gjm 3300 Report post Posted January 3, 2017 I'm not sure if he is still on holidays, but he'll certainly be back next week. Quote Share this post Link to post Share on other sites
Scrambler 7 Report post Posted February 22, 2017 Does anyone know just really quickly what the inside diameter of the clutch master supply line is for the e30? Is it 3/8 or something? Also does anyone know the inside diameter of the braided vacuum piping for the brake booster hose? Quote Share this post Link to post Share on other sites
LemonHunter 583 Report post Posted February 24, 2017 1998 E36 318iS question what is this thing, should it be making an audible buzzing sound (that can be felt as a vibration when it's touched) when key is in position 2 and car is not started? once started too many other sounds and vibrations to determine if it's still doing it. unrelated perhaps but when I switch the engine off there is a weird hissing sound followed by a spitting sound... (see attached video) 50966520174__C3954004-E02C-447D-A14E-B4BE12BD3EED.MOV Quote Share this post Link to post Share on other sites
M3AN 4184 Report post Posted February 26, 2017 Flux capacitor? Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted February 27, 2017 On 25/02/2017 at 10:49 AM, EURO V8 said: 1998 E36 318iS question what is this thing, should it be making an audible buzzing sound (that can be felt as a vibration when it's touched) when key is in position 2 and car is not started? once started too many other sounds and vibrations to determine if it's still doing it. unrelated perhaps but when I switch the engine off there is a weird hissing sound followed by a spitting sound... (see attached video) 50966520174__C3954004-E02C-447D-A14E-B4BE12BD3EED.MOV that's the idle control valve (ICV) , its suppose to hum 1 Quote Share this post Link to post Share on other sites
Young Thrash Driver 1021 Report post Posted March 30, 2017 Any competent mechanics in Hamilton (besides the dealer and Kerry at Mosen) anyone can recommend to check a car over? Cheers. Quote Share this post Link to post Share on other sites
Kepes 231 Report post Posted April 5, 2017 Hey guys, how much does a clutch kit weigh? Pressure plate and clutch disc... I'm visiting Australia and need a clutch from overseas. If it doesn't weigh too much I can have it sent to Australia and put it in my suitcase which would save me paying GST. Thanks Quote Share this post Link to post Share on other sites
Gabe79 410 Report post Posted April 5, 2017 35 minutes ago, Kepes said: Hey guys, how much does a clutch kit weigh? Pressure plate and clutch disc... I'm visiting Australia and need a clutch from overseas. If it doesn't weigh too much I can have it sent to Australia and put it in my suitcase which would save me paying GST. Thanks If you know exactly what parts you want, realoem has weights for part numbers. 1 Quote Share this post Link to post Share on other sites
Kepes 231 Report post Posted April 5, 2017 28 minutes ago, Gabe79 said: If you know exactly what parts you want, realoem has weights for part numbers. I didn't know they had this feature! Awesome, thanks mate. Look like the OEM clutch come close to 7kg. This an aftermarket 6puk so I imagine it'll weigh a little less. Perfect, Thanks again. Quote Share this post Link to post Share on other sites
gjm 3300 Report post Posted April 10, 2017 E36 drivers door... I've had some problems with the lock for a week or two (the key might unlock the door, but often wouldn't; no remote locking), but unlocking from the passenger side, leaning across and unlocking the drivers door hasn't been enough of a chore to make it an urgent fix. Until yesterday when leaning across and lifting the knob didn't work. It doesn't unlock. Can't open the door from the outside, or the inside. Grip the lock knob and lift, and you can feel it lift against something; release it and feel it pulled down. Almost like there's a small elastic band on the bottom of it. So the door is locked, and cannot be opened. I have managed to get the door card off without destroying it (and the foam-type liner). The window works. However, it's impossible to see anything that might be useful - it's all hidden inside the door, behind sheet metal. I think the actuator has decided to call it a day, but I've not had quite this sort of experience. There's always been a mechanical way to unlock the door, but not this time. Lifting the locking pin knob achieves nothing - there is absolutely no sense of anything happening. So... Tips, tricks and ways to sort this? Right now I'll settle for just being able to get the door open and closed! Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted April 10, 2017 50 minutes ago, gjm said: E36 drivers door... I've had some problems with the lock for a week or two (the key might unlock the door, but often wouldn't; no remote locking), but unlocking from the passenger side, leaning across and unlocking the drivers door hasn't been enough of a chore to make it an urgent fix. Until yesterday when leaning across and lifting the knob didn't work. It doesn't unlock. Can't open the door from the outside, or the inside. Grip the lock knob and lift, and you can feel it lift against something; release it and feel it pulled down. Almost like there's a small elastic band on the bottom of it. So the door is locked, and cannot be opened. I have managed to get the door card off without destroying it (and the foam-type liner). The window works. However, it's impossible to see anything that might be useful - it's all hidden inside the door, behind sheet metal. I think the actuator has decided to call it a day, but I've not had quite this sort of experience. There's always been a mechanical way to unlock the door, but not this time. Lifting the locking pin knob achieves nothing - there is absolutely no sense of anything happening. So... Tips, tricks and ways to sort this? Right now I'll settle for just being able to get the door open and closed! sounds like the dead lock is on and the locking actuator has failed , or the latch itself , try and clip the locking actutator off the latch and operate levers or the key lever to see if it unlocks 1 Quote Share this post Link to post Share on other sites
gjm 3300 Report post Posted April 10, 2017 2 minutes ago, BM WORLD said: sounds like the dead lock is on and the locking actuator has failed , or the latch itself , try and clip the locking actutator off the latch and operate levers or the key lever to see if it unlocks I'll give it a go. Thanks. Quote Share this post Link to post Share on other sites
gjm 3300 Report post Posted April 13, 2017 On 10/04/2017 at 8:44 PM, BM WORLD said: sounds like the dead lock is on and the locking actuator has failed , or the latch itself , try and clip the locking actutator off the latch and operate levers or the key lever to see if it unlocks On 10/04/2017 at 8:46 PM, gjm said: I'll give it a go. Thanks. Popped in to see Brent earlier in the week and got some pointers on what to do. Release the window guide, let it drop down, manipulate the glass out of the way, and I should have easier access to the actuator. It's a fiddle and a faff, but at least theoretically possible to manipulate things to release the deadlock. And it's not raining which means I actually have an opportunity to give this a go. Wish me luck! And - Thanks Brent. Regardless of my level of success, your advice is very gratefully received. 1 Quote Share this post Link to post Share on other sites
M3AN 4184 Report post Posted April 14, 2017 The indicator in my 328 (e36) has started to go on the blink (lol). When indicating right the indicator works fine sometimes, not at all other times and somewhere in between occasionally. When it's not working it doesn't make any clicking noise. Occasionally it will start fine then randomly start and stop. Indicating left seems fine for the time being. Aside from simply driving around town anticlockwise, where's the best place to start looking? Is this a common problem? Stalk, relay, elsewhere? Cheers. Quote Share this post Link to post Share on other sites
gjm 3300 Report post Posted May 10, 2017 1991 E30 M20B20 vs M20B25 - is there any difference in the parts used for the timing belt and water pump? (And associated bits and pieces?) Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted May 10, 2017 21 minutes ago, gjm said: 1991 E30 M20B20 vs M20B25 - is there any difference in the parts used for the timing belt and water pump? (And associated bits and pieces?) no 1 Quote Share this post Link to post Share on other sites
LemonHunter 583 Report post Posted May 10, 2017 4 minutes ago, BM WORLD said: no What he said, also, if in doubt use real OEM for all sorts of useful comparisons, or in my case, working out what my frankenbeamers need (Late model E30 320i with an Early E21 M20B23 was always a bastard) http://www.realoem.com/bmw/enUS/showparts?id=1548-ZA-03-1991-E30-BMW-325i&diagId=11_4365 http://www.realoem.com/bmw/enUS/showparts?id=1448-ZA-05-1991-E30-BMW-320i&diagId=11_4365 1 Quote Share this post Link to post Share on other sites
gjm 3300 Report post Posted May 10, 2017 Sweet. Thanks. Quote Share this post Link to post Share on other sites
nick496 273 Report post Posted May 10, 2017 On 4/14/2017 at 0:54 PM, M3AN said: The indicator in my 328 (e36) has started to go on the blink (lol). When indicating right the indicator works fine sometimes, not at all other times and somewhere in between occasionally. When it's not working it doesn't make any clicking noise. Occasionally it will start fine then randomly start and stop. Indicating left seems fine for the time being. Aside from simply driving around town anticlockwise, where's the best place to start looking? Is this a common problem? Stalk, relay, elsewhere? Cheers. I had something similar in the e30, though it was both indicators that stopped working. It was a faulty relay. Looks like in e36s it's in the fuse box. A few things to test would be when it happens, so use your hazards and see what happens. And also remove the relay, and then pop it back in while the car is running. If it works perfectly after doing so, it's most likely your relay. 1 Quote Share this post Link to post Share on other sites
pmet007 0 Report post Posted May 14, 2017 HI - this is my first post Our 2002 318TI (120kms and in good shape) has a broken exhaust valve spring and the local garage is quoting between $2000 and $3000 for the replacement job. Does this seem about right? Quote Share this post Link to post Share on other sites
LemonHunter 583 Report post Posted May 14, 2017 10 minutes ago, pm007 said: HI - this is my first post Our 2002 318TI (120kms and in good shape) has a broken exhaust valve spring and the local garage is quoting between $2000 and $3000 for the replacement job. Does this seem about right? I'm not familiar with the N42 engines, but that sounds like a lot, you could swap an entire second hand engine for that kind of money. I'd suggest calling a BMW specialist repairer, for general servicing and such local garages are usually cheaper than a BMW garage, but when it comes to specialist work like this, often the BMW garage is cheaper as they are more likely to be familiar with the task. Quote Share this post Link to post Share on other sites
gjm 3300 Report post Posted May 14, 2017 1 hour ago, EURO V8 said: I'm not familiar with the N42 engines, but that sounds like a lot, you could swap an entire second hand engine for that kind of money. I'd suggest calling a BMW specialist repairer, for general servicing and such local garages are usually cheaper than a BMW garage, but when it comes to specialist work like this, often the BMW garage is cheaper as they are more likely to be familiar with the task. @zero is familiar with the N42. I suspect he'll suggest using something different. Quote Share this post Link to post Share on other sites
pmet007 0 Report post Posted May 14, 2017 Thanks - can anybody suggest BMW specialist repairers in Auckland? Quote Share this post Link to post Share on other sites
Gabe79 410 Report post Posted May 14, 2017 12 minutes ago, pm007 said: Thanks - can anybody suggest BMW specialist repairers in Auckland? Got me started. Quote Share this post Link to post Share on other sites
zero 1162 Report post Posted May 15, 2017 4 hours ago, pm007 said: HI - this is my first post Our 2002 318TI (120kms and in good shape) has a broken exhaust valve spring and the local garage is quoting between $2000 and $3000 for the replacement job. Does this seem about right? Is it a n42 motor? If you give us the last 7 digits of your vin, or your license plate number I can look it up. If it is a n42 they have many well documented problems -some terminal. If an exhaust valve spring is broken then chances are the head is badly damaged. When a valve spring broke on mine the valve fell into the cylinder and you can guess what happened next. If you are fixing the n42 there are several things that should be done at the same time; # valve stem seals: the material bmw used fails and will start giving you problems at this many kms which will require an upper engine rebuild. # timing chain and guides: the plastic guides break and once you jump a tooth or three its bye bye motor. # timing chain tensioner: not strong enough and sometimes causes the chain to jump teeth. And all that aside the pcv system should be done as you will have the head off. As you can see its not cheap, and not worth it. You could buy a second hand motor but it will just have the same problems. If it were me I'd swap in the cheapest n42 engine I could find and sell the car straight away, then use the money to buy an e46 with either the earlier 4 cylinder motor or the 6 cylinder. In my case my e46 is getting a m62b44, after going through the heartache of rebuilding the engine and have it fail just 150 km later. My engine woes can be found here; 3 Quote Share this post Link to post Share on other sites
