BreakMyWindow 1987 Report post Posted September 2, 2019 Just now, andrewm said: Ive got a threaded rod with brass press cups that i bought as the e39 rear ball joint tool from the UK. Is the touring the same? Tool looks like the one in attached image for ‘ball joints’ also in image. Yep those balljoints are the same across all e39’s. i’ll Pm ya. Quote Share this post Link to post Share on other sites
M3AN 4184 Report post Posted September 6, 2019 Now have a hub puller set in Auckland available (can ship). A seriously useful tool if you're doing hubs or bearings. 2 Quote Share this post Link to post Share on other sites
hunter 413 Report post Posted September 11, 2019 Anyone in the Hamilton area have a multimeter I can borrow for an afternoon friday or Saturday this week. Need to test my battery Quote Share this post Link to post Share on other sites
B.M.W Ltd 951 Report post Posted September 11, 2019 (edited) A multi meter will only give you voltage. It will not do a load test which is what you need to do after charging it for at least 24hrs. If its over three years old...replace it Edited September 11, 2019 by B.M.W Ltd 1 Quote Share this post Link to post Share on other sites
wongle 1 Report post Posted January 4, 2020 Anyone around palmy/wellington have a clutch fan pulley tool? Quote Share this post Link to post Share on other sites
qube 3570 Report post Posted January 20, 2020 Looking for a pressure tester to find a small coolant leak. Located auckland Quote Share this post Link to post Share on other sites
zero 1162 Report post Posted January 20, 2020 @qube I have one you can borrow. Quote Share this post Link to post Share on other sites
Secniv 182 Report post Posted February 13, 2020 Looking to borrow/hire trailing arm bushing tool to remove and press in new bushings. Also for other rear ball joints/bushes. Quote Share this post Link to post Share on other sites
M3AN 4184 Report post Posted February 13, 2020 12 minutes ago, Secniv said: Looking to borrow/hire trailing arm bushing tool to remove and press in new bushings. Also for other rear ball joints/bushes. @zero, @BatMansWilly 1 Quote Share this post Link to post Share on other sites
modz 159 Report post Posted February 23, 2020 Looking to borrow a bearing separator to do my e30’s rear wheel bearings happy to pay tracked postage to/from thanks Quote Share this post Link to post Share on other sites
M3AN 4184 Report post Posted February 23, 2020 21 minutes ago, modz said: Looking to borrow a bearing separator to do my e30’s rear wheel bearings happy to pay tracked postage to/from thanks What size? Mine's 75mm to 105mm... more than welcome to borrow it if it will fit (assuming I can find it!). Quote Share this post Link to post Share on other sites
Deano1968 41 Report post Posted March 10, 2020 Hi. Has anyone in Hamilton got a socket (or tool) I can borrow to undo the output shaft nut a Getrag 260 gearbox? I've tried the ones out of my socket set, but they're not deep enough and interfere with the output shaft. Cheers. Dean. Quote Share this post Link to post Share on other sites
BreakMyWindow 1987 Report post Posted June 3, 2020 Anyone have a wiper arm puller i could borrow? Quote Share this post Link to post Share on other sites
modz 159 Report post Posted June 3, 2020 If anyone needs the following I have them for hire at reasonable rates: - Engine brace (sits across your engine bay) to do sump, subframe etc work - Engine stand - Panel stand with foam tops usually have 1-2 of these available Pick up in Howick and bond required 1 Quote Share this post Link to post Share on other sites
M3AN 4184 Report post Posted June 3, 2020 2 hours ago, BreakMyWindow said: Anyone have a wiper arm puller i could borrow? I realise there's a proper tool but I just use a two or three arm puller depending which will fit. I have a puller set you can use. Quote Share this post Link to post Share on other sites
BreakMyWindow 1987 Report post Posted June 3, 2020 1 hour ago, M3AN said: I realise there's a proper tool but I just use a two or three arm puller depending which will fit. I have a puller set you can use. Yeah i used a 2 jaw on the M5’s one... easy as. On the wagon though, have tried 2 jaw pullers (now bent) wd40, heat, love taps, prying. No joy. Need the proper tool i think. Quote Share this post Link to post Share on other sites
SRacin 44 Report post Posted June 17, 2020 Looking to borrow e34 rear subframe Bush tool so I dont burn the car in frustration. Cheers Quote Share this post Link to post Share on other sites
scottharvey 60 Report post Posted June 27, 2020 Has anyone got a scan tool in akl just had a cel come up the dash is pulling up code 131 which is for a bulb but I feel like that’s not why the cel came on Quote Share this post Link to post Share on other sites
M3AN 4184 Report post Posted June 27, 2020 I have the Carly app and transmitter, you're more than welcome to try that if you want to swing by Ellerslie, send me a PM. 1 Quote Share this post Link to post Share on other sites
M3AN 4184 Report post Posted August 23, 2020 Anyone have an O2 sensor socket I can borrow? N52 engine if that makes a difference. Cheers. Quote Share this post Link to post Share on other sites
modz 159 Report post Posted August 23, 2020 59 minutes ago, M3AN said: Anyone have an O2 sensor socket I can borrow? N52 engine if that makes a difference. Cheers. Sorry mate I don’t but if you’re in a pinch they’re $18 from repco click and collect and I can send you my repco vip number for discount 1 Quote Share this post Link to post Share on other sites
HalfJobHarry 106 Report post Posted August 30, 2020 On 8/23/2020 at 2:09 PM, M3AN said: Anyone have an O2 sensor socket I can borrow? N52 engine if that makes a difference. Cheers. I have one that fits the sensor size on N54 pre cat sensors....I can check the size tomorrow...I'm pretty sure it's about as 'standard' as they come? Quote Share this post Link to post Share on other sites
M3AN 4184 Report post Posted August 30, 2020 9 hours ago, HalfJobHarry said: I have one that fits the sensor size on N54 pre cat sensors....I can check the size tomorrow...I'm pretty sure it's about as 'standard' as they come? All good, thanks mate, I picked up a cheepie from Repco the other day. It's not the perfect tool but it did the trick. 22mm FWIW. I could have used a spanner since it was the easy to access sensor. Quote Share this post Link to post Share on other sites
HalfJobHarry 106 Report post Posted August 31, 2020 4 hours ago, M3AN said: All good, thanks mate, I picked up a cheepie from Repco the other day. It's not the perfect tool but it did the trick. 22mm FWIW. I could have used a spanner since it was the easy to access sensor. Glad it's sorted! Sounds like you had a bit of luck with the access there. They have always been total nightmares for me (at least the pre cat ones. The post cat ones...not so bad. Quote Share this post Link to post Share on other sites
qube 3570 Report post Posted October 30, 2020 Anyone have a car battery charge i can borrow? Not jumper leads. I want to hook the car up to a power source while running the self bleeding procedure for the cooling system on the e61 and also to do some diagnostic testing for discharging on my battery. Thanks! Quote Share this post Link to post Share on other sites
