No name user 379 Report post Posted September 9, 2013 if the runs were done in 4th which is how its meant to be done then with a 3.46 you would have 289ft/lb mtr and 3.64 you would have 274 ft/lb mtr which is about right going off a to4z comp map and that motor Quote Share this post Link to post Share on other sites
Garett 103 Report post Posted September 9, 2013 if the runs were done in 4th which is how its meant to be done then with a 3.46 you would have 289ft/lb mtr and 3.64 you would have 274 ft/lb mtr which is about right going off a to4z comp map and that motor Enough to pull granny off the potty! haha Quote Share this post Link to post Share on other sites
No name user 379 Report post Posted September 9, 2013 (edited) i was going to say 16yr school boy but granny will do Edited September 9, 2013 by crunchy Quote Share this post Link to post Share on other sites
Garett 103 Report post Posted September 10, 2013 Ok got my car back took it for a bit of a sneaky drive down the road, it stepped out in every gear I only got to forth but holy crap I had a smile from ear to ear, here's a copy of the dyno sheet Im really happy with the work done by Brent @ Dynopower he's done a top notch job on tuning it, if ya reading this cheers mate. Quote Share this post Link to post Share on other sites
No name user 379 Report post Posted September 10, 2013 1030nm is a tad different than 1000ft/lb still light car itll go well time to hit the track and show us what it does Quote Share this post Link to post Share on other sites
polley 916 Report post Posted September 10, 2013 Can anyone explain why some people use road speed as the bottom axis instead of RPM? Seen it a few times and dont really see the point of it. Quote Share this post Link to post Share on other sites
No name user 379 Report post Posted September 10, 2013 that dyno is built by torque performance and all there software does the same thing i hate using them as it makes no sense to read unless you know diff ratio versus speedo and rpm at set point agree and the point would be? there is none but making it hard to under stand what it all means Quote Share this post Link to post Share on other sites
Garett 103 Report post Posted October 28, 2013 Ha getting my head around the new page layout, its quite good. Ok a couple of updates.. Ive just spent countless hours sanding the car getting it ready for paint, don't look to hard at the paint job ok im not a panel beater lol Ive also fitted a oil pressure sensor sender unit to where the oil light light on the dash gets it signal from, as the threads are 12x1.5 for the sensor plug and 1/8npt for the a/m sensor so I drilled and tapped a wheel bolt as you cant find adapters for this sort of thing. Ive made the floor out of 3mm alloy sheet and going to get some skateboard grip tape to complete it Also upgraded the dash from the early grey/black one to an late e36 black one which looks a lot nicer I reckon umm.. I made a catch can out of cardboard then out of alloy from bending it in the vice, just need to get it all welded up now, I made it without doing any research on it haha so I think it may be a lil big, but guess better to big than to small huh And fitted some bonnet catches the flush mounting ones The goal is to have the vehicle ready for powercruize in taupo for the 15th nov Quote Share this post Link to post Share on other sites
westy 614 Report post Posted November 1, 2013 How'd I miss this update? Flash as cuz! Quote Share this post Link to post Share on other sites
Garett 103 Report post Posted November 1, 2013 How'd I miss this update? Flash as cuz! Cheers bud, got a couple more updates... Went everywhere to find good things for my car, found some grip tape from the surf shop 30 bucks for 3m which I thought was pretty good, I got my catch can back half welded so I can finish the internals of it, made up some heat shields for the bonnet that sh*t really cuts ya deep if ya not carful lol, I also installed E46 high stop lights in the front and rear, the front is activated via the missile switch, those switches are awesome I just want to have them for everything... Question does anyone have or know where to get a intercooler water sprayer from?? see I got the wires there that run from the ECU and id really like to put it to use Quote Share this post Link to post Share on other sites
Ace Of Spades 51 Report post Posted November 1, 2013 subaru wrx sti have them, so a subi wreakers?? Epic updates bro Quote Share this post Link to post Share on other sites
yng_750 247 Report post Posted November 2, 2013 vote to take a collection to buy this man a better camera? Quote Share this post Link to post Share on other sites
dubman 39 Report post Posted November 2, 2013 ^ he'll just pawn it to get his fix on Quote Share this post Link to post Share on other sites
Garett 103 Report post Posted November 3, 2013 subaru wrx sti have them, so a subi wreakers?? Epic updates bro Sweet ill try around tomorrow, cheers vote to take a collection to buy this man a better camera? I like this idea... ive never had a good camera ^ he'll just pawn it to get his fix on Well this is true ill stick to what I have... Quote Share this post Link to post Share on other sites
Garett 103 Report post Posted November 3, 2013 So today I remove the rear end (diff arms etc) from a E36 M3 and cleaned it up ready for the nolathane bushes to be installed, also installed the front M3 lower arms and brakes in my car, then finished sanding the last of the panels the bonnet of my car man im over sanding I have no fingernails left. just keep thinking end result its all in the prep work haha dam thoughts! Quote Share this post Link to post Share on other sites
Ahmedsinc 414 Report post Posted November 3, 2013 Isn't it tempting fate to have a perfect paint job on a drift car? 1 Quote Share this post Link to post Share on other sites
m325i 732 Report post Posted November 4, 2013 I remember a NZ Performance Car DIY for intercooler sprayer. Just use a washer bottle and windscreen sprayer set up? Looks pretty sick bro! Quote Share this post Link to post Share on other sites
Garett 103 Report post Posted November 11, 2013 Right so I've got it back from the painters on Friday last week and spent a bit of time outing it back togeather and really enjoying every min of it, I took it for a lil drive tonight lets just say it's a lot of fun, he's some pics of my progress, I've now got m3 gearbox diff axles subframe and brakes on with nolathane bushes the cage has now got padding and the windows are in, what's left is fitting the seats and harnesses the e46 high stop lights and side skirts, I think I'll make powercruise on Friday :/ maybe Quote Share this post Link to post Share on other sites
328bema 18 Report post Posted November 11, 2013 Will this car be road legal or? Quote Share this post Link to post Share on other sites
Garett 103 Report post Posted November 11, 2013 Will this car be road legal or? Yep soon it will be Quote Share this post Link to post Share on other sites
E30-323ti 66 Report post Posted November 11, 2013 Nice Colour Indeed!! 1 Quote Share this post Link to post Share on other sites
adams202 1 Report post Posted November 11, 2013 looking good man, one of my favourite builds on here. Quote Share this post Link to post Share on other sites
Garett 103 Report post Posted November 12, 2013 looking good man, one of my favourite builds on here. Cheers man its been a great ride building it! Quote Share this post Link to post Share on other sites
euroriffic 630 Report post Posted November 12, 2013 man this thing looks amaizing!!!! good work Garett. Quote Share this post Link to post Share on other sites
Garett 103 Report post Posted November 13, 2013 man this thing looks amaizing!!!! good work Garett. Cheers mate, its been a hell of a lot of late nights in the last month Quote Share this post Link to post Share on other sites
