Herbmiester 947 Report post Posted December 25, 2016 (edited) Fitted the style 350s to the E92, this time I had 255s on the back rather than 225s and the look very good. The Re003s have at least as much rear end grip as the 17 inch 255 s001s that were on there. Replaced the seat belt handover arms so now I don't have to reach all the way back to get the belt. The konis finally arrived in country so next up is suspension with M3 control/thrust arms up front and maybe some Eibach springs. Gave the E46 a thorough interior clean. It came up really well and I am so loathe to sell it now. Wife got a new job and may take the e46 as her company car but I might take the Ohlins road and track suspension out and sell it as she won't appreciate or use it. Edited December 25, 2016 by Herbmiester Quote Share this post Link to post Share on other sites
Haitoman 110 Report post Posted December 26, 2016 A new set of mats directly from Munich....yeehah... Quote Share this post Link to post Share on other sites
eliongater 718 Report post Posted December 26, 2016 Ended up climbing into the engine bay of the 525e, and yes there is enough space in there with the m20 1 Quote Share this post Link to post Share on other sites
Dogballs 123 Report post Posted December 29, 2016 (edited) I Finally got around to converting the 330i from an auto to 6 speed manual today.. - and it feels great! if anyone wants some help on the E46 conversion, happy to help. and FYI I used a M3 (S54) clutch and flywheel instead of the stupidly expensive 330 one with the built-in pilot bearing. I made an adaptor to use the 6speed type needle bearing to fit in the crank where the "normal" ball roller would go.. although this meant machining up an adaptor it was well worth it.. The cutch plate for the 6speed was also used - they are the same diameter and thickness as an M3 one so, fit in there just nicely, just the splines are different than an M3.. swapped the diff to the original spec 2.93 ratio removed the viscous fan and swapped out the aux fan etc to be as original manual config.. ----------------- this goes with the recent mods - changed out the std headlights for Bi-Xenons (huge improvement ) and upgraded to the Hi-Fi spec audio ( huge improvement too!) added TV function back, with a Tuner mod that allows digital Freeview reception and keeps the stock video module. Edited December 29, 2016 by Dogballs 7 Quote Share this post Link to post Share on other sites
adro 1127 Report post Posted December 29, 2016 E30 got some love yesterday. New 8mm High performance leads Bosch distributor cap + Rotor Bosch Injectors VDO fuel pump Rocker cover Gasket and plugs Wanted to do the TPS but have the wrong part :-( turns out the Auto one is different to the Manual. Has anyone spliced the auto to a manual? Picture of the auto one attached. The manual TPS is 3 pin (same as the ICV). CHeers, A. Quote Share this post Link to post Share on other sites
Gaz 1077 Report post Posted December 29, 2016 Got the vert out last night for the first time since the megameet, great night for a drive. Now to get the top working... 1 Quote Share this post Link to post Share on other sites
jonoe30 53 Report post Posted December 29, 2016 1 hour ago, Gaz said: Got the vert out last night for the first time since the megameet, great night for a drive. Now to get the top working... Do you have an EM or EH top? Just got my EM top working a few weeks ago... now I'm actually using my car with top down! Quote Share this post Link to post Share on other sites
Gaz 1077 Report post Posted December 29, 2016 36 minutes ago, jonoe30 said: Do you have an EM or EH top? Just got my EM top working a few weeks ago... now I'm actually using my car with top down! I've got an electric one. One motor has died and the roof needs alot of adjusting to get it to collapse properly. I'm tempted to pay someone to do it properly for me Quote Share this post Link to post Share on other sites
Allanw 1081 Report post Posted December 29, 2016 14 hours ago, Dogballs said: I Finally got around to converting the 330i from an auto to 6 speed manual today.. - and it feels great! I don't think many people who've only driven auto versions really appreciate the difference the manual box makes. Our E39 is only a 525i, but factory manual. I'd pick it again, over an auto 530i just for the directness and dynamics. It probably still doesn't make it faster than the auto 530i, but it sure feels "right" with a DIY trans, whether nana-ing around, or working it hard. Well done! 1 Quote Share this post Link to post Share on other sites
jonoe30 53 Report post Posted December 30, 2016 4 hours ago, Gaz said: I've got an electric one. One motor has died and the roof needs alot of adjusting to get it to collapse properly. I'm tempted to pay someone to do it properly for me Yeah I hear you there... I spent many hours reshimming and aligning the roof to get it to work properly (I also fitted new tension straps when I replaced the roof canvas which makes a big difference to folding). Thankfully I didn't have to replace the top motor so didn't have to re-sequence the timing with the microswitches which might be a headache in your case. I undertook it myself as I didn't think even a BMW mechanic would have had much practice adjusting them as they are so old and rare. The whole setup of the EM top seems to be a bit poorly engineered for BMW; I expect it will probably give me grief again in future so let me know if you do find an expert! Quote Share this post Link to post Share on other sites
huff3r 347 Report post Posted December 30, 2016 No more blue door! Grey primer instead, but it's a start! 2 weeks to the day til I can get my injector seals (cheaper to pick them up on my next visit to wellington than pay $6 freight for $5 of seals). After that I should have it on the road. Meanwhile the racecar got a 19mm irrigation elbow between the heater hoses, and filled with coolant, started and no leaks! Very hot inside with both front window regs stuffed, and no blower motor though. Especially with the huge hole in the firewall yet to be filled! And the compact.... well it needs a profile gasket. So I'll keep topping up the water until I have at least one more car road legal and can afford to pull it off the road and repair it. Or keep an eye out for a very cheap m43b16. 1 Quote Share this post Link to post Share on other sites
BreakMyWindow 1995 Report post Posted December 31, 2016 Road trip up to Parua Bay for New Years 4 Quote Share this post Link to post Share on other sites
qube 3570 Report post Posted January 4, 2017 Took the wagon up on a 1000km round trip to bay of islands and cape reinga. Friend took a few snaps thought id share them here 4 Quote Share this post Link to post Share on other sites
eliongater 718 Report post Posted January 4, 2017 37 minutes ago, qube said: Took the wagon up on a 1000km round trip to bay of islands and cape reinga. Friend took a few snaps thought id share them here Unparalleled 2 Quote Share this post Link to post Share on other sites
Olaf 3426 Report post Posted January 4, 2017 looking good, Kyu. I guess if you'd mailed this pack, it'd be a parallelogram. #; ) 1 Quote Share this post Link to post Share on other sites
qube 3570 Report post Posted January 4, 2017 Tried on some new wheels today 1 Quote Share this post Link to post Share on other sites
eliongater 718 Report post Posted January 4, 2017 9 hours ago, qube said: Tried on some new wheels today But how can we make jokes about parallels now? Quote Share this post Link to post Share on other sites
KwS 2450 Report post Posted January 4, 2017 Gosh it looks great on those MParallels. Quote Share this post Link to post Share on other sites
Matth5 471 Report post Posted January 4, 2017 20 hours ago, qube said: Took the wagon up on a 1000km round trip to bay of islands and cape reinga. Friend took a few snaps thought id share them here Were you at Cape Reinga on the 28th? Pretty sure I saw your car parked there... Man the drive up that road was fun. I had to take it easy on the way back though, used up too much petrol 1 Quote Share this post Link to post Share on other sites
qube 3570 Report post Posted January 4, 2017 (edited) Haha yep. I was with the big bunch of my asian friends taking a million photos by the lighthouse. It was indeed a fun drive. I got 12L/100km on my trip. You? Edited January 4, 2017 by qube 1 Quote Share this post Link to post Share on other sites
Matth5 471 Report post Posted January 4, 2017 (edited) Also have a vague memory of driving past it while it was parked on the roadside with someone taking photos, lol. Could have been someone else. Car shows 11.6l/100km but not sure how accurate that is, only time I made any effort to be economical was when heading back from Cape Reinga with low fuel. The stretch to Cape Reinga could have easily been 20l/100km... Anyone in the North Island who loves driving, needs to drive that road. It's a dream. Edited January 4, 2017 by Matth5 1 Quote Share this post Link to post Share on other sites
NZ BMW 368 Report post Posted January 5, 2017 (edited) I've just completed an almost 4000km road trip and managed about 11L/100km in the X5, pretty happy with that. Edited January 5, 2017 by NZ BMW Quote Share this post Link to post Share on other sites
huff3r 347 Report post Posted January 5, 2017 Polished front and rear chrome bumpers. This waiting for parts business sucks. Oh ordered paint too, so grey door will become blue door. Quote Share this post Link to post Share on other sites
Allanw 1081 Report post Posted January 6, 2017 Drove the E39, and realised how awkward the clutch has become... DAMN. Still, order a complete repaitr kit INCLUDING DMF. for NZ$808, shipped. Will get stung for GST. but still good!!! Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted January 12, 2017 towed a boat with the X5 9 Quote Share this post Link to post Share on other sites
