slybma 38 Report post Posted October 10, 2013 IIRC the donor was a eary - mid 1993 325 coupe. Did have the VIN at one stage but the file seems to have been lost in the course of moving house. I think i have the VIN number somewhere, i have the ECU from that car in my E30 Quote Share this post Link to post Share on other sites
Ahmedsinc 414 Report post Posted October 10, 2013 They can slide in length at the middle of the driveshaft , loosen the big nut , Bloody legend! Quote Share this post Link to post Share on other sites
Ahmedsinc 414 Report post Posted October 10, 2013 I think i have the VIN number somewhere, i have the ECU from that car in my E30 Actually that would be useful I know you sent it to me but I'm damned if I know what became of it Quote Share this post Link to post Share on other sites
slybma 38 Report post Posted October 10, 2013 Actually that would be useful I know you sent it to me but I'm damned if I know what became of it Haha found it WBABF32020JB02528 hope this helps Quote Share this post Link to post Share on other sites
Ahmedsinc 414 Report post Posted October 10, 2013 Haha found it WBABF32020JB02528 hope this helps Kickass! Don't suppose you'd be keen to sell the ECU? Quote Share this post Link to post Share on other sites
slybma 38 Report post Posted October 10, 2013 Kickass! Don't suppose you'd be keen to sell the ECU? haha sorry its there to stay, i finally got around to getting the engine fired up the ECU was the hard part to find Quote Share this post Link to post Share on other sites
Ahmedsinc 414 Report post Posted October 11, 2013 haha sorry its there to stay, i finally got around to getting the engine fired up the ECU was the hard part to find Thought you'd say that Right, now to find someone that can teach me how to code! Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted October 11, 2013 Thought you'd say that Right, now to find someone that can teach me how to code! which ecu type do you need , i have some manual coded ones in stock Quote Share this post Link to post Share on other sites
Ahmedsinc 414 Report post Posted October 11, 2013 which ecu type do you need , i have some manual coded ones in stock Should've known you'd have something stashed away '94 E36 325i. Not too worried about the rpm at idle, just want to avoid the rev flare on gearchanges. I can see that will annoy the hell outta me. Thanks Brent Quote Share this post Link to post Share on other sites
_Matt_ 42 Report post Posted October 21, 2013 one of my water pump bolts broke due to corrosion, i drilled it out but its made a bit of a mess and i need a way to fill it before redrilling and retapping. would a welder be the right thing to use to fill up the hole? thoughts? Quote Share this post Link to post Share on other sites
dubman 39 Report post Posted October 21, 2013 what about metal epoxy putty? although a weld sounds better Quote Share this post Link to post Share on other sites
_Matt_ 42 Report post Posted October 21, 2013 tried that, it's about as hard as baked clay lol, didn't really work at all. if a weld is the answer is there a Cantab with a welder willing to help out? Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted October 21, 2013 A heli coil would be better. A pic of the mess might help with suggestions. Welding is probably not an option Quote Share this post Link to post Share on other sites
yng_750 247 Report post Posted October 21, 2013 you can buy thread repair kits that use an metal epoxy, very different stuff to normal epoxy glues you buy for odd jobs. as glenn said a heli coil would be your best option. possibly best to take it to someone who has done it before, amateur work can just make it worse Quote Share this post Link to post Share on other sites
_Matt_ 42 Report post Posted October 21, 2013 you can buy thread repair kits that use an metal epoxy, very different stuff to normal epoxy glues you buy for odd jobs. as glenn said a heli coil would be your best option. possibly best to take it to someone who has done it before, amateur work can just make it worse I've done a bit of research and I'll try a 2 part epoxy which is about 3x the strength of the steel putty. If that fails I'll have a rethink. Helicoil won't work unless I use one in conjunction with the epoxy. The hole is large and not circular. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted October 22, 2013 I've done a bit of research and I'll try a 2 part epoxy which is about 3x the strength of the steel putty. If that fails I'll have a rethink. Helicoil won't work unless I use one in conjunction with the epoxy. The hole is large and not circular. You might be looking at a new block then. I doubt the epoxy will have the strength and deal with the temperatures. Show us a picture... by PM if you like Quote Share this post Link to post Share on other sites
_Matt_ 42 Report post Posted October 22, 2013 PM'd Quote Share this post Link to post Share on other sites
Allanw 1081 Report post Posted October 22, 2013 You want a timesert or an oversized insert. Spring style inserts (like helicoil brand are) can cause a lot of issues later. If you have the space, you can drill it bigger, screw in some threaded rod, then drill and tap to suit., VERY carefully. 1 Quote Share this post Link to post Share on other sites
EuroSurgeon 2 Report post Posted October 22, 2013 Which engine was this? If just one of four bolts holding pump, sometimes best bet is run with 3 bolts Quote Share this post Link to post Share on other sites
Etwenty1 45 Report post Posted October 22, 2013 e30 manual conversion pedal stops wondering about the kickdown switch on the accelerator pedal, if i remove this is there a stop that goes in its place? Also the clutch stop i have is a simple plactic disc with no adjustment. Is there a common adjustable option? Quote Share this post Link to post Share on other sites
UBH8N 0 Report post Posted October 27, 2013 Are e30 FL and PFL bonnets interchangeable or are they a different design? Quote Share this post Link to post Share on other sites
euroriffic 630 Report post Posted October 27, 2013 They're interchangable. Had a red pfl on my silver facelift Quote Share this post Link to post Share on other sites
_Matt_ 42 Report post Posted October 27, 2013 You want a timesert or an oversized insert. Spring style inserts (like helicoil brand are) can cause a lot of issues later. If you have the space, you can drill it bigger, screw in some threaded rod, then drill and tap to suit., VERY carefully. That's not a bad idea, I was thinking I could even use a smaller bolt rather than m6 since i have limited width to work. e.g m6 insert m4 bolt but yes i would have to be very careful. this is probably a last resort. Which engine was this? If just one of four bolts holding pump, sometimes best bet is run with 3 bolts its an m30 so 6 bolts in total, one of which is buggered. all bolts have to be torqued to 9 NM +/- 1NM so its still possible to fix (fingers crossed). Quote Share this post Link to post Share on other sites
m325i 732 Report post Posted November 9, 2013 Yo, Can you swap you front and rear wheels without have to rebalance or align? My balance/alignment is good, but I have a bit of inner rear camber wear. So if i put the front wheels and tyures on the back would that be sweet? Cheers Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2153 Report post Posted November 9, 2013 Yo, Can you swap you front and rear wheels without have to rebalance or align? My balance/alignment is good, but I have a bit of inner rear camber wear. So if i put the front wheels and tyures on the back would that be sweet? Cheers You dont need to rebalance of align if you do that. That said, would I do it? No. your front tyres are the ones you use to stop and turn, id rather have the maximum amount of tread i can thanks. plus you will just end up with 4 tyres with bald inner shoulders, then what do you do Quote Share this post Link to post Share on other sites
