jeffbebe 1587 Report post Posted October 19, 2014 Yeah, a 23 year old rubber joint (assuming it's never been replaced) isn't going to be great and you can bet those plastic spindles are forked as well. Quote Share this post Link to post Share on other sites
jeffbebe 1587 Report post Posted October 20, 2014 They had the top spindle in stock at BM Workshop - $25. Now that I've seen it, I know exactly what's wrong with the old one... All of the tabs are broken so the centre (rotating) part is loose, that means it pops out when the wheel is adjusted fully in and the column can move freely where it was. They're probably broken because of the deeper issue of play from the universal joint which is amplifying small bumps into the road into major shakes at the wheel. New universal joint on order ex-Germany. Quote Share this post Link to post Share on other sites
jeffbebe 1587 Report post Posted October 23, 2014 (edited) Tidying up the engine bay at the moment in preparation for Bimmerfest on Nov 15-16. Starting with the engine cover. So far I've attacked it with some rough sandpaper, will be moving onto some fine finishing paper before repainting. Got my helpers in on the action: The rubber gasket that attaches to it so it fits snugly over the manifolds is in pretty good nick but has a crispy coating of old, brown grease/oil which I'm not sure how to remove.... Suggestions? Edited October 23, 2014 by jeffbebe Quote Share this post Link to post Share on other sites
qube 3570 Report post Posted October 23, 2014 can u please bring your dogs... they r so cute Quote Share this post Link to post Share on other sites
jeffbebe 1587 Report post Posted October 23, 2014 The boot's not so comfortable for the dogs in the 8, I'm afraid. Can chuck the little one on the front seat but the big one plays havoc with the leather!! Quote Share this post Link to post Share on other sites
jeffbebe 1587 Report post Posted October 27, 2014 Curing the clear coat by driving! Still got some cleaning and polishing to do but it's looking a lot better under there now! Also chipped the DMEs. Seat pants test says okay! It was very quick to do so I'm confident I can swap them between dyno runs to check if the seat of my pants is correct. 4 Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted October 27, 2014 Shiny engine - well done 1 Quote Share this post Link to post Share on other sites
Michael. 2313 Report post Posted October 27, 2014 No more nasty yellow!! Good job Jooles. 1 Quote Share this post Link to post Share on other sites
jeffbebe 1587 Report post Posted October 27, 2014 No more nasty yellow!! Good job Jooles. Actually, there are still a few little bits of nasty yellow which I probably won't be able to get rid of until I remove the intakes but it looks pretty good in the interim! 1 Quote Share this post Link to post Share on other sites
KwS 2450 Report post Posted October 27, 2014 I take it you polished them in place? What was to procedure to get it to look like that? Looks great, sure makes a big difference! Quote Share this post Link to post Share on other sites
jeffbebe 1587 Report post Posted October 27, 2014 Yeah, wanted them tidied up for Bimmerfest but knew I wouldn't have time to do the full intake removal, etc (which is still on my to do list). I just used some wire brushes and a bit of elbow grease and had a vacuum cleaner running to suck up all the dust. I started with wire brush drill bits but it didn't give a very even polish (there are still some swirls). I repainted the engine cover and sanded all the shite off the gasket... It looks good but as I haven't got a paint bay and it was a windy weekend there are a few blemishes in the paint but nothing catastrophic. Will put it up as a DIY at some point. Quote Share this post Link to post Share on other sites
jeffbebe 1587 Report post Posted November 2, 2014 New hose clamps and finally got round to replacing the LH bank ignition leads (they were working okay but I had to do the RHS so just did the full set). About as clean as I can get the bay for now until I remove intake manifolds and valve covers... Have been advised that I should do this sooner rather than later thanks to a common issue with loosening banjo bolts (which will ultimately wreck the cams if not treated): Plenty of good solutions though: http://www.bimmerforums.com/forum/showthread.php?2088697-M70-S70-owners-Have-you-checked-your-banjo-bolts 1 Quote Share this post Link to post Share on other sites
Arma 134 Report post Posted November 3, 2014 Engine bay is looking very flash now. 1 Quote Share this post Link to post Share on other sites
jeffbebe 1587 Report post Posted November 6, 2014 Something for the weekend... 2 Quote Share this post Link to post Share on other sites
BreakMyWindow 1999 Report post Posted November 6, 2014 Trip to the chiropractor after you're done installing those new bushes in to the column haha 2 Quote Share this post Link to post Share on other sites
jeffbebe 1587 Report post Posted November 6, 2014 Looks reasonably accessible.... Famous last words. 2 Quote Share this post Link to post Share on other sites
jeffbebe 1587 Report post Posted November 9, 2014 No problems fitting the universal joint and the top spindle was pretty easy too apart from the snap ring which was a bit of a b*tch to remove without the right tools but I got there in the end. Unfortunately, it still hasn't sorted out the problem; although the steering response is better the judders through the steering wheel over any pumps is really bad. The suspension all looks pretty new but the shocks are worn and I have replacements on their way, I'm hoping that sorts out the root cause but the play in the steering column is still an issue. There's is no play at the steering box end of the column which is encouraging and I've tightened the bolt on the swivel joint so there is now no play where the splined end of the lower column fits into it. But at the top of the lower column where it connects to the universal joint there is still a fair bit of play. I think the only thing I haven't eliminated yet is the bush (#9) in the diagram below which is, of course, a discontinued part. Awesome. Quote Share this post Link to post Share on other sites
BM WORLD 1297 Report post Posted November 10, 2014 part 7 is a common part that wears out , have replaced a few of these over the years in e28 e34 etc. when you remove them you can feel the play in the universal also the bottom balljoint on the track rod(centre drag link) get a lot of play in them . 1 Quote Share this post Link to post Share on other sites
jeffbebe 1587 Report post Posted November 10, 2014 Any way to check the universal joint without removing it? Doesn't seem to be any play in it but perhaps you can't tell til it comes out. The track rod looks pretty new so don't think it's that. Quote Share this post Link to post Share on other sites
BreakMyWindow 1999 Report post Posted November 10, 2014 Is # 7 on the interior side of the firewall? If so you could engage the steering lock (take key out) and wiggle the wheel while checking the UJ for play. Else some one watching # 7 in the engine bay while you wiggle the steering wheel. Quote Share this post Link to post Share on other sites
jeffbebe 1587 Report post Posted November 10, 2014 No #7 connects to the steering box. Have solved one issue; the collar nut on the upper steering column had been tightened way too tight (presumably in an effort to eradicate the play in the wheel) which was stopping the steering wheel adjustment from working correctly. There is now, no longer any play in the wheel at any setting. Woohoo. However, the shake in the wheel over bumps is still there and a new issue has arisen: a single nasty clunk when turning under heavy load at low speed. Wondering whether I could have over tightened the universal joint or if the strut bar has amplified a worn bush somewhere. Will have to get it up on a hoist for a proper steering test. Quote Share this post Link to post Share on other sites
BM WORLD 1297 Report post Posted November 10, 2014 get someone to wiggle the steering wheel back and forth while some holds the uni joint in there hand you will feel the knocking in it . has any one checked the steering box itself?? the track rod ball joint under the steering arm as well , put your hand around it etc . really need it on a hoist someone doing the steering wheel while someone is underneath with a good light and eye etc Quote Share this post Link to post Share on other sites
BreakMyWindow 1999 Report post Posted November 10, 2014 ^ This. Quote Share this post Link to post Share on other sites
jeffbebe 1587 Report post Posted November 10, 2014 Yep, going to try and do that this week. Quote Share this post Link to post Share on other sites
BM WORLD 1297 Report post Posted November 11, 2014 also the idler arm bush on the left side flog out and the track rod will rise up m causes the left wheel to shudder in some corners etc Quote Share this post Link to post Share on other sites
