and you can pretty much have it/borrow for as required Those SR Injectors are 260cc min and I believe they are good for 300hp at the wheels Quote Share this post Link to post Share on other sites
tibbs.james 1 Report post Posted June 7, 2010 forgot to add this, http://nistune.com/ Quote Share this post Link to post Share on other sites
Forrest 35 Report post Posted June 7, 2010 So awesome Henry you bastard. Still one of the top cars on here. Hopefully going to do something similar to my sunroof sometime soon. Quote Share this post Link to post Share on other sites
|ncary 0 Report post Posted June 8, 2010 I've been researching away in the background thanks to your suggestions James. I think it looks like a fantastic plug-in ECU untill a Link G4 can be made the Boss in the medium future. And thanks Nath No other updates. You shouldn't have clicked on my thread. Quote Share this post Link to post Share on other sites
|ncary 0 Report post Posted June 26, 2010 So here's a picture of the car that the SR came from. Features include: Rear hub brakes (perfect for slowing down a 2liter turbo powered car), shortened rear shocks (the rear wheel doesn't even leave the guard at full droop), a '3.5 k' gloss black paint job (with the original red still showing in the door frames, under the bonnet/boot etc etc), super shiftu lightu desu, and rare Advanti 17in rims. It's nice to have my car back in the driveway, we offered it as security while we installed my M20 into his black car, which we dubbed 'the gee-eee-thir-tee'. This d*ck basically left it uncovered the whole time and now my car is full of water on the passenger side. I really have to reseal the sunroof panel, the water comes in through a bolt hole which is slightly too large for the tiny bolt. Work on my car will begin in a couple of weeks. Current project is painting my flatmates awesome Super Carry. Sanding blooooows. And never have I seen so much bog from the factory.. This van has it everywhere under the original paint. It's going to be gun metal gray. Spot the E30. And if you go for a ride in a V10 R8, leave your head pressed against the head rest. Trust me. Quote Share this post Link to post Share on other sites
