BreakMyWindow
2006 130i
Bought this last Friday for a good price. Being a track addict these days I was keen to get in to something RWD.
The Good…
-All paint except rear bumper and hatch lid is original
-New RE003’s 225/45/17 on all corners. I think the fronts should be 205/50/17 with these wheels?
-BMWP 6 pot Front Callipers
-Last owner had it 9 years. Presumably has had annual oil changes every 10-12k
-Valve cover gasket recently done, waterpump and tstat look new.
-Clutch feels bitey
Not so good…
-Oil pan gasket. No surprises.
-Lifter tick seems persistent, even after bleeding procedure and open road driving
-Usual old car wear and tear, the most annoying being the loose rearview mirror (previous installation error and loose retaining prong holding it to windshield)
-Shocks feel tired
-Needs new brakes all round
No dme codes but I reset the adaptations and chucked some 98 in. Goes better now.
Plan for now is to tidy it up, add some track focused mods and see how I go!
IMG_4100.jpegIMG_4102.jpegIMG_4103.jpegIMG_4104.jpegIMG_4105.jpegIMG_4106.jpegIMG_4108.jpegIMG_4107.jpegIMG_4109.jpegIMG_4113.jpeg
  • Like 5
There’s a black bonnet at pick a part Avondale. I was away, but thought about going for a look.
This the one from turners end of life? Or Mannheim?
Odd how its only got the front, Im pretty sure the dealer package was front and rear? Probably not a bad thing as the BMWP rear disks are not easy to find as are specific to 130 with BMWP. Curious if you have +SPBR coded to the VO, will give you an idea if they were installed by dealer or someone found them at a wrecker in Japan.
Good thing is NZ wreckers are stacked with lesser engined E87s, so trim bits etc are easy and cheap. I have 2 motorsports seats here in same spec (both tidy) if you are interested.
Maybe Turners, I bought it off TM from an ex Turners trader.
Yeah saw it on turners not long ago, was tempted to use it for parts for the mrs 130i haha.
Bit of progress, dash vents painted:
Sump gasket and engine mount inserts :
Not great, not terrible underneath the valve cover. 2 soft lifters on the exhaust side, have ordered 12 lifters to replace. Intake side seems ok which is good, no need to buy more tools to remove those c&nty valvetronic springs..
  • Like 5
If you do end up needing it I have the valvetronic spring tool and I'm happy to lend it out!
  • Thanks 1
The major engine work is now done. 4 lifters were squishy so replaced all 12. IMG_4256.jpeg
This was a thunder c&nt to remove (blind plug for locking the flywheel at tdc. The end you pull on snapped off so I spent about 4 hours stabbing and hitting it with a punch and bfh until it slid most of the way in to the flywheel. Then use the locking mandrel with a prybar to lever it all the way through. It got stuck to the flywheel so was able to remove it via the starter motor hole.
The exhaust cam bearing and ledge journals had seen better days. Got the cam polished and lightly sanded the scoring on the caps.
The state they were in:
After a polish and sanding followed by a quick clean up:
Engine timed up and now waiting for a few little gaskets and bits to arrive for the intake manifold. The large Disa is cooked so taking a gamble with a new one from aliexpress.
  • Like 4
  • Sad 1
Metal seals on the ledges?
Chipping away at re-assembly while waiting for parts. An old coil must’ve been arc’ing on cyl 6 as the Mg has blown out turned in to dust. Had to clean alot of crap out of the spark plug well. Cleaned up the corrosion out of all 6 holes then brushed 2 coats of epoxy enamel to give it a seal. Giving some high heat jb-weld a jam on the blown out damage..
IMG_4262.jpegIMG_4263.jpegIMG_4276.jpegIMG_4275.jpegIMG_4267.jpegIMG_4278.jpegIMG_4277.jpeg
Vanos oil strainers had no sludge but a couple of small bits of swarf on them.
Gave everything in the engine bay a good clean to help with future traces of oil and coolant leaks. 😄
  • Like 4
No bueno. Still makes a racket so guess i’m up for a replacement long block at some stage. With the new large disa it goes really well, will see how many trackdays it lasts. Pulled the oil filter out after 100kms of driving on fresh oil and there are no shavings or metal bits. I even tried proma Mbl8 snake oil.
  • Like 3
It'd be worth checking your exhaust manifold gaskets, I had a very similar sound on my 130i and ended up being the culprit. 🤞🏻
Had a decent go at cutting and polishing. Lots of trial and error along the way but getting the hang of it…
Test area to see how hardy the paint is.
On to cutting the fr guard.
Then the sides and the roof, which I never thought would come up well, lots of deep scratches. Gave it a wet sand first.
After cutting the sides and roof I expected this sh*t to appear under bright lighting..
Up until now i’d been using a rotary polisher so i switched to a DA and got rid of most of it.
Happy how it turned out :)
Got the hatch and bumpers to do. Won’t bother with the bonnet until i can find a straight one with saveable black sapphire metallic paint.
  • Like 9
Nice job, looks great! Make sure you protect it well. Washing the car has been a breeze ever since I did mine.
Replacement bonnet got given the same treatment as the rest of car.
Before
After
  • Like 8
Marty boy ain't fluffing around! good sh*t man!! Love seeing stuff like this! I need to sort my e91 touring and sell it lol it also has the dreaded ticking but it has been sitting for a year now!
No more ticky diesel like n52!
After hunting around for a good exhaust cam and bearing ledge and no luck I pulled a good one out from a pickapart car.
I should’ve done this the first time round i opened it up, the old cam had alot of play resting in the ledges. Happy days!
Cleaned up the replacement :
Doesn't look out of place…
Result!
  • Like 9
  • Thanks 1
Scrubs up well. New rear brakes and handbrake adjusted. Will order a new pair of discs and my go-to track pads for the front. Gearbox oil and some RBF and she’s ready for Hampton downs end of next month.
  • Like 5
Epic work, looks fantastic!
Have racked up about 1500kms since the camshaft surgery and all is well. Great car to drive, rewards smoothness especially with the clutch. Penrite synthetic in the gbox has significantly reduced the notchy shifting. Wof and rbf next week then Hampton Downs on one of 2 dates end of month that isn’t expecting rain.
  • Like 3
Been busy with the interior, full lci interior swap over a wip. Dashboard swap next…
Between 06/06 and 01/08 cars exchanging fr seats are all happy bar the upper seat width adjusters. Looks easy to fix later on.
Was this the car from Turners Hamilton ?
