Etwenty1 45 Report post Posted August 30, 2017 3 hours ago, qube said: fixed the issue with the backrest twisting Did you disconnect the cable or just cut out section of sheath? Ps I have a cheap reset tool you could use but am in TAURANGA 1 Quote Share this post Link to post Share on other sites
M3AN 4184 Report post Posted August 30, 2017 4 hours ago, qube said: Anyone have a airbag reset tool for an E39? Asking on behalf of a friend. Have done some work on the passenger seat and the light came on. Pretty sure nothing wrong just needs to be reset. Cheers If it has a Pac-man connector under the hood I can probably do it for you also. 1 Quote Share this post Link to post Share on other sites
qube 3570 Report post Posted August 30, 2017 maybe we do it on Sunday Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted August 30, 2017 The cheapest way to do these is get a new cable made half an inch longer by an instrument company that makes speedo cables. Quote Share this post Link to post Share on other sites
eliongater 718 Report post Posted October 23, 2017 Is someone in Wellington able to flare a brake line for me? I also need the threaded part. Quote Share this post Link to post Share on other sites
mattmannz 1 Report post Posted November 10, 2017 I am in Kapiti and have E39 software and brake flare tools, press, ball joint tool and most other bits and pieces if anyone needs a hand. Quote Share this post Link to post Share on other sites
Syy0628 13 Report post Posted November 20, 2017 On 8/28/2014 at 8:37 AM, duvey said: I have spring compressors, a ball joint splitter, and a OBD1 peake tool on the North Shore that anyone is welcome to borrow. Also lots of other things like torque wrenches and air tools. Hi, I am a new member to the forum, I am currently working on my e36, I suspect a fuel system problem, do you happen to have fuel pressure gauge that I can borrow for a fee? I think my e36 316i with m43 is using M1.73 DME, does your scan tool work on my car? Can I borrow that as well? thanks Quote Share this post Link to post Share on other sites
Karter16 487 Report post Posted December 8, 2017 Hi all, If anyone is interested I can provide paper templates for those who want to manufacture their own E46 M3 RACP reinforcement plates. The plates and process are as per this thread: http://bimmersport.co.nz/topic/57571-karter-16s-e46-m3-journal/ The templates come with the expectation that final adjustments will be needed for fitting. The individual pieces of the plates need to be welded together. Some pieces can be folded. The plates were designed with the intent of epoxy affixing to the RACP using 3M 7333 Epoxy. The plates come with zero warranty/guarantee, however I have reasonably high standards and I fitted these to my car. I am aware that RACP plates only solve part of the problem (and indeed might cause new ones), something which everyone should be aware of before they do anything to their RACP. I fitted these plates as a part solution. I am using the BMW structural epoxy to reinforce the front mount points as well (rear points already done under BMW corrective action in my case). I am not tracking my car, and I'm not rough on it. If you are looking for a super solution you should look at a Mason bar and/or other such more comprehensive solutions. These plates require DIY skills, welding skills, etc. but are offered as they will help others save time if they are wanting to go down the DIY route. No charge - happy to copy the paper templates and post within NZ for free. Cheers, Matt 1 Quote Share this post Link to post Share on other sites
modz 159 Report post Posted December 13, 2017 Hi team does anyone have a 10 spline (std ZF manual) clutch alignment tool I could borrow and return mid Jan? Quote Share this post Link to post Share on other sites
warrenp 6 Report post Posted January 31, 2018 Anyone able to lend/sell the water pump (pulley pump?) holder tool for m54 and other engines? I could collect anywhere between Hutt valley and Masterton. https://www.ebay.com/itm/New-Iron-32mm-Fan-Clutch-Nut-Wrench-Water-Pump-Holder-Removal-Tool-Kit-For-BMW/332381663617?hash=item4d637db181:g:upIAAOSw6AlZvLq4 Quote Share this post Link to post Share on other sites
Gabe79 410 Report post Posted January 31, 2018 22 minutes ago, warrenp said: Anyone able to lend/sell the water pump (pulley pump?) holder tool for m54 and other engines? I could collect anywhere between Hutt valley and Masterton. https://www.ebay.com/itm/New-Iron-32mm-Fan-Clutch-Nut-Wrench-Water-Pump-Holder-Removal-Tool-Kit-For-BMW/332381663617?hash=item4d637db181:g:upIAAOSw6AlZvLq4 For that price, you might as well buy them, no? I have them here in Auckland and am happy to loan for cost of postage anytime. Quote Share this post Link to post Share on other sites
warrenp 6 Report post Posted January 31, 2018 (edited) Thanks Gabe, I made the tool out of an old handsaw. It had a hole in about the right place at the end so I anglegrinded an indent to about the same shape as the OEM tool. Worked like a charm. If anyone in Wairarapa region needs it let me know. Edited February 3, 2018 by warrenp Quote Share this post Link to post Share on other sites
Jacko 2342 Report post Posted March 8, 2018 I have E8/9x bushing removal/install kits, happy to hire etc to members (may even sell in a month!) Schwaben Silent Block/Bushing Tool Set Remove and install rear ball joints on E38, E39, E60/61, E63/64, E65/66, and E70's Removal and installation of ball joints and bushings on rear control arms on E36, E46, E39, E60/61, E63/64, E65/66, E70, E83 and E85/86 Z4's Removal and installation of rear subframe mounted differential bushings on E36, E46, E83 and E85/86 Z4's Removal and installation of rear differential mounted bushings on E36, E46, E9X, E60/61, E63/64, E65/66, and E85/86 Z4's BGS Technic Rear Trailing Arm Set For replacing the trailing arm bushings and trailing arm in wheel carrier bushing suitable for BMW Models 1 and 3 (2004 - 2012) series: E81 / E82 / E83 / E85 / E86 / E87 E88 / F20 / E90 / E91 / E92 / E93 includes the following tools: split bush compressor to be used as OEM 334450 camber arm mounting extraction / insertion tool to be used as OEM 334460 trailing arm mounting extraction / insertion tool to be used as OEM 334480 German Specialty Tools Rear Subframe Set E87/90/91/92/93 This tool set used to remove and Install front and rear bushings in the rear subframe. Applicable: BMW E87 and E90/91/92/93 Quote Share this post Link to post Share on other sites
BreakMyWindow 1987 Report post Posted June 1, 2018 Anyone have the diff and subframe bush kit similar to one above for e39 available for rent? 1 Quote Share this post Link to post Share on other sites
M3AN 4184 Report post Posted June 12, 2018 Does anybody have a M14x1.5 die I can use? I need to chase a thread and my biggest is 12x1.5. Seems a shame to have to purchase a tool for such a job. If you're out of Auckland I'd be happy to cover costs. Cheers. Quote Share this post Link to post Share on other sites
Gabe79 410 Report post Posted June 12, 2018 On 6/1/2018 at 5:50 PM, BreakMyWindow said: Anyone have the diff and subframe bush kit similar to one above for e39 available for rent? Have you found one yet? If not, do you, or anyone else want to go halves on one? Quote Share this post Link to post Share on other sites
WYZEUP 283 Report post Posted July 9, 2018 Does anyone have any wheel dollys in the wellington region i can borrow/rent for a weekend? Quote Share this post Link to post Share on other sites
Jacko 2342 Report post Posted July 14, 2018 Anyone got an engine support bar I can borrow? The kind that spans the engine bay from the guards. Gearing up to do the 130 sump gasket Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2153 Report post Posted July 14, 2018 On 3/8/2018 at 8:59 PM, Jacko said: I have E8/9x bushing removal/install kits, happy to hire etc to members (may even sell in a month!) yep im interested. On 7/9/2018 at 12:37 PM, WYZEUP said: Does anyone have any wheel dollys in the wellington region i can borrow/rent for a weekend? yep have a few here, garage type cant tow with them or anything. Quote Share this post Link to post Share on other sites
francoisv 466 Report post Posted September 30, 2018 Probably been asked a few times before, but does anyone have a car trailer i could borrow / hire / HJ for a couple days? Quote Share this post Link to post Share on other sites
qube 3570 Report post Posted January 9, 2019 Airbag reset tool anyone? E36 Quote Share this post Link to post Share on other sites
BreakMyWindow 1987 Report post Posted January 9, 2019 1 hour ago, qube said: Airbag reset tool anyone? E36 As in to reset the airbag light on the cluster? If so i have the software. Quote Share this post Link to post Share on other sites
M3AN 4184 Report post Posted January 9, 2019 As above @qube, I can also do it with my rig. I won't be upset (much) if you choose Martin over me though. ? Quote Share this post Link to post Share on other sites
qube 3570 Report post Posted January 9, 2019 Dave is definitely closer to me just need to do the seat bypass first then will have a go to reset the airbag light on the cluster. cheers all! Quote Share this post Link to post Share on other sites
BatMansWilly 74 Report post Posted January 11, 2019 Hey Guys, in need of a Slide Hammer for a few days. Need to get a few Dents out of the car. Happy to give ya some $$$ or ? for it. located in Auckland. Cheers Quote Share this post Link to post Share on other sites
