325_driver 422 Report post Posted December 29, 2019 (edited) Hi all, not for the BMW, those valves are pretty clean. But thought i would ask, There's some serious carbon build on valves up on a direct injection engine, and i'm looking to take the manifold off, soak the ports in a solvent (like gum gutter, seafoam etc) for a few hours and then attack with a wire brush. Trouble is, those products don't exist over here in New Zealand. Anyone know any readily available solvents that will dissolve or atleast loosen up carbon. Edited December 29, 2019 by 325_driver Quote Share this post Link to post Share on other sites
Eagle 1777 Report post Posted December 29, 2019 Subaru upper engine cleaner used to be the recommended one but ive never used it myself. Ive also seen a CRC version intake cleaner at Repco. If its real bad and baked on then i would think media blasting would be the only way to do a thorough job. 1 Quote Share this post Link to post Share on other sites
gjm 3300 Report post Posted December 29, 2019 Would brake cleaner work? Quote Share this post Link to post Share on other sites
zero 1162 Report post Posted December 29, 2019 Soak in kerosene Quote Share this post Link to post Share on other sites
Navin 180 Report post Posted December 30, 2019 Used to use the Subaru upper engine cleaner on a lot of my older cars. Worked a treat, wasn't too badly priced from Winger Subaru from memory. 2 Quote Share this post Link to post Share on other sites
Allanw 1081 Report post Posted December 30, 2019 I used petrol ? I tried 2 cans on the CRC cleaner, and the Nulon one, prior to stripping down my Mrs Touran FSI engine - they appeared to do nothing, other than pooling in the intake! I cleaned it all out with petrol, a small wire brush, plastic scraper and a toothbrush. Right as rain after that. I'd run the cans throught a couple of hundred kms prior, then had to do an emergency repair one evening, so decided to strip off the intake at the same time. I already had a spare intake I'd cleaned prior, but the head ports and valves had to be done in place. Turn the motor to close each port, scrub, clean and rinse, then I emptied the ports with a mityvac (Use a non-explosion-causing vacuum source!). I think they sprays work well enough on port injected cars, as the port injection washed the ports and valves with petrol. On direct injected cars, EGR, Oil vapour, vlave stem oil and valve timing all contribute to the build up, and heat REALLY bakes it on. Quote Share this post Link to post Share on other sites
325_driver 422 Report post Posted December 30, 2019 (edited) Thanks all, i wasn't sure if petrol or kerosene would work but will give it a shot, but i'll just leave it for several hours before hitting it with a pick and wire brush Edited December 30, 2019 by 325_driver Quote Share this post Link to post Share on other sites
Jacko 2296 Report post Posted December 30, 2019 Subaru upper engine cleaner, all the dealers will have it, it makes some impressive smoke Quote Share this post Link to post Share on other sites
KwS 2450 Report post Posted December 30, 2019 If its bad enough, a wallnut blast might be the only way Quote Share this post Link to post Share on other sites
325_driver 422 Report post Posted December 31, 2019 @KwS believe me i was debating it just got the manifold and rail off, wahoo, going to be a fun new years haha Quote Share this post Link to post Share on other sites
dirtydoogle 383 Report post Posted December 31, 2019 That's not too bad at all. Walnut blasting is the safest way because you don't risk etching any of the surfaces Otherwise start with the least aggressive approach possible. You could get the majority out with gun cleaning brushes and degreaser Quote Share this post Link to post Share on other sites
325_driver 422 Report post Posted December 31, 2019 yeah, going to soak in kero, then light scraping. got me a set of these also going to rangi me up a scotch brite-round-wire device and put it on the drill Quote Share this post Link to post Share on other sites
dirtydoogle 383 Report post Posted December 31, 2019 Keep in kind with excessive carbon build up you may have poor valve sealing so be prepared to do an oil change after and let it crank a bit before firing. Direct injection is a total pain in the arse. 1 Quote Share this post Link to post Share on other sites
325_driver 422 Report post Posted December 31, 2019 (edited) oh man totally didnt think about it that way, i've already flushed the oil heaps, like 8l of sacrificial new 15w40 through it with flush to get it even resembling oil colour again, and then some nice synthetic in it and looking nice and golden. Oil was looking like black sludge when I picked it up. haha oh well. With that in mind, i'm leaving the ports soaking in kero over night, and going to see if the levels have changed at all, that should give me a good indication of its going past the vales into the oil. i'll also be cranking it a bit without plugs too after all of this, just to be super safe. Edited December 31, 2019 by 325_driver Quote Share this post Link to post Share on other sites
dirtydoogle 383 Report post Posted December 31, 2019 She'll be right mate ? Quote Share this post Link to post Share on other sites
325_driver 422 Report post Posted December 31, 2019 Not a bad result Soaked in kero for a few hours - loosened up big bits with screw driver / pick - brake cleaner and scotch brite to get the final bits off Found a new use for my paint gun spraying in there to blow out the liquid, i look like i've been stuck in a chimney for weeks now 6 Quote Share this post Link to post Share on other sites
NZ BMW 368 Report post Posted January 1, 2020 Good result - what type of vehicle is this anyway? Quote Share this post Link to post Share on other sites
Allanw 1081 Report post Posted January 1, 2020 It appears to be a VW group 2.0 FSI engine - same as in my Mrs Touran, and what was in mine, before it had "the operation". Quote Share this post Link to post Share on other sites
325_driver 422 Report post Posted January 6, 2020 Yup 2.0 FSI. Making a catch can to hopefully reduce the intake garbage. The inside of the plenum is pretty wet with oily residue. Turned a paint can with some JB weld and old BMW quick connectors into a chur bro catch can mod The top one ain't going to be a breather but sealed with a dip stick in it haha Going to have a tyre valve on the bottom as a drain valve. Using an old BMW filter in it to help stop the oil 2 Quote Share this post Link to post Share on other sites
zero 1162 Report post Posted January 6, 2020 (edited) Great kiwi ingenuity there mate. I made a catch can out of a remote oil filter housing Edited January 6, 2020 by zero Quote Share this post Link to post Share on other sites
Allanw 1081 Report post Posted January 8, 2020 On 1/6/2020 at 4:06 PM, 325_driver said: Making a catch can to hopefully reduce the intake garbage. On 1/6/2020 at 10:31 PM, zero said: I made a catch can out of a remote oil filter housing I installed an R32 VR6 ?. More complicated than a catch can... but very effective ? 4 Quote Share this post Link to post Share on other sites
