Eagle 1776 Report post Posted June 15, 2024 14 hours ago, Palazzo said: No room either way. Full disclosure, it’s a rowing machine. Tried vice grips. Think the best way is to cut a slot in like Neil suggested. Where do you buy a multi tool? If you can cut a slot in it then you should be able to cut it most of the head off easy with the right tool. A dremel type tool or die grinder would work best using carbide bits but a cutting disc can work to grind down small stuff. Quote Share this post Link to post Share on other sites
Palazzo 522 Report post Posted June 16, 2024 5 hours ago, topless said: I use a torx male socket to get these out with reasonable success (come across this quite often). Hammer a slightly oversize one into the hole and then carefully try to get it to shift slightly backwards and fowards before trying to fully undo it. Give the head of the stripped allen key bolt a good number of axial blows before hammering in the torx socket as this will help shock the binding threads loose. Thanks Will, that did the trick. 2 hours to remove 9 bolts, including digging up my grandfathers 9/16 open ended spanner. Only to find the last bolt has an end missing and simply turns and turns and turns… guess I’ll just have to mask more off. 1 Quote Share this post Link to post Share on other sites
Toksis 3 Report post Posted June 24, 2024 Ok i want to change my front shocks to the msport shocks. Can I just change the shocks per se? Nothing else It is compatible? E90 normal shocks to msport. Thanks! Quote Share this post Link to post Share on other sites
gjm 3300 Report post Posted September 5, 2024 (edited) 2013 F20 116i. Just been for a WoF, passed with no issues at all. Next day... Dashboard does a poor impression of a Christmas Tree. Poor because it's only a few lights. Speed limiter is also not working. The ol' IT standby - turn it off and turn it n again - clears it temporarily. Cleared yesterday, used this morning without issue, came back this evening. Before anyone asks - I don't have immediate access to a code reader! ABS issue, speed sensor, brake pad wear sensor...? Edit: Going to check tyre pressures ASAP. iDrive hasn't mentioned them as an issue, but the warning light is on and it's an easy thing to check. Edited September 5, 2024 by gjm Update Quote Share this post Link to post Share on other sites
KwS 2448 Report post Posted September 5, 2024 Duff ABS sensor or other ABS issue would be my guess. TPMS was measured by the wheel speed sensors on the older BMWs, so i presume the F20 is the same. Gonna have to scan it. Quote Share this post Link to post Share on other sites
Olaf 3415 Report post Posted September 5, 2024 14 hours ago, gjm said: 2013 F20 116i. Just been for a WoF, passed with no issues at all. Next day... Dashboard does a poor impression of a Christmas Tree. Poor because it's only a few lights. Speed limiter is also not working. The ol' IT standby - turn it off and turn it n again - clears it temporarily. Cleared yesterday, used this morning without issue, came back this evening. Before anyone asks - I don't have immediate access to a code reader! ABS issue, speed sensor, brake pad wear sensor...? Edit: Going to check tyre pressures ASAP. iDrive hasn't mentioned them as an issue, but the warning light is on and it's an easy thing to check. After a scan - my first port of call would be battery. Modern BMW (like E60 onwards) very sensitive to voltage and bad batty the source of many gremlins. Be sure to code to the car if you change it out. You're into modern BMW ownership, you need a scan tool. 1 Quote Share this post Link to post Share on other sites
gjm 3300 Report post Posted September 5, 2024 2 hours ago, Olaf said: After a scan - my first port of call would be battery. Modern BMW (like E60 onwards) very sensitive to voltage and bad batty the source of many gremlins. Be sure to code to the car if you change it out. You're into modern BMW ownership, you need a scan tool. My first thought was battery, too. Andy suggested tyre pressures - valid, and easy to check. Miss M has a modern BMW. Dad needs a scan tool. 🤣 Quote Share this post Link to post Share on other sites
gjm 3300 Report post Posted September 10, 2024 In the absence of appropriate tools to do a job, consult someone who does have them and knows how to use them. Visit to Greg at GH Automotive in Hastings, quick scan and.. Right rear wheel speed sensor Right rear wheel speed sensor Right rear wheel speed sensor Right rear wheel speed sensor Right rear wheel speed sensor Right rear wheel speed sensor We looked at each other. "So. What do think might be the problem?" (I also learned that there's a speed sensor on all 4 wheels which in hindsight makes sense. For some reason I'd been thinking there was a right rear, and a left front.) Hopefully be sorted later today. Quote Share this post Link to post Share on other sites
Gaz 1076 Report post Posted September 10, 2024 38 minutes ago, gjm said: (I also learned that there's a speed sensor on all 4 wheels which in hindsight makes sense. For some reason I'd been thinking there was a right rear, and a left front.) You're thinking of brake pad wear sensors 1 Quote Share this post Link to post Share on other sites
gjm 3300 Report post Posted September 10, 2024 3 hours ago, Gaz said: You're thinking of brake pad wear sensors 'cos there's only pads on 2 wheels...? But yes. Quote Share this post Link to post Share on other sites
KwS 2448 Report post Posted September 10, 2024 Called it 😁 1 Quote Share this post Link to post Share on other sites
Toksis 3 Report post Posted December 2, 2024 Is this tyre repair good? Thanks Quote Share this post Link to post Share on other sites
Palazzo 522 Report post Posted December 7, 2024 Are all e36 fuel pumps the same? 6cyl ones at least? Quote Share this post Link to post Share on other sites
Harper 603 Report post Posted December 8, 2024 39 minutes ago, Palazzo said: Are all e36 fuel pumps the same? 6cyl ones at least? All the same, 16146758736 Quote Share this post Link to post Share on other sites
Palazzo 522 Report post Posted December 8, 2024 Thanks, hopefully that’s the problem. Quote Share this post Link to post Share on other sites
Toksis 3 Report post Posted January 7 Where is the low pressure AC port and High pressure AC port of E90 n46 2006? Thanks! Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted January 7 17 hours ago, Toksis said: Where is the low pressure AC port and High pressure AC port of E90 n46 2006? Thanks! front right corner and back left corner Quote Share this post Link to post Share on other sites
Twistee 500 Report post Posted February 21 Can anyone recommend an electroplater that does Gold Zinc Passivate? I have a pile of nuts, bolts, pipes etc that I would like to have re-plated. Quote Share this post Link to post Share on other sites
gjm 3300 Report post Posted February 21 There's a few around. I contacted George at Advanced Chrome Platers in Hamilton and he did a fabulous job for me. (He also does wheel rim repairs.) He has (or had) a website but that doesn't seem to be working at present. Facebook page exists but hasn't been updated in several years: https://www.facebook.com/p/Advanced-Chrome-Platers-100059898652085/ I know that 10 years or so ago he was concerned that while he wasn't planning retirement, there seemed zero interest from anyone to take over the business. The business is still listed as current at Companies House. 1 Quote Share this post Link to post Share on other sites
BMWALEX478 0 Report post Posted March 2 2007 e87 130i Ive got a rough idle and codes for air mass system and went to give the MAF sensor a quick clean when I noticed one of the connector pins seems to be missing. Anyone got the part number for the connector and do you think that's the issue? Thanks Quote Share this post Link to post Share on other sites
Spinner99 67 Report post Posted March 2 Maybe give it a quick check to make sure it has 5 wires going into it (not all connectors use all pins). Assuming it does, hopefully there's a way for you to re-pin it without having to replace it? Quote Share this post Link to post Share on other sites
BMWALEX478 0 Report post Posted March 4 Ive done a bit of research and I found one thing that said there are only supposed to be four of the five but there is no proper information on it. Could someone with a N52 please send through a photo of their plug connector like I have and please tell me if you have the facelift or not. (I have the LCI) Thanks. Quote Share this post Link to post Share on other sites
deedub 135 Report post Posted May 15 Just noticed that my coolant reservoir cap on my 98 E36 318is has a 1.4 bar cap. Checked real oem and it should be 2.0 bar. Trying to understand if there's a reason PO would intentionally replace with lower pressure cap. May have just been the best option available. Does anyone know if there are benefits to 1.4 over 2.0? Or if it even matters much? Quote Share this post Link to post Share on other sites
Vass 1059 Report post Posted May 15 It's been a topic of debate around the forums for a good while. Some see it as an "upgrade", the logic being lower pressure = less strain on the plastic & rubber components in the cooling system = longer life for the cooling system components. The counter argument is that lower pressure = lower boiling point = higher chance of vapours in the system. Gases don't transfer heat nearly as efficiently as fluids, leading to localised hot spots or hot pockets in the engine, which obviously isn't good. I'm far from an expert but from what I gather you'll probably be fine running with either option if the car only sees light everyday use. It'd take quite a bit of bashing to get it to the extremes where the difference would start to show so you get two camps of people who claim to have run with their preference for years and have never had issues. Personally, I like to preventatively replace the main failure prone cooling system components and stick with the cap the car was designed for. 1 Quote Share this post Link to post Share on other sites
gjm 3300 Report post Posted May 15 43 minutes ago, deedub said: Just noticed that my coolant reservoir cap on my 98 E36 318is has a 1.4 bar cap. Checked real oem and it should be 2.0 bar. Trying to understand if there's a reason PO would intentionally replace with lower pressure cap. May have just been the best option available. Does anyone know if there are benefits to 1.4 over 2.0? Or if it even matters much? Suspect it was as much as case of using a cap that was available as much as anything else. As suggested, stick with original spec if possible. Quote Share this post Link to post Share on other sites
