euroriffic 630 Report post Posted November 9, 2013 if they're directionals get the rears swapped from side to side. That's what I did on the e30 Quote Share this post Link to post Share on other sites
m325i 732 Report post Posted November 9, 2013 They say 'outside' on them so I assume I can't just swap the sides over. The wear is very minimal now, but I thought it would buy me some time before replacing all 4. Thnx Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2153 Report post Posted November 9, 2013 not really all BMWs check the inside rear tyres, especially if lowered. I pulled a set off my E34 6 months ago, looked easily WOFable on the outside 3mm or more of tread, but inside just hitting the canvas, good job i took the wheels off for a different job and spotted it Quote Share this post Link to post Share on other sites
tcbaurpower 5 Report post Posted November 16, 2013 Hi, my e32 has a coolant leak and I believe it is the heater radiator. The reason being is that when it is first turned on you can smell coolant. Would I be correct in assuming this is the culprit and can I close off the coolant flow to the heater until it can be replaced? My next step would be taking it to a radiator specialist to get pressure tested in case it is not the heater. Anyone had a similar issue before and have some advice? Quote Share this post Link to post Share on other sites
Ahmedsinc 414 Report post Posted November 19, 2013 Is the distance between the E36 front strut towers the same as the E46? Quote Share this post Link to post Share on other sites
cliffdunedin 8 Report post Posted November 20, 2013 Looking at changing trans fluid and filter this weekend, am I right to assume that i can reset the trans adaptation by unplugging the battery for a time or do I need to book in to get the dealer to do it? Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted November 20, 2013 Looking at changing trans fluid and filter this weekend, am I right to assume that i can reset the trans adaptation by unplugging the battery for a time or do I need to book in to get the dealer to do it? No.. that won't work. It needs to have adaptions cleared in the DME & EGS with a scanner Quote Share this post Link to post Share on other sites
cliffdunedin 8 Report post Posted November 20, 2013 Thanks Glenn. Quote Share this post Link to post Share on other sites
cliffdunedin 8 Report post Posted November 20, 2013 (edited) Hey guys searched high and low but cant get a definitive answer about what type of trans oil my zf box uses. Can anyone help me out? Cheers Edit - Valvoline Maxlife or Nulon Full Synthetic are LT 71141 compatible. Edited December 7, 2013 by cliffdunedin Quote Share this post Link to post Share on other sites
UBH8N 0 Report post Posted November 27, 2013 Hey, just brought a parts e30 and want to do a check on the archive vin decoder but some part of its life it has been re-vined, where do i find the factory stamped number in a pfl 30? Quote Share this post Link to post Share on other sites
lord_jagganath 421 Report post Posted December 3, 2013 (edited) ... I have just had an accident with the e34 touring, no panel damage, just rims and tyre damage, but i need to have the shafts and brakes etc looked at. where can I have the car looked at and diagnosed/repaired? do I need to get it reviewed by my insurance provider? Would appreciate a quick reponse please guys... the car is out in Avondale, any suitable repairers here? EDIT:- insurance is going to review it. :sigh: Edited December 3, 2013 by The Juggernaut Quote Share this post Link to post Share on other sites
Kepes 231 Report post Posted December 14, 2013 (edited) Having a (very) hard time getting the fill plug out of my manual transmission. I have a 17mm allen key. A penetrating oil such as PB Blaster looks like my best bet. Are there any alternatives to this? or any tricks to getting this bolt out? There isn't a lot of room down there so it's quite hard! Some people suggest jacking the wrench/allen key but i'm not too keen on that. Any ideas?CheersEdit: 1987 E30 325i Edited December 14, 2013 by Kepes Quote Share this post Link to post Share on other sites
euroriffic 630 Report post Posted December 14, 2013 To to the gym and try again in the morning Orrrrrr put some shock into it hitting the wrench Quote Share this post Link to post Share on other sites
_Matt_ 42 Report post Posted December 14, 2013 Having a (very) hard time getting the fill plug out of my manual transmission. I have a 17mm allen key. A penetrating oil such as PB Blaster looks like my best bet. Are there any alternatives to this? or any tricks to getting this bolt out? There isn't a lot of room down there so it's quite hard! Some people suggest jacking the wrench/allen key but i'm not too keen on that. Any ideas? Cheers Edit: 1987 E30 325i that's a rather large allen key you have there…i'd suggest putting a pipe over it to lengthen it and try again. Quote Share this post Link to post Share on other sites
yng_750 247 Report post Posted December 14, 2013 or get a hex key socket and use a powerbar. Quote Share this post Link to post Share on other sites
EuroSurgeon 2 Report post Posted December 14, 2013 You will need a long bar, they lock solid, Quote Share this post Link to post Share on other sites
_Matt_ 42 Report post Posted December 14, 2013 when I changed my fluid I used a hex socket, put a wrench over it and whacked it with a hammer. Quote Share this post Link to post Share on other sites
euroriffic 630 Report post Posted December 15, 2013 Same here Quote Share this post Link to post Share on other sites
Kepes 231 Report post Posted December 15, 2013 Wouldn't budge!! Either I get myself a gym mebership or do you think any shops would crack it loose for me using som fancy tools? Quote Share this post Link to post Share on other sites
Etwenty1 45 Report post Posted December 15, 2013 I'd slide a 1m long piece of steel pipe over the allen key and try again. Quote Share this post Link to post Share on other sites
e30ftw 435 Report post Posted December 15, 2013 Even with a Hammer it would budge? WD40 it, Andy swears by it Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2153 Report post Posted December 15, 2013 WebRep currentVote noRating noWeight yeah its good stuff. spray it on and leave it to penetrate for a bit. every bit helps when you have a bitch nut. I have one of these in 17mm and 10mm, for the two types of transmission plugs i have come across on BMWs so far. put my power bar on it sometimes with an extension too, and it will pop out. if you are going to buy a socket like that, make sure you get a one piece socket 1/2" drive, not the cheaper two piece type Quote Share this post Link to post Share on other sites
_Matt_ 42 Report post Posted December 15, 2013 I have the same as that ^ but that + a rachet didn't fit between the gear box and the cars body, which is why i put a spanner around it. Quote Share this post Link to post Share on other sites
Kepes 231 Report post Posted December 15, 2013 Ahh that may be a better idea than the allen key. Might even cut a little piece off the allen key and put it in a spanner. Its just beig under the car when its on stands is what bugs me! Quote Share this post Link to post Share on other sites
Rrascal 4 Report post Posted December 15, 2013 Where do I find the oil pressure switch on an M30 engine..? Quote Share this post Link to post Share on other sites
