Vass 1082 Report post Posted December 9, 2024 Somewhat impulsively jumped into another side project in the form of RHD headers from Malian Exhaust / Kage Trading. tl;dr of it is - THESE ARE NOT A STRAIGHT BOLT ON. They will require (quite extensive) modification to bolt up to the rest of the exhaust, nor will they clear the steering linkage, contrary to their claims. Unless you have the welding equipment & experience, or are prepared to shell out another 1-1.5x the purchase price in paying someone to have these reshaped, my recommendation would be to AVOID. I knew some of the downsides prior to diving into it so had time to emotionally/financially prepare. These were originally purchased by @Eagle who discovered the fitment issues and subsequently abandoned them in favor of an M52 setup. I then took over the baton knowing that at the very least they'll need new flanges welded on in place of their stupid '2024 revision' slotted bolt hole design. Eagle also kindly provided the new flanges. I took off the stock manifolds (bit of a mission having to support the engine & taking out the exhaust side engine arm & mount to gain enough clearance to slide them out) and dropped both sets off at Flame Performance. They used the stock manifolds to make up a jig to accurately position and weld up the new flanges. Bank 1 was fairly straightforward and just needed a bit of extending and a bit of an angle adjustment. Bank 2 however was angled completely incorrectly and needed a lot of work. Also have them weld on the supplied bolts to turn them into studs and make installing the rest of the exhaust a bit less of a hassle. The initial test fit revealed that bank 1 needed to be extended by another 4mm so got dropped off back at the shop to get redone. With that done the angle between the two flanges was still slightly off but close enough for the gaskets to eat up the slack. I gave both headers a quick polish to get rid of the discoloration from welding and wiped them down to avoid having any fingerprints permanently burnt on. Came out looking pretty flash. 1 Quote Share this post Link to post Share on other sites
Vass 1082 Report post Posted December 9, 2024 With the catless headers being significantly more compact, bolting them on was a fair bit easier since they slid through easily enough so that the engine arm didn't need to come out again. I also replaced the stock studs with new ones from the N-series engines that are slightly shorter and have an E-torx head, making installation a lot easier than the double-nut method. I thought about reusing the manifold gaskets with the heat shields, mostly to retain the clips for the O2 sensor wiring but due to the different positioning of the bungs those wouldn't have worked anyway. The new headers are angled straight down, are quite a way away from the valve cover so keeping the heat shields probably wouldn't have had much effect apart from making access to the bolts a lot more tedious. Opted for brand new M52 gaskets that are pretty much identical to the M54 ones, minus the heat shields. The bank 2 O2 sensor (990mm) had enough length in it to fit into the factory clips, bank 1 however (570mm) was now considerably further away and wouldn't reach at all. The options were to order in a new longer bank 2 sensor (which might still have been too short) or make up an extension which I decided to have a go at. Not the first time the spare wiring loom has come in handy. Hacked it up a bit more, as well as a spare old O2 sensor and made up a nice factory-looking extension that blends right in. I only recently discovered these heat shrink + solder butt connectors and now swear by them. So easy to use and seem to create a nice, solid connection. 10/10 recommend. The additional new connection didn't fit under the beauty cover but slotted in between the valve cover and the fire wall and sits there quite securely. The other issue with these headers was that the bank 2 O2 sensor bung is positioned so that the top of the sensor pretty much sits right up against the fire wall heat shield. I bashed them in at that spot as much as I could but it's still mighty close. Not ideal but it is what it is. The exhaust was a bit tight going on but the flanges bolted up fine in the end. The bank 1 flange must still have ended up angled slightly wrong with a slight gap over top of it but luckily the edge of the inner opening looks to be slightly bulged and the gasket looks to be sealing fine. 1 Quote Share this post Link to post Share on other sites
Olaf 3426 Report post Posted December 9, 2024 mate, that's commitment! how do they sound? how does it go now?! 1 Quote Share this post Link to post Share on other sites
Vass 1082 Report post Posted December 9, 2024 The next issue I ran into was the steering linkage. Having initially hooked up my stock one with the CMP coupler, there looked to be plenty of clearance... until I turned the wheel and the bolt holding the coupling to the main shaft started hitting on the headers. Video They claim that the clearance is there but might become a problem if your engine mounts are worn. Mine are barely 12k km's old and the bolt is not even close to clearing so I doubt it'd be any better with brand new engine mounts. Luckily, I anticipated this being a potential issue or that the clearance would be tight at the very least so I pre-emptively ordered a slim linkage from @modz. Great bit of kit, arrived quickly and well packaged with handy instructions, would definitely recommend. Glad I had it on hand by the time the headers came back from the shop so it didn't hold me up. Compared to the stock linkage the ends are clocked slightly differently so all I had to do was reposition the plastic alignment sleeve at the steering rack end. It does end up being slightly shorter than stock so the steering column does extend out of the firewall a bit further. Mine seems to have a lot of play in the column so might look to replace some bushes or the whole column at some stage. Heaps of clearance now so I'm happy as Larry. 1 Quote Share this post Link to post Share on other sites
Vass 1082 Report post Posted December 9, 2024 28 minutes ago, Olaf said: mate, that's commitment! how do they sound? how does it go now?! Cheers! I'm getting to it, just breaking the spiel up into parts as the posts are getting pretty long. 1 Quote Share this post Link to post Share on other sites
Vass 1082 Report post Posted December 9, 2024 Have now put a few hundred km on with the headers installed and they've developed a nice bronze-ish tinge. Looks pretty cool. Performance wise, can't say I notice much of a difference. The engine does rev quite freely but then again I wasn't really complaining beforehand either. My butt dyno isn't awfully well calibrated and I wouldn't have realized it was 30hp below stock power numbers until we put it on the dyno. Gonna try address a few more things and do another power run at some point to compare. Having driven a bit monitoring fuel trims the LTFT's still keep jumping between 5.6 - 6.3 - 7.8 - 8.6 for both banks so doesn't looks like it's made a difference there. Would have been wishful thinking to expect it to have done though. Didn't notice a massive difference in sound either. It did make the tone somewhat deeper but the difference is very marginal and it still sounds quite subdued to my ear. At idle there is no difference at all, at around 4-5k RPM and above you do hear it more but not as much as I would have expected. I was hoping for a more throatier tone but with the rest of the exhaust remaining stock I guess the muffler does what mufflers do. I want to retain the secondary cats so as to not smell like a bag of rotten eggs so might look into getting an aftermarket muffler at some point instead, but that will be sometime in the distant future. Video #1 Video #2 Should have really made the comparison a bit more scientific and taken some 'before' videos and maybe a dB reading but of course only thought of it after the exhaust was already off the car. Here's a brief summary of my experience with the Malian Exhaust RHD headers: The flanges at the engine head end are perfectly straight, fitment is good and they bolt up nice and straight. The flanges on the exhaust side are horrible, it's like they never fitted them onto an actual car before rushing them into production - the angles are wrong, the lengths aren't even and the whole slotted bolt hole design is baffling - even if they did line up and weren't hitting each other when bolted up to the head, I have no idea what guarantees that the tubes remain in proper alignment. They had a previous version of these with stock-style flanges that apparently worked fine, why they moved away from it is beyond me. They've even kept photos of the original ones bolted up on an actual car on their website, yet sell a 'revised' kit that doesn't work. Again to reiterate - these will not bolt up to the stock exhaust without extensive modification. The position of the O2 sensor bungs is way off. Even cut down the Bank 2 O2 sensor is hitting the chassis, even with the heat shields bashed in. Could have clocked them differently since there's heaps of room to facilitate it but guess they never bothered test fitting. They could have omitted the secondary O2 bungs entirely since they're so tight against the chassis they're unusable anyway. I don't believe the stock steering linkage would have cleared even with brand new engine mounts so be prepared to fork out for a slim one. The supplied gaskets are garbage and went straight in the bin. As far as RHD alternatives go, there doesn't appear to be much choice out there. There's Gravity Performance, who don't ship to NZ, and there's Supersprint that are eye-wateringly expensive. There's also Coby ones that look to be mild steel and would still need some welding to mate up to the rest of the M54 exhaust. All in all, with the purchase price, paying for having these re-welded, the slim steering linkage and new gaskets, this exercise cost me around $1.2k, which is still pretty reasonable in my eyes, with @Eagle also taking a bit of a loss on the initial purchase. Despite not quite getting the sound gains I was hoping for, I feel it was still a worthwhile thing to do and a step in the right direction and I'd still do it again if I had to. Just would have been good to know what to expect before jumping into it so hopefully this might help someone else out there. 2 Quote Share this post Link to post Share on other sites
Vass 1082 Report post Posted December 9, 2024 I did also swap out the amber indicators for a fresh set of clears as some eagle-eyed folk might have noticed from those videos. TYC brand corners and fender indicators are good quality and still pretty cheap from Spareto so got sets of both ambers and clears last year. Paired them up with chrome bulbs from LEDPerf since they were the only ones I found (other than Aliexpress) that carried the smaller chrome fender indicator bulbs. Pricing seemed reasonable but did find dealing with them quite annoying so probably wouldn't bother again. Despite a .co.nz website and NZ flag plastered all over the place, they ship their stuff out from France which in my case took over 3 weeks to arrive with little to no tracking updates along the way. The bulbs look to be random brand and probably Chinese-made anyway so would just go direct to Aliexpress next time. Chrome bulbs do make quite a difference though and give a nice clean finish instead of the egg-yolk look you get with amber bulbs. With the fender indicators I somehow ended up with slightly different ones with one having a pearly white edge and the other more of a beige. Might tack on another pair with the next order to have a matching set since they cost the equivalent of a pack of chips. I've also taken up the practice of super-gluing in those metal tabs after having 3 of them shoot out one after another into the fender cavity when reinstalling them after a polish. Don't need the hassle of trying to fish those out again. Did enjoy the amber look but wanted to switch it up a bit after a a year and a bit on that setup and the car does look way more modern with the clears. Need to take her out for a scenic photoshoot up in the hills on a cloudy day sometime. 5 Quote Share this post Link to post Share on other sites
Olaf 3426 Report post Posted December 9, 2024 that's looking very well cared-for. kudos. 1 Quote Share this post Link to post Share on other sites
KwS 2450 Report post Posted December 11, 2024 Love the look of your wagon. So good I also appreciate the effort you went to to both make the headers work, and document the shambles they are out of the box 1 Quote Share this post Link to post Share on other sites
modz 159 Report post Posted December 12, 2024 On 12/9/2024 at 2:50 PM, Vass said: The next issue I ran into was the steering linkage. Having initially hooked up my stock one with the CMP coupler, there looked to be plenty of clearance... until I turned the wheel and the bolt holding the coupling to the main shaft started hitting on the headers. Video They claim that the clearance is there but might become a problem if your engine mounts are worn. Mine are barely 12k km's old and the bolt is not even close to clearing so I doubt it'd be any better with brand new engine mounts. Luckily, I anticipated this being a potential issue or that the clearance would be tight at the very least so I pre-emptively ordered a slim linkage from @modz. Great bit of kit, arrived quickly and well packaged with handy instructions, would definitely recommend. Glad I had it on hand by the time the headers came back from the shop so it didn't hold me up. Compared to the stock linkage the ends are clocked slightly differently so all I had to do was reposition the plastic alignment sleeve at the steering rack end. It does end up being slightly shorter than stock so the steering column does extend out of the firewall a bit further. Mine seems to have a lot of play in the column so might look to replace some bushes or the whole column at some stage. Heaps of clearance now so I'm happy as Larry. Great to see it on the car @Vass- I rarely get to see the finished product in place as they go all over the world. Very tidy build, well done! 1 Quote Share this post Link to post Share on other sites
Vass 1082 Report post Posted December 12, 2024 1 hour ago, modz said: Great to see it on the car @Vass- I rarely get to see the finished product in place as they go all over the world. Very tidy build, well done! Happy to vouch for a good product mate. Thanks for making these! I would've been left in a right pickle without it. Feel free to use the photos for reference or promo if that's something that would be of use to you. Quote Share this post Link to post Share on other sites
Eagle 1787 Report post Posted December 12, 2024 Yep thanks to @Vass for buying these. Lucky (or not) he bought them and had sorted them to save someone the expense and headache of doing it. The LHD versions probably would of been cheaper to modify especially using the slim joint. Malian Exhaust / Kage Trading are easily the worst and most scummy company ive ever dealt with online. Finally got some money back a few days ago from credit card dispute after they stuffed me around in various ways for months. Too bad we didnt have a proper invoice in time to make them pay for what they really owe. 1 1 Quote Share this post Link to post Share on other sites
balancerider 845 Report post Posted December 12, 2024 On 12/9/2024 at 4:29 PM, Vass said: Did enjoy the amber look but wanted to switch it up a bit after a a year and a bit on that setup and the car does look way more modern with the clears. Need to take her out for a scenic photoshoot up in the hills on a cloudy day sometime. Roof rail delete looks so good on the e46 (and the PFL e91 for that matter) 2 1 Quote Share this post Link to post Share on other sites
Vass 1082 Report post Posted December 13, 2024 In a more sombre development, I stumbled upon whatever THIS is. Still struggling to figure out the rich running condition and with the beauty covers off messing around with the headers, I decided to swap out the spark plugs. The current ones were put in when rebuilding the engine and had only done around 12k km's since brand new but that did include the full break in period so, clutching at straws, I figured that might have gunked them up somehow. Easy enough item to tick off so might as well. Whilst at it, I decided to stick my cheapo Aliexpress endoscope dongle down into the cylinders and have a gander. Almost wish I didn't. Whilst 5 of the 6 cylinders/pistons looked pretty much spotless, cylinder 2 looked like it had a crater in the top of the piston. The camera resolution/quality of course didn't help and probably made it look like worse than it was. It was nearly midnight when I discovered it, which set my mind spiralling and I went to bed thinking the engine was toast. The next day I borrowed a better quality endoscope off a mate and had a second look which cleared it up a bit. What I originally thought was a hole was just some nasty carbon buildup but nevertheless the silver, shiny blob still looked like something burnt to the top of the piston. I ended up sticking a piece of wire down the spark plug tube and started picking away at it. Was pretty hard work getting any control and leverage on it but you can see chunks breaking off at around 50 seconds into the video. I taped the endoscope to the piece of wire and went at it some more. You can see a bunch of those chunks littered around, still no idea what it might have been or how whatever it is got there but hopefully not enough of it to do any real damage. I taped a rubber hose to the end of the shop vac, stuck that down the cylinder and tried to suck out the debris, then turned the engine over to get the exhaust valves open on that cylinder and blew it out with compressed air to hopefully clear out any remaining loose stuff. I also had a look at the exhaust valves themselves which didn't reveal any obvious defects. Full video investigation catalogue if anyone cares. The spark plugs themselves actually looked fine, not overly sooty and no obvious bits missing so no smoking gun there. Did a compression test just to be safe which showed around 170 psi but at that point the car had been sitting for close to a month so wouldn't have been an accurate result. Will recheck on a warm engine sometime. I reinstalled the old spark plugs for now. Once the headers got bolted up, I poured a bottle of Techron fuel system cleaner into the tank and topped it off with some BP 98 to hopefully clear out some gunk that might have accumulated and caused this. Need to go on a few more longer runs and give it some spanking to help burn off the remnants. Once that tank is up and the cleaner's worked its way through the system I'll do a proper compression test and install the fresh spark plugs. Bit of a nerve wracking episode that but the car is still seemingly running fine so seem to have gotten away with just a scare. Bit weird still that only one cylinder looked as bad whilst nothing of the like in any of the rest of them. Cars are pain. Quote Share this post Link to post Share on other sites
Vass 1082 Report post Posted December 13, 2024 Also, I keep seeing a slight damp patch at the bottom of the gearbox that feels a bit oily to the touch. It's never properly dripping so not an obvious massive leak but seems to be slowly weeping from somewhere. Almost looks like it's coming out from the bottom two casing bolts. The drain plug threads also seemingly look shiny at all times so could also be that. Then again those are the bottom most parts of the gearbox and it could just be accumulating down there from above. The plugs themselves were brand new so shouldn't really be leaking. Would it be a good idea to wrap some teflon tape around them next time I do a gearbox flush? At this point all the seals apart from the output shaft seal have been replaced. I do have one sitting on the shelf but they're not known to be particularly failure prone and I didn't feel confident enough to mess with pre-loading the output flange so left it alone for the time being. Not a big enough leak to start getting concerned about just yet but would be good to know if it's a common occurrence and whether there's an obvious remedy. Quote Share this post Link to post Share on other sites
Olaf 3426 Report post Posted December 22, 2024 On 9/30/2024 at 1:06 AM, Vass said: On the "performance" side of things, I committed blatant sacrilege by throwing on some intake mods. First was a Bevinsee intake air scoop off Aliexpress. Wouldn't usually go for such things but it looked tidy, all black, no logos and supposedly helps with intake air flow and reduces intake temperatures by a few degrees so was worth a shot for the low price. I was just catching up on your build thread - wow! Wondering - would you recommend the Bevinsee intake? I found them on Aliexpress for under 50 clams, and I figure if it helps with intake temps in the summer at slower speeds, that wouldn't be a bad thing... Re BMW-safe windscreen washer fluid, I just buy the BMW stuff - a couple of dozen bottles at a time. It's cheap enough, does the job. The Liqui Moly stuff is also good though more expensive by a good 30%. HTH 1 Quote Share this post Link to post Share on other sites
Vass 1082 Report post Posted December 22, 2024 14 hours ago, Olaf said: Wondering - would you recommend the Bevinsee intake? I found them on Aliexpress for under 50 clams, and I figure if it helps with intake temps in the summer at slower speeds, that wouldn't be a bad thing... I don't have any metrics to back up its effectiveness but for that kind of money I reckon you might as well, can't see how it would hurt. Install is 2 minutes, no logos on it so blends right in without looking tacky and does its job with no fuss. Marginal gains and all that. 14 hours ago, Olaf said: Re BMW-safe windscreen washer fluid, I just buy the BMW stuff - a couple of dozen bottles at a time. It's cheap enough, does the job. The Liqui Moly stuff is also good though more expensive by a good 30%. Might grab some next time I'm there if it's cheap enough. In this instance it turned out my issue was the new washer reservoir cap not having a vent opening and nothing to do with the fluid or the washer jets themselves, funnily enough. Was a classic case of if it ain't broken... 1 Quote Share this post Link to post Share on other sites
Neil McCauley 477 Report post Posted December 23, 2024 On 12/12/2024 at 9:27 PM, balancerider said: Roof rail delete looks so good on the e46 (and the PFL e91 for that matter) Absolutely transformative. Can't believe how much better it makes the car look. 1 Quote Share this post Link to post Share on other sites
Vass 1082 Report post Posted December 26, 2024 Following @Eagle's lead, I finally got around to hooking up an additional air inlet from the brake duct to the bottom of the air intake box to emulate the full Dinan kit. I wasn't going to bother until Eagle pioneered it, doing some excellent investigative work to discover that the elbows used by Dinan were awfully similar to the ones used on the E39 to connect the airbox to the duct in the chassis leg (part number 13711437886) and matched it up with a suitable hose. I got my hands on a pair of those elbows, a meter of hose, a spare air box, a 57mm hole saw and went to town. The clearance is really tight and with the airbox installed, the elbow ends up kinked. Once you hook up the hose it straightens up but ends up moving the kink further up into the airbox end. Fiddled around with it as much as I could, even ended up getting a spare airbox and drilling a new hole as much towards the edge as possible but didn't manage to get it perfectly straight - the room just isn't there. Not ideal but will still feed air through so very much an improvement. Might benefit from a slightly more flexible hose to help straighten out the kink at the airbox end, will do for now but keen to play around with it a bit if I find something suitable. The Dinan box also comes with a gasket of sorts to seal up the airbox lid better. I filled the groove with some adhesive backed foam to emulate that to finish up. No real way of telling how much of a difference it makes but definitely doesn't hurt. Combined with the ram intake scoop I'm pretty happy with the intake side of things now, near enough maxed out on any gains there were to be had short of any invasive mods. Swapped out for the new spark plugs having gone through the tank that I put some injector cleaner into. Stuck an endoscope down cylinder 2 - still looking slightly gunky but does look to have cleaned out somewhat, no more obvious big chunks in sight so not nearly as bad as first feared. Tried out some NPD100 and clocked up some 50km along back roads with some harder pulls. Can't say it's night and day difference as others have experienced, will need to do some more longer drives to know for sure as there were still remnants of the previous fuel in the tank. There seems to be some sort of weird resonance/vibration when accelerating hard, I'm wondering if it might be due to the headers not being perfectly balanced and the difference in back pressures since they're far from equal length. Or might just be shitty road surface. Neither the intake, the new spark plugs or the different fuel have made much of a difference to the LTFT's though with both banks firmly stuck on -7.8%. Haven't cleared adaptations yet but figured 50km would have been enough for the DME to fully adjust. Don't know what else there is left to try and rectify it, guess it just is what it is. At least it's not running lean. 1 Quote Share this post Link to post Share on other sites
Vass 1082 Report post Posted February 9 (edited) I keep saying I've given up on trying to track down the cause of the rich running, but then something snaps in my head and I jump to the next implausible thing to try out. This time around it was the injectors. After helping a mate do an engine swap, I grabbed the injectors off his old engine to eliminate that possible culprit. Dropped them off at a shop to get professionally ultrasonic cleaned & flow tested - checked out fine to within spec. Swapped them in, cleared adaptations and went for a drive - sure enough the LTFT's were back at -7.0/7.8% after about 20 minutes. Figured I wouldn't bother swapping the old ones back since the result was the same but then when firing up after sitting for 10 minutes or more the engine would run really rough for a few seconds, struggling to hold idle with the red oil pressure light staying on. Decided to hook up the fuel pressure gauge to check for issues. 52 psi at idle 48 psi after shutting the engine off 38 psi after 10 minutes 32 psi after 20 minutes 22 psi after 40 minutes The pressure shouldn't drop below 43.5 psi after 20 minutes to be within spec so this is well off. Not sure how it passed the tests at the shop or whether I managed to damage them somehow when installing but back out they came to revert back to the original ones. Picked up some tricks whilst fiddling with them the first time so the removal-installation process was way quicker the second time around. Ran the same test to make sure all was in order. 52 psi at idle 48 psi after shutting the engine off 45 psi after 10 minutes 44 psi after 20 minutes 44 psi after 30 minutes 44 psi after 40 minutes 44 psi after 60 minutes Mint. Also swapped out my DISA valve for the spare one I also grabbed from the other engine. Mine had been rebuilt with a metal flap and (supposedly) a new diaphragm but figured I'd check swap it out as well and check if it makes any difference. Went for a longer drive, initially things looked promising with LTFT's staying close to 0 but after a while suddenly jumped into the negative again. Stopped by to do some shopping and upon returning they'd somehow gotten reset back to 0%. Took the car out for another run around some back roads and the LTFT's remained promising throughout - 0% on bank 1 and -0.8% on bank 2 by the end of the day. Was beginning to think it had been the DISA valve all along but took it out again for an even longer run yesterday to confirm. The numbers remained low at first but then very gradually began to creep up, settling down in the familiar -7.0/8.6% territory after an hour-something and 70-odd km's. For the 37th time, I give up. I've now tried a bunch of stuff with the same end results: Swapped out MAF sensors - from brand new VDO & to several originals 2 different throttle bodies 3 different ICV's Air filters - stock panel filter, K&N high flow filter DINAN CAI with additional air inlet 2 sets of injectors Different fuel grades - 95, BP98, NPD100 Swapped out DME's with different firmware & software versions, reflashed tunes Stock exhaust manifolds; catless headers Fuel pump & filter are just over a year old. Fuel pressure is sitting at the higher end of the spec at 52 psi at idle. Might try swapping in another fuel filter & pressure regulator at some point, because what the hell... @Eagle also suggested crank & cam sensors might have something to do with timing and fuel injection so could be another thing to try and swap out for some spares I've got laying around at some point. Brand new OE/Genuine sensors the lot though so probably another stab in the dark. Chasing shadows is fun. Edited February 9 by Vass Quote Share this post Link to post Share on other sites
Vass 1082 Report post Posted February 9 All the hooning around was a good excuse to bust out the camera and take some glamour shots though. 7 Quote Share this post Link to post Share on other sites
Vass 1082 Report post Posted February 24 Took her in for a WoF inspection the other week, sailed through without a hiccup. Always enjoy getting compliments from the mechanics, even got thanked for bringing it in. Clearly preferred dealing with what he dubbed a "full restoration" than the clapped out Altezza that came before me. Hit 240,000 km's on the way home. 12,512 km's since the engine rebuild and 10,308 km's post driveline overhaul. Here's to many more. 6 Quote Share this post Link to post Share on other sites
Vass 1082 Report post Posted March 17 (edited) Being the hoarder that I am, I had managed to acquire a couple of spare sets of black cube trims over the years and finally got around to doing something with them. All of the pieces, including the ones installed in the car, had varying degrees of wear and scratches so I've been meaning to do a mini-restoration for a while. Could always just redo it in semi-gloss black but fancied a bit of a colour change and went for a silver tone to sort of emulate the clubsport silver trims. Went to Spraystore, showed them what I was after and instead of custom-mixing something they recommended the off-the-shelf silver wheel paint, which was pretty close to the tone I wanted. Gave the pieced a light sand with 600/2000 grit, masked off the inner edges on a few pieces, wiped down with alcohol and gave them 3-4 light coats (10 minutes between coats), followed by 2 coats of matte clear for a bit of protection. The coats were light enough to retain the cube texture and not look too dull. Might have turned out a tad brighter than I would have liked but on the whole I do quite like it. Will see how I feel about it in a few months' time but so far I'm pleased with the outcome. The wife said she liked it better all black. I guess haters gonna hate. Edited March 17 by Vass 11 Quote Share this post Link to post Share on other sites
Herbmiester 947 Report post Posted March 17 That looks fantastic. 🤩 1 1 Quote Share this post Link to post Share on other sites
Olaf 3426 Report post Posted March 17 That looks superb. Very individual. I’m finding myself in the very unusual position of being envious of your stick 😎 4 Quote Share this post Link to post Share on other sites
