gjm 3300 Report post Posted June 2, 2020 18 minutes ago, Gaz said: Magic eye doesn't always mean sh*t. Load test is most reliable way to confirm battery status Completely agree. It's a guide - nothing more. Load testing typically requires being able to start the vehicle. That's not happening, without charging the battery (again). Which I can do, of course. 5 minutes ago, M3AN said: Hmm, that battery sounds good enough for at least one start... sure your starter is okay? I don't have any meaningful E30 knowledge but can you reach the starter with a dead blow hammer to give it a tap when you can hear the 'noid? I'm not suggesting the battery is not the culprit but I'd want to eliminate the starter before buying a new battery. Either way, when I did my research ~8 months ago these guys: https://www.mrpositive.co.nz/ had the best price by quite some margin for a Bosch S5. When fully charged, it seems it'll do a couple of starts. The third one is a bit of a no-go... But when the car starts, it starts easily. I measured a 5V difference between running (charging) voltage, and that displayed when unsuccessfully trying to start the car. Even when it won't start, there's enough charge to show good headlights and full beam. This suggests to me that voltage is present, but power is not. Quote Share this post Link to post Share on other sites
allan 295 Report post Posted June 2, 2020 Have you checked the earth connections Quote Share this post Link to post Share on other sites
gjm 3300 Report post Posted June 2, 2020 6 minutes ago, allan said: Have you checked the earth connections Not yet. It's dark and there's no undercover, let alone inside, space I can use. Quote Share this post Link to post Share on other sites
KwS 2450 Report post Posted June 2, 2020 Voltage dropping to 9V is a pretty sure sign its FUBAR. I wouldnt bother looking too far without replacing the battery first. Quote Share this post Link to post Share on other sites
gjm 3300 Report post Posted June 9, 2020 2003 X5. Colleague at work is looking for new tyres. She has runflat rims and tyres and present, and has been advised she *must* use runflat tyres. Not because 'ordinary' tyres won't be suitable - they'll fit and work perfectly well - but because in the even of a puncture, the pressure sensors could be damaged if 'ordinary' - not runflat - tyres are fitted. I thought the sensors were sufficiently out of the way for that not to be an issue? Of course, I don't own or drive an X5... Quote Share this post Link to post Share on other sites
B.M.W Ltd 951 Report post Posted June 9, 2020 The tyre pressure monitoring works by diagnosing from the wheel speed sensors. They don't have sensors inside the wheel 1 Quote Share this post Link to post Share on other sites
polley 916 Report post Posted June 11, 2020 On 6/10/2020 at 9:48 AM, B.M.W Ltd said: The tyre pressure monitoring works by diagnosing from the wheel speed sensors. They don't have sensors inside the wheel I've never had to deal with tpms system. But had researched it awhile ago as was interested to see how it worked. And had read about the system you describe and also the system which uses sensors in the tyre valve. A quick check on TIS for e53 shows it uses a pressure sensor in valve system. Maybe the tyre shop is correct. Would be interesting to know what system it is using. https://www.newtis.info/tisv2/a/en/e53-x5-3.0d-sav/wiring-functional-info/chassis-suspension/wheels-tyres/tyre-pressure-control/XkPZ3jW 1 Quote Share this post Link to post Share on other sites
B.M.W Ltd 951 Report post Posted June 11, 2020 I stand corrected. You learn something every day. I found this: https://www.tomorrowstechnician.com/tech-tip-bmw-tpms-systems/ 1 Quote Share this post Link to post Share on other sites
Jacko 2341 Report post Posted June 11, 2020 Found something similar the other day, 128s (the US market N52B30 coupe) uses actual pressure sensors, makes ya wonder why BMW developed two systems for two different markets considering so much of the parts are similar. 1 Quote Share this post Link to post Share on other sites
M3AN 4183 Report post Posted June 11, 2020 Does TPMS apply to runflats? If so I'd expect you to need to use the valves because the wheelspeed sensor wouldn't see a meaningful change. 1 Quote Share this post Link to post Share on other sites
C-130 Hercules 572 Report post Posted June 12, 2020 Hi Team - looking to buy some ceramic grease for glow plug fitting. Any recommendations for good product and where to buy? Cheers! Quote Share this post Link to post Share on other sites
KwS 2450 Report post Posted June 12, 2020 9 hours ago, M3AN said: Does TPMS apply to runflats? If so I'd expect you to need to use the valves because the wheelspeed sensor wouldn't see a meaningful change. Must do, my E91 was specced with runflats from new and had the weird rolling radius based TPMS with no sensors. Didnt know that was a thing until i went digging to find out why mine randomly triggered a TPMS light driving back from Hamilton despite pressures being good. Quote Share this post Link to post Share on other sites
Gaz 1077 Report post Posted June 12, 2020 Because the runflat tyres have a stiffened sidewall, it's nigh impossible to tell if you have a puncture visually, hence the need for TPMS Quote Share this post Link to post Share on other sites
KwS 2450 Report post Posted June 12, 2020 1 hour ago, Gaz said: Because the runflat tyres have a stiffened sidewall, it's nigh impossible to tell if you have a puncture visually, hence the need for TPMS That's @M3ANs point. With the stiff sidewall, wouldn't it make more sense to have an actual pressure sensor instead of the fake abs sensor one? Quote Share this post Link to post Share on other sites
Jacko 2341 Report post Posted June 12, 2020 Pretty much all the E8/9 generation have runflats, but two different systems for telling Karen the tyres flat. Quote Share this post Link to post Share on other sites
aja540i 1925 Report post Posted June 12, 2020 9 hours ago, KwS said: Must do, my E91 was specced with runflats from new and had the weird rolling radius based TPMS with no sensors. Didnt know that was a thing until i went digging to find out why mine randomly triggered a TPMS light driving back from Hamilton despite pressures being good. It can be triggered by a long gentle bend in the road, not enough angle on the steering wheel for the sensor to detect, but enough difference in wheel speed for the abs sensor to detect, and it thinks you have a flat, the Waterview tunnel triggered the TPMS in the M5. Quote Share this post Link to post Share on other sites
B.M.W Ltd 951 Report post Posted June 12, 2020 (edited) 10 hours ago, C-130 Hercules said: Hi Team - looking to buy some ceramic grease for glow plug fitting. Any recommendations for good product and where to buy? Cheers! I've used this on many diesel motors in the past. Max operating temp is 1200'c https://eshop.wurth.co.nz/Copper-paste-CU-800-PAST-CU-800-TUBE-100G/08938001.sku/WuerthGroup-Wuerth.cgid/en/GB/NZD/?VisibleSearchTerm=Copper+grease Be very careful and use the correct tools Edited June 12, 2020 by B.M.W Ltd adding info 2 Quote Share this post Link to post Share on other sites
B.M.W Ltd 951 Report post Posted June 12, 2020 (edited) I might also add: Do a lot more research and only use the correct tools before you attempt to do the job. This varies quite a bit with different models and engine types. Edited June 12, 2020 by B.M.W Ltd Quote Share this post Link to post Share on other sites
Gaz 1077 Report post Posted June 12, 2020 8 hours ago, KwS said: That's @M3ANs point. With the stiff sidewall, wouldn't it make more sense to have an actual pressure sensor instead of the fake abs sensor one? Doesn't really matter as long as it does the job. Both super reliable, only issues with them are users ones. Quote Share this post Link to post Share on other sites
C-130 Hercules 572 Report post Posted June 12, 2020 4 hours ago, B.M.W Ltd said: I might also add: Do a lot more research and only use the correct tools before you attempt to do the job. This varies quite a bit with different models and engine types. Thanks for the heads up - was expecting it actually ? They can be tricky to take out. Have been squirting a bit of oil onto the base for a couple of days now to work itself in. Have come up with the following procedure: 1. Don't rush 2. Penetrate bases with oil for some days 3. Warm engine before removal 4. Compressed air clean seats 5. Dap oil on base and let soak for another 30 mins 6. Check tight - 1/64th tighten 7. Then attempt to loosen (with torque 11-12nm?) 8. If resistance is encountered, work your way up again and down again Got hold of following products. Not sure which is better. Any suggestions? Quote Share this post Link to post Share on other sites
B.M.W Ltd 951 Report post Posted June 12, 2020 Your on to it. What vehicle/engine are you doing this on ? Quote Share this post Link to post Share on other sites
C-130 Hercules 572 Report post Posted June 12, 2020 16 minutes ago, B.M.W Ltd said: Your on to it. What vehicle/engine are you doing this on ? Gl320cdi / Om642.940 Quote Share this post Link to post Share on other sites
B.M.W Ltd 951 Report post Posted June 12, 2020 4 minutes ago, C-130 Hercules said: Gl320cdi / Om642.940 Good luck....I'd get the engine hot before starting the job so it's warm by the time you get there. 1 Quote Share this post Link to post Share on other sites
C-130 Hercules 572 Report post Posted June 13, 2020 8 minutes ago, B.M.W Ltd said: Good luck....I'd get the engine hot before starting the job so it's warm by the time you get there. Thanks, yes that's the plan. ? Quote Share this post Link to post Share on other sites
Mikan 173 Report post Posted June 14, 2020 I'm keen to swap an m42 into my m40 e30, but am very keen to hold on to my aircon. Will it be possible to bolt the original compressor onto the m42, or is there zero chance the belt tracking will line up? Or is the pulley different or something maybe? Failing that, would a compressor from the donor car work with the rest of the e30's aircon setup? I appreciate any knowledge/thoughts/speculation. Cheers. 1 Quote Share this post Link to post Share on other sites
