*Glenn* 856 Report post Posted April 8, 2016 So sorry for you after all your hard work. My heart goes out to you and I give you credit for everything you have gone through and done. My hat goes of to you. The broken spring, I'm sure is the result rather than the cause 3 Quote Share this post Link to post Share on other sites
zero 1162 Report post Posted April 8, 2016 That's really sad news. I've heard of three potentially relevant causes for valve spring failure: Over-revving (although I don't see how this would break a spring - maybe localised heat build-up?) Poor quality metal used in manufacture Rust on the spring (which can result in failure in the same way a stress fracture would) Could the spring have been exposed to damp while the engine was in pieces? It certainly wasn't over revved. I tried to protect the springs by keeping them soaking in jars of simple green before they were installed, and then when they were installed I coated then in crc or oil. But yeah, building the engine under my house it probably gets a bit damp under there. I don't suppose simple green concentrate damaged the spring, but who knows? 1 Quote Share this post Link to post Share on other sites
zero 1162 Report post Posted April 8, 2016 So sorry for you after all your hard work. My heart goes out to you and I give you credit for everything you have gone through and done. My hat goes of to you. The broken spring, I'm sure is the result rather than the cause Thanks Glenn for your kind words. What do you mean by 'result rather than cause'? I would have thought that if a collet came off it would have done so on first start straight after the rebuild? It was running smooth as before it went pop. Quote Share this post Link to post Share on other sites
KwS 2450 Report post Posted April 8, 2016 That sucks man, i was so hoping you had sorted the issues once and for all. 2 Quote Share this post Link to post Share on other sites
polley 916 Report post Posted April 8, 2016 That really sucks. 1 Quote Share this post Link to post Share on other sites
BM WORLD 1296 Report post Posted April 8, 2016 AH CRAP , that would really pi$$ me off . sorry for your loss , after all your work. 1 Quote Share this post Link to post Share on other sites
Ahmedsinc 414 Report post Posted April 8, 2016 Fuuuuuuuuuhhhck! 1 Quote Share this post Link to post Share on other sites
Olaf 3426 Report post Posted April 8, 2016 bummer, Nathan. sorry to hear of that. something better will come. 1 Quote Share this post Link to post Share on other sites
Allanw 1081 Report post Posted April 8, 2016 Bummer dude - that wasn't something I expected to happen!!! Guy Fawkes is still quite a few months away yet! If it was only idling, it may still be worth opening back up and see how bad the damage is. 1 Quote Share this post Link to post Share on other sites
Ahmedsinc 414 Report post Posted April 8, 2016 Interesting that the spring shear points are aligned with each other. Is there a possibility a collet might have been misaligned leaving the spring cap at an angle? Does seem pretty strange it would choose to let go at idle - I've seen the debris of an over-rev causing valve float and piston death, quite similar to your failed spring but the fractures weren't on the same plane. If you can bring yourself to conduct an autopsy I'd be fascinated to see the resulting carnage in the cylinder and on the crank. Did the engine entirely seize? 1 Quote Share this post Link to post Share on other sites
zero 1162 Report post Posted April 8, 2016 Interesting that the spring shear points are aligned with each other. Is there a possibility a collet might have been misaligned leaving the spring cap at an angle? Does seem pretty strange it would choose to let go at idle - I've seen the debris of an over-rev causing valve float and piston death, quite similar to your failed spring but the fractures weren't on the same plane. If you can bring yourself to conduct an autopsy I'd be fascinated to see the resulting carnage in the cylinder and on the crank. Did the engine entirely seize? Engine didn't seize but made terrible noises and the cylinder 4 spark plug became stuck in the head. When I tried to remove the plug it was so tight it felt like it threaded itself and its still in there. I would have thought a poorly aligned collet would have let go straight away - not 150kms after the rebuild? If I can bring myself to look at the motor I will pop the head and take photos. Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted April 8, 2016 Absolute bummer Nathan. I would certainly throw my toys if that happened. So bloody frustrating after all your time, money & patience. 1 Quote Share this post Link to post Share on other sites
Ahmedsinc 414 Report post Posted April 9, 2016 Engine didn't seize but made terrible noises and the cylinder 4 spark plug became stuck in the head. When I tried to remove the plug it was so tight it felt like it threaded itself and its still in there. I would have thought a poorly aligned collet would have let go straight away - not 150kms after the rebuild? If I can bring myself to look at the motor I will pop the head and take photos. I'd be inclined to agree, though sometimes strange stuff happens. Really feel for ya dude! 1 Quote Share this post Link to post Share on other sites
BreakMyWindow 1999 Report post Posted April 9, 2016 It's a real kick in the nuts, but definitely give yourself a pat on the back for giving it your best shot. I'm sure you've learned alot through the whole ordeal which will prove invaluable on future projects. 1 Quote Share this post Link to post Share on other sites
Ahmedsinc 414 Report post Posted April 16, 2016 Whats the latest? Outright replacing the car or are you gonna do the B25 transplant? Quote Share this post Link to post Share on other sites
zero 1162 Report post Posted April 16, 2016 Bought another car to tide me over. Another black motorsport e46 wagon, but with a m54b25 in it. I need to pull the head off my car and have a look before I settle on which direction I'm gonna go, but its now officially a project car. Will either put the m54 from the parts car in it or go full retard and squeeze in a m60 or m62. I've just been so busy with work, and helping a mate with his e36, that I haven't had the time (or the heart) to pull the head yet. 5 Quote Share this post Link to post Share on other sites
K13r4n 1 Report post Posted April 16, 2016 Just read through the entire thread and holly f*ck. What a legend, so sorry it didn't work out man. 1 Quote Share this post Link to post Share on other sites
Ahmedsinc 414 Report post Posted April 17, 2016 Bought another car to tide me over. Another black motorsport e46 wagon, but with a m54b25 in it. I need to pull the head off my car and have a look before I settle on which direction I'm gonna go, but its now officially a project car. Will either put the m54 from the parts car in it or go full retard and squeeze in a m60 or m62. I've just been so busy with work, and helping a mate with his e36, that I haven't had the time (or the heart) to pull the head yet. f**k it dude, just junk it - you'll only lose more time and energy obsessing over something thats already dead. Trouble with the M6x transplants into the E36/46 is the subframe vs sump issue. How about a single Vanos 3l stroked turbo M50? Better power, more torque and no engineering issues. Better yet, how about an LS1? 1 Quote Share this post Link to post Share on other sites
zero 1162 Report post Posted April 17, 2016 f**k it dude, just junk it - you'll only lose more time and energy obsessing over something thats already dead. Trouble with the M6x transplants into the E36/46 is the subframe vs sump issue. How about a single Vanos 3l stroked turbo M50? Better power, more torque and no engineering issues. Better yet, how about an LS1? Its a good car, just needs a repower. Could go the stroked 6 route too. Wont go ls1 because its blasphemy to put a holden motor in a bmw. The only car I would put a chevy engine into would be a hotrod or a kit car. Quote Share this post Link to post Share on other sites
Olaf 3426 Report post Posted April 17, 2016 Its a good car, just needs a repower. Could go the stroked 6 route too. Wont go ls1 because its blasphemy to put a holden motor in a bmw. The only car I would put a chevy engine into would be a hotrod or a kit car. like a TVR? 1 Quote Share this post Link to post Share on other sites
BreakMyWindow 1999 Report post Posted April 20, 2016 f**k it dude, just junk it - you'll only lose more time and energy obsessing over something thats already dead. Trouble with the M6x transplants into the E36/46 is the subframe vs sump issue. How about a single Vanos 3l stroked turbo M50? Better power, more torque and no engineering issues. Better yet, how about an LS1? Modified e39 v8 subframe and boom. 1 Quote Share this post Link to post Share on other sites
zero 1162 Report post Posted May 30, 2016 So after much umming and ahhing I've made a decision. The car will become a project car and will get a m60/m62 and getrag 420g conversion. This will be a long and expensive process, but it means I can take my time and do it right, and pick up the parts needed when they come available for cheap. In the meantime I have a daily driver so there is no rush. To help fund raise I am wrecking my parts car. If you want to help you can buy some parts of it; http://bimmersport.co.nz/topic/56147-wrecking-2001-325i-wagon/ Also I've never done a v8 swap into an e46, so any knowledge would be appreciated. The internet has a bit of info, but you cant beat info from bimmersport members who have first hand know how. I know subframe will have to either be swapped/modified or the sump modified to fit. And if I go down the modified sump route then custom engine mounts have to be used. Car will get brake and suspension upgrade, as well as chassis strengthening. Quote Share this post Link to post Share on other sites
qube 3570 Report post Posted May 30, 2016 ill just put this link here.. http://www.trademe.co.nz/motors/car-parts-accessories/bmw/engines/auction-1095282231.htm 3 Quote Share this post Link to post Share on other sites
gjm 3300 Report post Posted May 30, 2016 ill just put this link here.. http://www.trademe.co.nz/motors/car-parts-accessories/bmw/engines/auction-1095282231.htm You're a bad man. A very, very bad man. But I like you. 1 Quote Share this post Link to post Share on other sites
