paulo
Damaged e46 M3 @ Turners
What do you mean? It's mint.
Posted Image
Can I see some kerbing on the front wheel in that pic???
Some d*ck spray painted the back wheel....
In all seriousness, would there be much good left? Dash is poked, wouldnt trust the front seats, engines probably poked. Rear end and maybe gearbox OK?
NZ new,200,000 km`s certainly up there for a e46 M3.
Probably the Serious Crash Unit trying to working out what caused this mess.
Very likely, but sarcasm doesnt work very well on the interwebs ;)
Says its an import (6,350kms at border check).
Maybe I should go look at it :-)
Weird, as it's registered as ex-Germany, but is a Japan-version. There is a 525i Touring from kerikeri for sale with the same things in it's history, and I've seen a 7 series the same - all 2000 models too. the 7 had a line in it build sheet that it was a testbed version or something similar too. Maybe it was destined for Japan, but ended up as a tourist delivery or somethiing. A bit weird to have a RHD car in Germany.
It has a weird WOF history too - then weren't too regular sometimes, but looks like it failed a fair few times... makes you wonder about it's service history.
It's last WOF was november 11 - what's it been doing since may 2012, when the wof would have expired....
Found the driver. Maybe they had the ASC remapped to "boy racer"
Saw this video ages ago. Actually looks like this car! Amazing..how the hell did the car end up in nz??
My guess is the the large hadron collider.
Looks like the car was converted to RHD somewhere is the time space continuum.
And WHY did they convert it to RHD after the accident?
