Jamez 2147483647 Report post Posted January 25, 2016 Sorry about the site downtime, have had issue over the last week with servers getting to hot. Have disabled thermal shutdown until a resolve for the cooling issues is found. 5 Quote Share this post Link to post Share on other sites
eliongater 718 Report post Posted January 25, 2016 Thanks for the update Quote Share this post Link to post Share on other sites
gjm 3300 Report post Posted January 25, 2016 You're not alone.I've seen corporate data centres with portable industrial fans in them to try and keep temps down. 1 Quote Share this post Link to post Share on other sites
Olaf 3428 Report post Posted January 25, 2016 indeed, thanks for the update, and all the hard work you do to keep things running. hopefully disabling thermal shutdown protection doesn't put your kit at risk. 1 Quote Share this post Link to post Share on other sites
Ahmedsinc 414 Report post Posted January 25, 2016 Would rather see the site vanish for a wee bit than risk you guys nuking your gear! You're not alone.I've seen corporate data centres with portable industrial fans in them to try and keep temps down. Lol, have worked in small server rooms in the past with IT guys running in carrying multiple $20 fans from the Warehouse in desperation. Then going into utter panic mode when the current draw from the fans is enough to trip the RCD on the wall outlet. Schadenfreude ftw!! 1 Quote Share this post Link to post Share on other sites
Nobimmer 694 Report post Posted January 25, 2016 Nerrrrr lag Quote Share this post Link to post Share on other sites
Matth5 471 Report post Posted January 25, 2016 Have disabled thermal shutdown until a resolve for the cooling issues is found. That seems risky. Probably due to the unusually hot weather we've been having. Quote Share this post Link to post Share on other sites
hybrid 1045 Report post Posted January 25, 2016 All good, jamez has been spraying water on it instead, seems legit. 8 Quote Share this post Link to post Share on other sites
BreakMyWindow 2003 Report post Posted January 25, 2016 switch to 5w 30 5 Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2153 Report post Posted January 25, 2016 Fans dont work over the long term, they just blow the hot air around and make it even warmer, need a solution to get the heat outside. Only way is to throttle back performance really. Quote Share this post Link to post Share on other sites
Neal 576 Report post Posted January 26, 2016 maybe a second hand Coke machine and install gear inside. Only would need to chill to about 20 degrees ? Quote Share this post Link to post Share on other sites
polley 916 Report post Posted January 26, 2016 Only way is to throttle back performance really. Heat pump in our server room seems to work fine. It's only small room though, its no DC. Quote Share this post Link to post Share on other sites
eliongater 718 Report post Posted January 26, 2016 Heat pump in our server room seems to work fine. It's only small room though, its no DC.A heat pump brings in cold air (whilst making outside warmer). I think what Andy was meaning the fans in the servers themselves and the portable fans that only blow the air around, which cools the air by heating everything in the room up if the air can't get outside. So when everything in the room heats up the fans become ineffective as there is nowhere for the heat to go.Or something to that effect Quote Share this post Link to post Share on other sites
e30ftw 435 Report post Posted January 27, 2016 1 Quote Share this post Link to post Share on other sites
Allanw 1082 Report post Posted January 27, 2016 You should install a complex liquid cooling system, running under a great pressure, and use lots of economical plastic to do it. Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2153 Report post Posted January 27, 2016 Having said that, Bimmersport is hardly a high demand website, not does it require a datacenter to keep the wheels turning. What does it run off James? or is it hosted through your work? Quote Share this post Link to post Share on other sites
Jamez 2147483647 Report post Posted January 27, 2016 It's running off a virtual server on my blade cluster which is in a C3000 blade chassis at Hampton Downs. I am looking at moving it to a cluster at work though. Traffic wise, the VPS has moved quite a bit in just under 2 days. 16:32:40 up 1 day, 18:14, RX packets 51717195 bytes 54970010770 (51.1 GiB) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 24506792 bytes 7954451946 (7.4 GiB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2153 Report post Posted January 27, 2016 It's running off a virtual server on my blade cluster which is in a C3000 blade chassis at Hampton Downs. On the whole they seem to be pretty reliable but i can see why you are having heat issues. Let me know if you get fan/psu/components fail as we have those come through work and ones similar. Probably have some more blades for it too if not populated. Im sure i can donate to keep Bimmersport running. 3 Quote Share this post Link to post Share on other sites
