qube 3570 Report post Posted September 6, 2017 theres not enough sand and powder in auckland to keep up with your work mate! 1 Quote Share this post Link to post Share on other sites
zero 1162 Report post Posted September 6, 2017 4 minutes ago, qube said: theres not enough sand and powder in auckland to keep up with your work mate! Thanks man. Its definitely time consuming but at least I can say I did it myself. 1 Quote Share this post Link to post Share on other sites
allan 295 Report post Posted September 6, 2017 9 hours ago, zero said: at least I can say I did it myself. And their you have it a man that takes pride in his work and the results for all to see. 2 Quote Share this post Link to post Share on other sites
WYZEUP 283 Report post Posted September 6, 2017 my oh my reading this makes me want to go back and re-do all my work again haha 2 Quote Share this post Link to post Share on other sites
Karter16 487 Report post Posted September 8, 2017 On 9/6/2017 at 7:22 PM, zero said: I got the subframe and diff into the car. I had to then take it back out again because the lower and upper control arms couldn't be bolted in with the diff in the way. Rookie mistake. But second time is a charm. Haha - we got pretty close to making the same mistake The welded spacers on the front brace look nice - good work! 1 Quote Share this post Link to post Share on other sites
zero 1162 Report post Posted September 8, 2017 44 minutes ago, Karter16 said: Haha - we got pretty close to making the same mistake The welded spacers on the front brace look nice - good work! Thanks mate. I'm a slow learner. Quote Share this post Link to post Share on other sites
modz 159 Report post Posted October 17, 2017 Well done on the project and the detail, following this with interest. Once my E46 coupe may end up getting a V8....there are so many nay-sayers online in regards to it not fitting purely due to the sump, which does seem a cop out 1 Quote Share this post Link to post Share on other sites
Karter16 487 Report post Posted December 8, 2017 How's everything going? Any updates? 1 Quote Share this post Link to post Share on other sites
Michael. 2313 Report post Posted December 8, 2017 On 10/17/2017 at 9:01 PM, modz said: Well done on the project and the detail, following this with interest. Once my E46 coupe may end up getting a V8....there are so many nay-sayers online in regards to it not fitting purely due to the sump, which does seem a cop out Sump on the M62 is pretty nasty, it is a cop out though. I'd just ditch the factory sump and make a simple new type with laser cut pieces. For the engines to fit nicely they need to be quite far reward to clear the subframe and not too thick either as the subframe to block clearance isn't much. 1 Quote Share this post Link to post Share on other sites
zero 1162 Report post Posted December 8, 2017 3 hours ago, Michael. said: Sump on the M62 is pretty nasty, it is a cop out though. I'd just ditch the factory sump and make a simple new type with laser cut pieces. For the engines to fit nicely they need to be quite far reward to clear the subframe and not too thick either as the subframe to block clearance isn't much. Also the oil pump needs to be taken into consideration as its at the front of the motor. I havnt had a good look at this yet. Quote Share this post Link to post Share on other sites
zero 1162 Report post Posted December 8, 2017 5 hours ago, Karter16 said: How's everything going? Any updates? A bit slow due to lack of funds. I need to buy adjustable camber plates and one more front control arm and the front end can be installed. Rear end is all installed. Engine bay has been modified and painted. While I wait for money to buy parts I gave my wifes car a full respray. 2 Quote Share this post Link to post Share on other sites
Michael. 2313 Report post Posted December 8, 2017 7 hours ago, zero said: Also the oil pump needs to be taken into consideration as its at the front of the motor. I havnt had a good look at this yet. Oh yeah of course, what a pain in the ass. Would really need to remove it and run an remote oil pump, almost be best with a basic dry oil sump. That would sit right where the steering rack is. 1 Quote Share this post Link to post Share on other sites
zero 1162 Report post Posted December 9, 2017 Dry sump would be perfect but way out of my price range. I guess I could make/get made a modified sump with an external oil pump. I would be terrified of it failing though and killing the motor. 1 Quote Share this post Link to post Share on other sites
Michael. 2313 Report post Posted December 9, 2017 Yeah, I think a mechanical external pump, custom mounted and running off the accessory belt would do the trick and be the most reliable etc. Could probably get a remote mount electric oil pump but I do also question the reliability, that said you could put in a fail safe switch/sensor that cuts the engine if the oil pressured drops or electric motor fails, turning off the engine ignition immediately 2 Quote Share this post Link to post Share on other sites
gjm 3300 Report post Posted December 9, 2017 12 hours ago, zero said: Dry sump would be perfect but way out of my price range. I guess I could make/get made a modified sump with an external oil pump. I would be terrified of it failing though and killing the motor. I'll re-read the thread, but what are you doing for EMS? Michael's suggestion of an electric pump, cutting the engine in the event of low oil flow or pressure (pressure ain't everything!) would work. 1 Quote Share this post Link to post Share on other sites
zero 1162 Report post Posted December 10, 2017 2 hours ago, gjm said: I'll re-read the thread, but what are you doing for EMS? Michael's suggestion of an electric pump, cutting the engine in the event of low oil flow or pressure (pressure ain't everything!) would work. If you mean ecu then I'm not decided, but probably a link. Quote Share this post Link to post Share on other sites
Michael. 2313 Report post Posted December 10, 2017 9 hours ago, gjm said: I'll re-read the thread, but what are you doing for EMS? Michael's suggestion of an electric pump, cutting the engine in the event of low oil flow or pressure (pressure ain't everything!) would work. haha yeah flow is often forgotten, cold oil, plenty of pressure but low flow is the classic example. I think it's easier to switch something via pressure though, I'm sure inline oil flow meters exist but the cost and how the data they produce would be used would be the challenge. 1 Quote Share this post Link to post Share on other sites
BreakMyWindow 1995 Report post Posted December 10, 2017 Keep the original sump and modify an e39 v8 subframe? 1 Quote Share this post Link to post Share on other sites
zero 1162 Report post Posted December 11, 2017 17 hours ago, BreakMyWindow said: Keep the original sump and modify an e39 v8 subframe? I did investigate this option and had a e39 v8 subframe to play around with. I decided against it because it would require using the crappy e39 steering box, which was not a compromise I was prepared to make. Also, I don't know how badly it messes up the suspension geometry. 2 Quote Share this post Link to post Share on other sites
Michael. 2313 Report post Posted December 11, 2017 I know that's what Ray did with the S62 into the E46 vert. Not sure I'd go that way but it's proven to work. Don't you find the on center feel of the M5 steering box a bit dull Martin? 1 Quote Share this post Link to post Share on other sites
BreakMyWindow 1995 Report post Posted December 11, 2017 2 hours ago, Michael. said: I know that's what Ray did with the S62 into the E46 vert. Not sure I'd go that way but it's proven to work. Don't you find the on center feel of the M5 steering box a bit dull Martin? Yeah that’s if being fussy. Get an M5 steering box with servotronic. Wouldn’t be gutted. 3 Quote Share this post Link to post Share on other sites
zero 1162 Report post Posted December 12, 2017 On 12/11/2017 at 6:39 PM, Michael. said: I know that's what Ray did with the S62 into the E46 vert. Not sure I'd go that way but it's proven to work. Its proven but its a compromise. There are better ways of doing it. 1 Quote Share this post Link to post Share on other sites
BreakMyWindow 1995 Report post Posted December 12, 2017 11 hours ago, zero said: Its proven but its a compromise. There are better ways of doing it. Better, as in more expensive? Quote Share this post Link to post Share on other sites
zero 1162 Report post Posted December 12, 2017 2 hours ago, BreakMyWindow said: Better, as in more expensive? Similar cost and similar time. Keeping the existing e46 suspension geometry and steering is the better way of doing it from all my research. Its just solving the sump and oil pump challenge that instead becomes the issue. Dry sump is the ideal but way too expensive for me. Most people modify the existing sump and move the engine up and forward but I see that as a compromise too. Quote Share this post Link to post Share on other sites
Eddie 66 Report post Posted May 20, 2018 how is this going? Quote Share this post Link to post Share on other sites
