lemusa 86 Report post Posted October 17, 2020 Definitely keen to have a beer when you're passing through! Quote Share this post Link to post Share on other sites
BreakMyWindow 1995 Report post Posted October 27, 2020 Sold the Eisenmann mufflers to help fund the suspension refresh. Back to stock which is quite pleasant cruising around the city... getting old. Plan down the track is to fit headers and a tune. I think with stock mufflers it will have just the right amount of angry. 4 1 Quote Share this post Link to post Share on other sites
BreakMyWindow 1995 Report post Posted November 4, 2020 Let the fun begin! 9 Quote Share this post Link to post Share on other sites
Sammo 2616 Report post Posted November 4, 2020 Jesus, that looks like a lot of work ? 1 Quote Share this post Link to post Share on other sites
hunter 413 Report post Posted November 4, 2020 imagine how toight it'll feel after all those goodies go in. 1 Quote Share this post Link to post Share on other sites
adro 1127 Report post Posted November 4, 2020 Santa came early! Wow, what a haul. 1 Quote Share this post Link to post Share on other sites
leichtbau 525 Report post Posted November 4, 2020 Serious flex with the exchange rate as it is! Quote Share this post Link to post Share on other sites
Matth5 471 Report post Posted November 5, 2020 That must have hurt the wallet, but I'm sure the M5 deserves it Quote Share this post Link to post Share on other sites
BreakMyWindow 1995 Report post Posted December 17, 2020 The fun actually began today. Thought I could do the entire rear axle but only managed to sort out one rear corner before getting too tired and over it. After 21years and 197k kms the larger control arm balljoint and the shock was F’d. The rest was actually ok but since I only ever want to do this sort of job once, may as well do it all. Hopefully get the other rear corner sorted tomorrow then on to the front, which I think is alot easier in terms of access to nuts and bolts. 5 Quote Share this post Link to post Share on other sites
zero 1162 Report post Posted December 17, 2020 What engine is going in the mk1? Quote Share this post Link to post Share on other sites
balancerider 845 Report post Posted December 18, 2020 Those rear brakes look tiny for a 400hp sedan with a V8 in the front! Quote Share this post Link to post Share on other sites
KwS 2450 Report post Posted December 18, 2020 1 hour ago, balancerider said: Those rear brakes look tiny for a 400hp sedan with a V8 in the front! Google seems to indicate they are 328mm rotors, so not that small! Quote Share this post Link to post Share on other sites
BreakMyWindow 1995 Report post Posted December 18, 2020 Managed to conquer the rear axle today. Much like the lhs the shock and control arm balljoint were f’d. The lower swingarm balljoint was looser than the lhs one. Made a start on the front too. So far the lhs shock and control arm are f’d. The thrust arm balljoint and bush (x5 item swapped out 3 years ago) are fine, along with the drag link and tie rod ends still feel ok so may leave those and replace when actually needed. In the last pic I forgot to fit the strut mount bearing. Was a sign to finish up for the day. Hopefully wrapped up tomorrow. 4 Quote Share this post Link to post Share on other sites
BreakMyWindow 1995 Report post Posted December 18, 2020 On 12/18/2020 at 12:26 AM, zero said: What engine is going in the mk1? Not my project so don’t really want to spill... 1 Quote Share this post Link to post Share on other sites
BreakMyWindow 1995 Report post Posted December 19, 2020 And done! Didn’t do the steering linkages as they were ok but put a tear in one of the outer tierod balljoint boots 🤦♂️ Something to worry about next year. Hopefully get an alignment next week.. 4 Quote Share this post Link to post Share on other sites
NUSTAD 243 Report post Posted December 19, 2020 (edited) Any initial observations on how it feels compared to before? Nice work BTW! Edited December 19, 2020 by NUSTAD Quote Share this post Link to post Share on other sites
BreakMyWindow 1995 Report post Posted December 20, 2020 2 hours ago, NUSTAD said: Any initial observations on how it feels compared to before? Nice work BTW! Feels waaaay better over dips and bumps. Definitely “tighter” 3 Quote Share this post Link to post Share on other sites
BreakMyWindow 1995 Report post Posted December 22, 2020 Over the past couple of days the front suspension developed a bit of a knocking noise over bumps at low speed. Turns out the front arms on the bushing ends weren’t quite torqued enough. Whew. Had the pro’s at P&S autocentre correct this and do a wheel alignment. Suspension refresh is now wrapped up. Quote Share this post Link to post Share on other sites
zero 1162 Report post Posted December 23, 2020 Your toe was way out. It must drive so much better now 1 Quote Share this post Link to post Share on other sites
BreakMyWindow 1995 Report post Posted December 29, 2020 Couldn’t really call it done without replacing all the steering linkages. New tyres all round tomorrow too. Current tyres seemed to have worn in a way that makes the car feel a bit nervous over ruts and bad patches of road, probably due to stuffed shocks. Quote Share this post Link to post Share on other sites
hunter 413 Report post Posted December 29, 2020 1 hour ago, BreakMyWindow said: Couldn’t really call it done without replacing all the steering linkages. New tyres all round tomorrow too. Current tyres seemed to have worn in a way that makes the car feel a bit nervous over ruts and bad patches of road, probably due to stuffed shocks. You’re running Michelin’s aye mate. The ps4 ? my car has them. Only a few months old and I find the quite tram line prone. Quote Share this post Link to post Share on other sites
BreakMyWindow 1995 Report post Posted December 29, 2020 1 hour ago, hunter said: You’re running Michelin’s aye mate. The ps4 ? my car has them. Only a few months old and I find the quite tram line prone. Yep, hmm ordered some more. Quote Share this post Link to post Share on other sites
Eagle 1787 Report post Posted December 29, 2020 10 hours ago, hunter said: You’re running Michelin’s aye mate. The ps4 ? my car has them. Only a few months old and I find the quite tram line prone. 3 sets on my old E39 and never felt that to be the case. Quote Share this post Link to post Share on other sites
str8_6 278 Report post Posted December 29, 2020 Have the PS4’s on my M5 and love them. No issues with tram lining. Quote Share this post Link to post Share on other sites
BreakMyWindow 1995 Report post Posted January 1, 2021 New tyres on and much better with basically no tramlining. Unfortunately the tyre shop scratched the rear wheels fitting the tyres so that’s getting sorted some time next week. They also torqued every wheel up gorilla FT. F’ing muppets 🤦♂️ Over sharp bumps the front wheels would squeak which was annoying, but not anymore after cleaning up the brake pad “ears” and their contact points on the calliper, and calliper retaining bracket. Then I applied some anti squeal paste to those areas. Another niggly but annoying thing ticked off the list. 4 Quote Share this post Link to post Share on other sites
