Gaz 1075 Report post Posted August 2, 2010 Do TV on one side and gold on the other so if you change your mind you can just turn the car around Quote Share this post Link to post Share on other sites
Forrest 35 Report post Posted August 2, 2010 ^ Haha comedian. I have split all four wheels, I am just busy writing a spiel on the way I found easiest to split them up. Quote Share this post Link to post Share on other sites
Jamez 2147483647 Report post Posted August 2, 2010 I found a metal hammer the easiest way, but then I wasn't reusing the lips Quote Share this post Link to post Share on other sites
Forrest 35 Report post Posted August 2, 2010 I now have four wheels totally split up. Here is my best method to tackle it with some associated pics, obviously there are a few shortcuts to what I did, but I was trying to minimize extra costs. 1. Spray with penetrate spray before hand on all bolts and nuts both side. Take a 8mm 12pt ring spanner on the front bolt, a 10mm 12pt socket with ratchet attached, undo and push the bolts out (you may need a hammer and nail punch), repeat 30 times per wheel. 2. Take the tyre valve out. A 14mm spanner on the front of the valve, a big flat head screwdriver on the rear to hold it in place, undo and push out, a couple of mine were so loose, no wonder the tyres were leaking air Be careful you don't damage the seal, they are about $40 each to replace. 3. Mark the three bits of the wheel so you can put it back in essentially the same place so it is easier to re-balance. Also label the wheel so you don't get them all mixed up. 4. Next, tackle taking the front lip off. You will see a small bead of silicone on the wheel, cut this off and cut a little into the wheel with a stanley knife/razor blade. Then get a heat gun (mine is heat adjustable, so I found 350deg worked great, run it around the siliconed area you just cut into. Get your chosen BFH and wack the sh*t behind the lip and it should crack off after a few hits on opposing sides of the wheel. 4. For the center piece removal, repeat the above steps but don't hit it with a hammer put a blanket/towel on the ground then a old tyre, put the wheel face down then wack it with a big block of wood right in the middle near the wheel bolt holes and eventually it will crack loose, watch out for splinters. 5. You will now have your wheels in 3 bits, repeat this four times and then get ready for prep and paint. That's all for now Quote Share this post Link to post Share on other sites
Mark 178 Report post Posted August 2, 2010 Here's my way of doing it: Step 1: Take wheels to shop Step 2: Hand over blank cheque Step 3: New wheels! Admire your dedication Nath... I don't trust myself to not f**k it up. Quote Share this post Link to post Share on other sites
pjay 8 Report post Posted August 3, 2010 Pr if you want a REALLY flash ass job. Black cheque this man: http://wokke.de/ and have them widened at the same time. Quote Share this post Link to post Share on other sites
CamB 48 Report post Posted August 3, 2010 Good stuff 3. Mark the three bits of the wheel so you can put it back in essentially the same place so it is easier to re-balance. Also label the wheel so you don't get them all mixed up. Suggest you do this with something that will survive the painting or polishing precedures to come. Quote Share this post Link to post Share on other sites
kerry 10 Report post Posted August 3, 2010 nice job so far , they are going to look sweeeet Quote Share this post Link to post Share on other sites
bravo 35 Report post Posted August 3, 2010 Do you have to use the valves that came with the wheels? new valves are throw-away consumable items at most tyre shops. The place I go puts new ones in for free every time I get new tyres. Quote Share this post Link to post Share on other sites
Forrest 35 Report post Posted August 3, 2010 ^ Um I don't think so. But these metal BBS ones are baller Quote Share this post Link to post Share on other sites
Lucan 196 Report post Posted August 3, 2010 +1 I have the Baller BBS valves too. Never mind those huge black ugly ones Quote Share this post Link to post Share on other sites
Forrest 35 Report post Posted August 3, 2010 Spent the afternoon cleaning one wheel and removing all old gasket sealant. Taking my time with this stage because the wheels are worthless if they don't seal properly, miles well throw them away. Used a scotch brite pad with some brake cleaner and a hose for general cleaning, then turps and a scraper to remove all the gasket sealant, finishing off by preparing all sealed surfaces by scuffing them up with 150grit sandpaper to give a nice key for the gasket sealant to stick to when I seal them together. Now starting to sand the centers to prep for primer. Pics to come when I have done all four. Quote Share this post Link to post Share on other sites
gouba 0 Report post Posted August 3, 2010 (edited) if you root up the valve stems, Harley Davidson has replacement stems that supposedly fit (cheaper than $40 a pop as well) Edited August 3, 2010 by gouba Quote Share this post Link to post Share on other sites
Forrest 35 Report post Posted August 3, 2010 ^ Good to know. Got all four wheels stripped and de-gasketed. Start sanding the centers tomorrow for primer if I get time before uni, aiming to have these clearcoated this time next week then mounted on the car before the weekend. In other news I am allowed to bring my E30 home and out of storage for the first time in 3 months. Can't wait. Quote Share this post Link to post Share on other sites
zenetti 0 Report post Posted August 3, 2010 dude you change your mind so many times I think you should just send the wheels back to me Quote Share this post Link to post Share on other sites
Forrest 35 Report post Posted August 3, 2010 (edited) ^ Wouldn't you be inclined to change your mind if you decided to paint yours purple originally then realised how much work and time is spent dissassembling and reassembling? and the fact I am not doing it again in a hurry haha. Now I see why most people pay others to do this haha. Clearly my threads are becoming an excuse for all you to rip the sh*t outta me, I'm kinda over it, why should I bother sharing my knowledge? Edited August 3, 2010 by Brams Quote Share this post Link to post Share on other sites
Guest Simon* Report post Posted August 3, 2010 Nath when you've finished your writeup and stuff let me know and I'll cleanse your thread of all the posts you want out In the meantime here's some more nice bright TV for ya Quote Share this post Link to post Share on other sites
bellicose 9 Report post Posted August 3, 2010 Clearly my threads are becoming an excuse for all you to rip the sh*t outta me, I'm kinda over it, why should I bother sharing my knowledge? Take no notice of them mate. Paint them whatever colour ya like, they arn't their rims and i can understand you want to make sure 'bout the colour. Do it once and do it right. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted August 3, 2010 Take no notice of them mate. Paint them whatever colour ya like, they arn't their rims and i can understand you want to make sure 'bout the colour. Do it once and do it right. +1 Nathan Quote Share this post Link to post Share on other sites
Jamez 2147483647 Report post Posted August 3, 2010 Nathan it looks like you have the fat (normal) valves that can be bought for a few dollars, these are what my thin valves look like, they have a smaller hole. I found when getting new lips from germany that they come with the narrow valve holes that cant fit normal valves this can be corrected by getting a bigger hole drilled. My RS033's have narrow valves but my RS001's and RS003's have the same valves you got. Smaller valve With valve cap Quote Share this post Link to post Share on other sites
zenetti 0 Report post Posted August 3, 2010 Clearly my threads are becoming an excuse for all you to rip the sh*t outta me, I'm kinda over it, why should I bother sharing my knowledge? Dude, chill out, I thought you of all people would have realised it was a tongue in cheek comment. It was just a bit of friendly natured banter As other pople have said do what ever you want but just make sure you do it once and do it right. Quote Share this post Link to post Share on other sites
pureboiracer 0 Report post Posted August 3, 2010 purple all the way imo. Quote Share this post Link to post Share on other sites
JFry 1 Report post Posted August 3, 2010 purple all the way imo.+1, good on ya for giving it a go yourself Quote Share this post Link to post Share on other sites
Forrest 35 Report post Posted August 4, 2010 Made some non related wheel progress today. Finished painting the F/L genuine Alpina rear wing in Tech1 wing style with a Platanengrun Metallic insert. Pics to come when the paint dries. Quote Share this post Link to post Share on other sites
Forrest 35 Report post Posted August 4, 2010 Winner winner chicken dinner. God it is hard to get a good finish in a freezing garage and it's 6deg outside. Not perfect but perfect enough for me, the perfectionist. Quote Share this post Link to post Share on other sites
