hotwire 352 Report post Posted July 27, 2008 In the 320i Allow an hours work max - whatever their rate is. Quote Share this post Link to post Share on other sites
bimmer boy 21 Report post Posted August 23, 2008 Are the electric window regulators on E36 sedans interchangeable with the regulators on a E36 coupe? Cheers Quote Share this post Link to post Share on other sites
pureboiracer 0 Report post Posted September 28, 2008 probably not as the door will be longer and thus possibly changind the width of the regulator Quote Share this post Link to post Share on other sites
deane30 30 Report post Posted October 19, 2008 When you drain coolant from an e30 320i facelift do you need to use the block drain plug or can you just use the drainplug/hose on the radiator? I'm wanting to flush the radiator Cheers Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted October 20, 2008 Are the electric window regulators on E36 sedans interchangeable with the regulators on a E36 coupe? Cheers NO....completely different regulators & motors Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted October 20, 2008 When you drain coolant from an e30 320i facelift do you need to use the block drain plug or can you just use the drainplug/hose on the radiator? I'm wanting to flush the radiator Cheers Would pay to drain and flush out both. Sedement builds up in the block Quote Share this post Link to post Share on other sites
deane30 30 Report post Posted October 21, 2008 Would pay to drain and flush out both. Sedement builds up in the block Thanks very much Glenn. Can anyone tell me if this is a good (and comprehensive guide) or should it be done differently? http://web.archive.org/web/20001202052900/...;view_records=1 Cheers Quote Share this post Link to post Share on other sites
oscar90 0 Report post Posted October 21, 2008 just double checking hazard button wont click in and stay in, so you have to sit and hold the button for your hazards to constanly go, definetly gonna fail WoF/re-registering test yes? cheers Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted October 21, 2008 just double checking hazard button wont click in and stay in, so you have to sit and hold the button for your hazards to constanly go, definetly gonna fail WoF/re-registering test yes? cheers Hazard lights are not a WOF requirement. Indicators are though Quote Share this post Link to post Share on other sites
Mark 178 Report post Posted October 21, 2008 just double checking hazard button wont click in and stay in, so you have to sit and hold the button for your hazards to constanly go, definetly gonna fail WoF/re-registering test yes? cheers A new switch shouldn't be too expensive. You never know when you might need to double park! Quote Share this post Link to post Share on other sites
oscar90 0 Report post Posted October 21, 2008 A new switch shouldn't be too expensive. You never know when you might need to double park! this is true haha not a no1 priority atm Quote Share this post Link to post Share on other sites
320guy 0 Report post Posted October 22, 2008 In a word. No. It wont bolt up. Getrag 260 can be made to fit. Or else you will need to find a ZF 5 speed from e36. How much did you score your M50 for and what are you planning to do before you turb it? Actually a 240 will fit the m50, and if the m50 is in a E30 will fit even better then the 260. (as the shifter lines up correctly) Quote Share this post Link to post Share on other sites
greenday-rulz21 6 Report post Posted December 20, 2008 Just a quick question, what the name of the double sided tape some of you use to stick your germanplates onto your car. And where you can get it. Had a quick look down the road but they didn't seem to have any suitable tape. Cheers, Nick Quote Share this post Link to post Share on other sites
Forrest 35 Report post Posted December 20, 2008 Just a quick question, what the name of the double sided tape some of you use to stick your germanplates onto your car. And where you can get it. Had a quick look down the road but they didn't seem to have any suitable tape. Cheers, Nick Repco or Supercheap should have some man, just ask for double sided foam tape Quote Share this post Link to post Share on other sites
Cale 36 Report post Posted December 20, 2008 Hardware stores- Bunnings, Hammer Hardware, Placemakers etc? Just make sure you buy (as above) the foam type Quote Share this post Link to post Share on other sites
greenday-rulz21 6 Report post Posted December 20, 2008 Yea, they didn't have the foam tape. The noob I talked to didn't even know what I meant when I asked if they had the foam type double sided tape. He asked for a brand or name so I thought Id ask here. I'll just go into mitre 10 mega tomorrow and try find some. Cheers for the quick responses. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted December 20, 2008 How much do you need ?? I can give you some tomorrow if you want Quote Share this post Link to post Share on other sites
greenday-rulz21 6 Report post Posted December 20, 2008 How much do you need ?? I can give you some tomorrow if you wantIts for putting my German plates on, so just enough to stick them on well enough. I would definitely take you up on that offer but I don't know if I will be able to make it out to Botany before Christmas. Appreciate it though Glenn. Quote Share this post Link to post Share on other sites
martyyn 2 Report post Posted December 20, 2008 Any DIY store will have it Nick. Made by 3m I think. Quote Share this post Link to post Share on other sites
bravo 35 Report post Posted December 20, 2008 There are a couple of brands, but 3M do make some. Also known as double sided trim tape. Quote Share this post Link to post Share on other sites
tire 10 Report post Posted December 21, 2008 That double sided tape can be got from supercheap, different ones from $5 - $15, just got some now. Quote Share this post Link to post Share on other sites
elmarco 56 Report post Posted December 21, 2008 Just a quick question, what the name of the double sided tape some of you use to stick your germanplates onto your car. And where you can get it. Had a quick look down the road but they didn't seem to have any suitable tape. Cheers, Nick 3M VHB tape - sticks like sh*t to a blanket. Hardware stores should sell it in small sections (horrifically expensive to buy a complete roll). Quote Share this post Link to post Share on other sites
Apex 693 Report post Posted December 21, 2008 What size clip holds the gear selector linkage into the gearbox? E30, 320i, 240 Gearbox. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted December 21, 2008 What size clip holds the gear selector linkage into the gearbox? E30, 320i, 240 Gearbox. The pushrod or the support linkage ?? Quote Share this post Link to post Share on other sites
Apex 693 Report post Posted December 21, 2008 The Piece that slips into the gearbox on the end of the selector shaft thing.. Sorry have no idea as to what the part is called. Thanks Glenn. Quote Share this post Link to post Share on other sites
