qube 3571 Report post Posted October 4, 2021 14 hours ago, Jacko said: If only it were manual. swap your manual box and everything else into it? haha NZ NEW - no xenon headlights 1 Quote Share this post Link to post Share on other sites
M3AN 4113 Report post Posted October 6, 2021 A few blemishes but not bad for $7,750 (auto), includes a spare wheel too... https://www.trademe.co.nz/a/motors/cars/bmw/130i/listing/3291571052 Quote Share this post Link to post Share on other sites
KwS 2448 Report post Posted October 6, 2021 24 minutes ago, M3AN said: includes a spare wheel too... Of the wrong size and style...? Quote Share this post Link to post Share on other sites
M3AN 4113 Report post Posted October 6, 2021 7 minutes ago, KwS said: Of the wrong size and style...? Not sure if there's such a thing as "wrong" style but I think they're 261's which were a factory option for the 130's, standard on the 135's. The blue one I shouldn't have purchased came on them. Quote Share this post Link to post Share on other sites
qube 3571 Report post Posted October 6, 2021 ^ I think he means the spare is a style 66 - E39 bore and offset which wont fit the 1 series 1 Quote Share this post Link to post Share on other sites
M3AN 4113 Report post Posted October 6, 2021 Ahh... I see. I wonder if that is better or worse than no spare at all (assuming non-runflats)? Quote Share this post Link to post Share on other sites
Jacko 2241 Report post Posted October 6, 2021 (edited) 1 of 196 2011's, look like Advan RS2s?... and luggage straps! https://www.trademe.co.nz/a/motors/cars/bmw/130i/listing/3292542749 edit - its actually a 2010 - WBAUD52080J012341 Edited October 6, 2021 by Jacko Quote Share this post Link to post Share on other sites
M3AN 4113 Report post Posted October 6, 2021 16k? 🤨 A mint manual isn't worth that. And even with those miles a 10 year old car still needs 10 year old maintenance. Quote Share this post Link to post Share on other sites
Driftit 2204 Report post Posted October 7, 2021 19 hours ago, Jacko said: 1 of 196 2011's, look like Advan RS2s?... and luggage straps! https://www.trademe.co.nz/a/motors/cars/bmw/130i/listing/3292542749 edit - its actually a 2010 - WBAUD52080J012341 Love my luggage straps. And love Advans. But that at that asking price I could have had two of my 130. Quote Share this post Link to post Share on other sites
NZ_InFerno 396 Report post Posted October 10, 2021 They've changed it to $16k now, wild pricing 2 1 Quote Share this post Link to post Share on other sites
duluth 41 Report post Posted October 18, 2021 Took the 130i out over the weekend and found that when i was braking from high speed I was getting a bit of a shudder from the brakes. Any ideas ? Quote Share this post Link to post Share on other sites
qube 3571 Report post Posted October 18, 2021 Warped rotors? Quote Share this post Link to post Share on other sites
Jamez 2147483647 Report post Posted October 18, 2021 3 hours ago, duluth said: Took the 130i out over the weekend and found that when i was braking from high speed I was getting a bit of a shudder from the brakes. Any ideas ? Aprils does that on longer spirited drives but then comes right with normal driving. In my case I figured it was just pad buildup. 1 Quote Share this post Link to post Share on other sites
duluth 41 Report post Posted October 18, 2021 10 minutes ago, Jamez said: Aprils does that on longer spirited drives but then comes right with normal driving. In my case I figured it was just pad buildup. 14 minutes ago, qube said: Warped rotors? Thanks for the comments. I suspect it might be pad build up as it only happens when coming from high speed to a slow speed/stop. My rotors are a bit rusty looking too. Quote Share this post Link to post Share on other sites
Driftit 2204 Report post Posted October 18, 2021 Factory pads create a bit of build up. Always comes right with normal driving for me. Otherwise your lower control arms could be done. 1 Quote Share this post Link to post Share on other sites
qube 3571 Report post Posted October 19, 2021 if the shudder happens around 80kmh then most likely LCA bushes 1 Quote Share this post Link to post Share on other sites
duluth 41 Report post Posted October 19, 2021 35 minutes ago, qube said: if the shudder happens around 80kmh then most likely LCA bushes Any recommendations on best replacements ? Quote Share this post Link to post Share on other sites
M3AN 4113 Report post Posted October 19, 2021 (edited) 21 minutes ago, duluth said: Any recommendations on best replacements ? Get M3 ones, you'll need an alignment afterwards but if your existing ones are shot then any replacement would likely require an alignment. The TRW ones, which are actually BMW ones, will probably cost you less than replacing the bushings in your existing ones. The M3 front lower control arms add camber which is a good thing. https://babybmw.net/forum/viewtopic.php?f=11&t=109115 Edited October 19, 2021 by M3AN 2 Quote Share this post Link to post Share on other sites
Jacko 2241 Report post Posted October 20, 2021 On 10/19/2021 at 2:09 PM, duluth said: Any recommendations on best replacements ? Amazon TRW p/n for M3s LCAs, can often find them for dirt cheap. 1 Quote Share this post Link to post Share on other sites
Brianr70 90 Report post Posted October 26, 2021 Did the airbag recall thing today..at Continental Cars in Wellywood, only took 20mins 1 Quote Share this post Link to post Share on other sites
M3AN 4113 Report post Posted October 26, 2021 22 minutes ago, Brianr70 said: Did the airbag recall thing today..at Continental Cars in Wellywood, only took 20mins Lucky for some, Auckland City BMW continue to ignore my car. Great brand ambassadors they've turned out to be, Munich would be delighted I'm sure! Quote Share this post Link to post Share on other sites
duluth 41 Report post Posted October 26, 2021 Would style 385 rims from an f20 fit on the 130i? Quote Share this post Link to post Share on other sites
E30 325i Rag-Top 3027 Report post Posted October 26, 2021 Probably yes, I am running F20 rims on the wife’s E87 and they are a very nice fit imho. From the reading I did the sizing and offsets between the two 1 Series generations was very similar, although I don’t think I checked style 385 specifically. 1 Quote Share this post Link to post Share on other sites
NZ_InFerno 396 Report post Posted October 26, 2021 1 hour ago, duluth said: Would style 385 rims from an f20 fit on the 130i? The $450 ones on trademe? They look good. Think the offset is in the ballpark, I had a quick look at the specs online yesterday. Quote Share this post Link to post Share on other sites
duluth 41 Report post Posted October 27, 2021 7 hours ago, NZ_InFerno said: The $450 ones on trademe? They look good. Think the offset is in the ballpark, I had a quick look at the specs online yesterday. Saw some ones on Facebook marketplace Quote Share this post Link to post Share on other sites
