Jacko 2352 Report post Posted February 27, 2018 Decided to blow some money at the old girl - Birds B1 Dynamics full kit - Bilsteins/springs/swaybars/quaife LSD (about time on the LSD front!) SuperPro Bushes on everything, including rear subframe, new spring pads/tophats/bumpstops/shock mounts/Meyle HD links etc etc and everything inbetween E92 M3 LCAs etc New SMF and Clutch, deleting the SAC and CDV, new centre bearing and guibos New Waterpump and thermostat (232k on the clock of the original, and got a canbus com error with it last week) Upgrade/Rebuild shifter And decided to say F work for a few weeks and do it all in the carport Might be a lil bit interesting pulling the gearbox with the car on jack stands. The only thing left to order is the tool for the subframe bushes, still screwing around with either just buying it (and probably selling it) or just making something. Pics to come! 3 Quote Share this post Link to post Share on other sites
Jacko 2352 Report post Posted March 14, 2018 11 years later, it finally gets what it should have had out of the box 6 Quote Share this post Link to post Share on other sites
qube 3570 Report post Posted March 14, 2018 Quaife! 1 Quote Share this post Link to post Share on other sites
KwS 2450 Report post Posted March 22, 2018 Its crazy they dont have an LSD standard. Is there any other BMW Lego LSD that would bolt straight in? Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted March 22, 2018 2 hours ago, KwS said: Its crazy they dont have an LSD standard. Is there any other BMW Lego LSD that would bolt straight in? only thing is a complete rear end from a e92 m3 or e81 1M , pretty much only M cars have lsd now , unless you retro fit or special order ? 1 Quote Share this post Link to post Share on other sites
Jacko 2352 Report post Posted March 25, 2018 It begins, turning 236k of road grime into something resembling chocolate milkshake. 2 Quote Share this post Link to post Share on other sites
KwS 2450 Report post Posted March 25, 2018 Thats come up well, I need to do that on all my cars. Whats your weapon for it? Just normal car wash or something stronger? Quote Share this post Link to post Share on other sites
Jacko 2352 Report post Posted March 25, 2018 (edited) 2 hours ago, KwS said: Thats come up well, I need to do that on all my cars. Whats your weapon for it? Just normal car wash or something stronger? Generic "heavy duty" car wash from super cheap, foam gun, Luxio wheel cleaner stuff (like dragons breath) and a water blaster. Was surprised how well it cleaned up too. Even BMW stickers are LL04 rated... Edited March 25, 2018 by Jacko 2 Quote Share this post Link to post Share on other sites
Olaf 3426 Report post Posted March 25, 2018 which foam gun did you get? Is it one for your water blaster? Quote Share this post Link to post Share on other sites
Jacko 2352 Report post Posted March 26, 2018 15 hours ago, Olaf said: which foam gun did you get? Is it one for your water blaster? Some generic ebay one that about 5 other companies rebrand and charge more for! Was like $30, works mint, hooks up to the nilfisk water blaster. 1 Quote Share this post Link to post Share on other sites
Jacko 2352 Report post Posted April 1, 2018 Day 1 (well 4 hours) progress... Discovered what looks to be the gearbox input shaft seal leaking, good thing some clever bastard ordered full set of box seals! Lucky... All comes apart pretty simply so far, helper dog is lots of help. Unbolt things, clean them up, unbolt next thing, rinse and repeat. Diff out and then off to the Kayne Barrie to install the quaife tomorrow, will probably start stripping the rear suspension and installing the poly bushes as well. 1 Quote Share this post Link to post Share on other sites
gjm 3300 Report post Posted April 1, 2018 Good dog! I have helper cats. All they do is remind me how slow I am... Quote Share this post Link to post Share on other sites
Jacko 2352 Report post Posted April 1, 2018 Yes.. he is very helpful, particularly when hes trying to lick your ear you while trying to wrestle the driveshaft out.... Quote Share this post Link to post Share on other sites
Jacko 2352 Report post Posted April 2, 2018 Day 2... Progress. More waterblasting under the car while on a creeper, its messy, got totally covered in crap. Took some creativity with the diff bushes to get them out, particularly the rear one as its pretty large. Ended up using bits of the subframe and CAB bushing tools to get something that fitted. Came out and went in easy otherwise. Shocks out, very tired but still working, bump stops and lower mounts are totally shot. Curiously rear diff mount is shagged, fronts look fine. Drive shaft guibos have some cracking, center bearing feels pretty rattly. Pretty minor for the number of ks on it, and luckily nothing havent ordered parts for already. Subframe bushes and all the rear suspension arm bushes tomorrow, and likely new shocks, springs, and sway bar in. 2 Quote Share this post Link to post Share on other sites
Jacko 2352 Report post Posted April 3, 2018 (edited) Day 3... Swaybars are a @*!# BMW must start with the swaybar and build car around it. Eventually discovered best way is to drop both front subframe bolts and play some sort of chinese finger puzzle. For those that want to know - Stock MS rear is 14mm, B1 is 15mm, stock MS front is 23.5mm, B1 is 28mm The GST (Kommen) subframe bush tool is the business, really nice quality and makes it an easy job. Didnt even have to swear. Butchery of the schwaben bush kit makes for easy install of the crush tubes. Pretty sure could do a cars subframe bushes in an easy half day from go to woah. Found some waterbased degreaser (supercheap), can stick it in foam gun. Works mint. All the rear end arm bushings tomorrow, needs more blue PU. Edited April 3, 2018 by Jacko 3 Quote Share this post Link to post Share on other sites
Michael. 2313 Report post Posted April 3, 2018 Good job, work most people wouldnt do! 1 Quote Share this post Link to post Share on other sites
Jacko 2352 Report post Posted April 4, 2018 Day 4. Bush is a four letter word. So many bushes, takes ages, way worse than subframe bushes. The trailing arm ones in the hub are a bastard, for some reason the ali external clamshell is really soft (brake heat?) And likes to swag its ass all over the place. Peening it all back in and swearing solves it. All the bushes done though. Its downhill from here. Time for a beer. 4 Quote Share this post Link to post Share on other sites
hunter 413 Report post Posted April 4, 2018 wish i had these skills, tools and bushes for my e46 Quote Share this post Link to post Share on other sites
Jacko 2352 Report post Posted April 4, 2018 Not too many skills, need more. Watched some youtube, read the manual, did it. Im still working out how Im going to get the gearbox out without dropping it on myself... I have PTSD of dropping my old SC Levins gearbox on my groin. 2 Quote Share this post Link to post Share on other sites
hunter 413 Report post Posted April 4, 2018 Skills include temperament to do this type of work lol.. 1 Quote Share this post Link to post Share on other sites
Michael. 2313 Report post Posted April 4, 2018 Definitely need to be game, but that's like anything in life Quote Share this post Link to post Share on other sites
B.M.W Ltd 951 Report post Posted April 5, 2018 (edited) 18 hours ago, Jacko said: Not too many skills, need more. Watched some youtube, read the manual, did it. Im still working out how Im going to get the gearbox out without dropping it on myself... I have PTSD of dropping my old SC Levins gearbox on my groin. Getting the gearbox out will be easier than getting it back in with the weight on the back of the engine. Putting it back in with out loading the clutch center and bending it will be your first hurdle. Doing it on stands without the right tools can also be very dangerous. It really should be only attempted doing it on a hoist with a transmission jack to get the alignment and load right or dropping the engine, transmission and front cross member together. Edited April 5, 2018 by B.M.W Ltd 1 Quote Share this post Link to post Share on other sites
Jacko 2352 Report post Posted April 5, 2018 (edited) 1 hour ago, B.M.W Ltd said: Getting the gearbox out will be easier than getting it back in with the weight on the back of the engine. Putting it back in with out loading the clutch center and bending it will be your first hurdle. Doing it on stands without the right tools can also be very dangerous. It really should be only attempted doing it on a hoist with a transmission jack to get the alignment and load right or dropping the engine, transmission and front cross member together. Its going to be a very careful careful slow process I agree though, unfortunately carport doesnt feature a hoist or transmission jack (looked at a few transmission adapters for the floor jack, they didnt look like they would work though). If some guy didnt have to go and close up his workshop, it'd be on his hoist Edited April 5, 2018 by Jacko Quote Share this post Link to post Share on other sites
Jacko 2352 Report post Posted April 5, 2018 (edited) Todays effort, Unleash the parts cannon! Slow going getting the Diff back in, Kayne did a nice job with the Quaife innards swap (quick turn around too!) The bush kit has a big ass washer between diff rear mount and the subframe, its a mare to get in and lined up while balancing diff on jack and jiggling it around to get holes to line up. Shocks and springs fall in though, which is a pleasant change! Back ends pretty much done now, other than covers and exhaust... Just the clutch, box, shifter rebuilt, front struts, water pump, thermostat, m3 LCAs, and an oil change to go now! Edited April 5, 2018 by Jacko 5 Quote Share this post Link to post Share on other sites
Jacko 2352 Report post Posted April 6, 2018 (edited) Front end suspension done, bar the swaybar, that can wait for the waterpump and thermostat tomorrow. M3 lower arms are simple to fit. Struts are a struggle to get in, takes some brute force to get them under the gaurds. All that remains from the original struts is the washer for the upper hat, and the upper perch plate. Found a few kg of gravel and dead insects under the bumper trim, so busted out the water blaster again... Edited April 6, 2018 by Jacko 1 Quote Share this post Link to post Share on other sites
