Jamez 2147483647 Report post Posted October 9, 2011 (edited) Spent the day knocking down the drug room in the garage to make way for the 540i Edited October 9, 2011 by Jamez Quote Share this post Link to post Share on other sites
tmase 19 Report post Posted October 11, 2011 Got my E39 back after a service and new rear pads and rotors - HVAC final stage resistor unit promptly died - need to source one and replace it - Quote Share this post Link to post Share on other sites
Michael. 2313 Report post Posted October 11, 2011 Fitted new coil packs, rotors, and distributors. Runs like silk now. Quote Share this post Link to post Share on other sites
_Matt_ 42 Report post Posted October 11, 2011 cleaned some more stuff Quote Share this post Link to post Share on other sites
KRZY-E30 0 Report post Posted October 11, 2011 Got my manual conversion installed on my 325i. Drives well! clutch is very strong. Gear box is smooth. Thanks Jono for supplying the kit! p.s the drive shaft center mount didn't fit my F/L e30. also got a few other bits replaced. Quote Share this post Link to post Share on other sites
AN E30 Fan 1 Report post Posted October 14, 2011 Had a new windscreen put into Dudlee after the last one cracked. I had a leak from the windscreen aswell and luckily enough it wasn't the Sunroof drainage holes that have rusted through just the windscreen rubber seal. Novus sealed it all up for free and put the new windscreen. 10/10 Quote Share this post Link to post Share on other sites
DrphTa 5 Report post Posted October 14, 2011 Wash, clay, wash + wax = IMG_4150.CR2 by josh_richardson, on Flickr Get some spacers Quote Share this post Link to post Share on other sites
Gotheschu 1 Report post Posted October 14, 2011 tralaaaalaaaa Thanks iSignIt Quote Share this post Link to post Share on other sites
joshnz 2 Report post Posted October 14, 2011 Get some spacers Actually? .. i would prob need longer bolts too? Quote Share this post Link to post Share on other sites
DrphTa 5 Report post Posted October 14, 2011 Actually? .. i would prob need longer bolts too?Yea either slip on or bolt on. If you buy slip on you will need longer bolts. Im running 18mm slip ons with longer bolts Quote Share this post Link to post Share on other sites
thorburn 123 Report post Posted October 14, 2011 -1 for spacers Jack that looks great Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2153 Report post Posted October 14, 2011 got a few boxes of goodies for two cars that are both immobile right now. BMW life Quote Share this post Link to post Share on other sites
polley 916 Report post Posted October 14, 2011 Weekend will consist of cutting down 24 studs and attempting to install them, gonna be a mission trying to get to some of these. Quote Share this post Link to post Share on other sites
kerry 10 Report post Posted October 14, 2011 ^like button Quote Share this post Link to post Share on other sites
polley 916 Report post Posted October 14, 2011 ^like button Clearances are tight, down pipe has maybe 5mm each side. Quote Share this post Link to post Share on other sites
Lucan 196 Report post Posted October 14, 2011 /\ Damn. Car looks good Jack - Thumbs up. Quote Share this post Link to post Share on other sites
Michael. 2313 Report post Posted October 14, 2011 Polley... very nice work. I am curious as to what metal type you used for the manifold? As in steel type/grade and thickness? I need to look at making up some 4-2-1 headers for my V8 soon so just want to get some ideas of what material others are using for exhaust manifolds. Quote Share this post Link to post Share on other sites
polley 916 Report post Posted October 14, 2011 Polley... very nice work. I am curious as to what metal type you used for the manifold? As in steel type/grade and thickness? I need to look at making up some 4-2-1 headers for my V8 soon so just want to get some ideas of what material others are using for exhaust manifolds. They are steam pipe bends, they would be over kill for a NA manifold (and heavy), unless you plan on making a turbo manifold ?? Quote Share this post Link to post Share on other sites
3 SERIES 93 Report post Posted October 16, 2011 (edited) Productive Sat avo for the boys at the Park Rd E30 Performance Centre Found out why the E30 was running on 5. Huge crack in the Dizzy so replaced that. Replaced Plugs. Replaced the non captive superlow springs in the rear for some lows. Fitted SA spec boot lining and larger toolkit. Replaced faulty coolant sensor. Fixed other little bits n pieces. Finished off with a test drive with the fellas Edited October 16, 2011 by 3 SERIES Quote Share this post Link to post Share on other sites
crazyarab 6 Report post Posted October 20, 2011 First part of shipment arrived today Quote Share this post Link to post Share on other sites
Michael. 2313 Report post Posted October 20, 2011 Drove it it somewhat quickly on a private road. Quote Share this post Link to post Share on other sites
polley 916 Report post Posted October 20, 2011 Cranked it over and gained some oil pressures. Battery is on the charger then I will check I am getting correct signals from the crank VR sensor to the ECU. Quote Share this post Link to post Share on other sites
thorburn 123 Report post Posted October 20, 2011 Exciting times. Are you going to be renting a dyno when it's all configured? Quote Share this post Link to post Share on other sites
kerry 10 Report post Posted October 20, 2011 Exciting times. Are you going to be renting a dyno when it's all configured? im sure wintec could hook em up aye james? Quote Share this post Link to post Share on other sites
thorburn 123 Report post Posted October 20, 2011 That might have been what I was hinting at Quote Share this post Link to post Share on other sites
