Allanw 1081 Report post Posted January 27, 2013 Did Whangarei to Kawakawa, to play trains. Used 7.2L/100kms on the way up. but managed to change the average to 7.9 coming back due to having a kidney stone and rushing a bit..... Plus we followed an E92 M3 with the plate GO4IT2 Quote Share this post Link to post Share on other sites
viettt 1 Report post Posted January 27, 2013 Today, i looked at my E30.. Then went inside and slept all day and watched vids of BMWs on youtube. 1 Quote Share this post Link to post Share on other sites
DarinD 8 Report post Posted January 27, 2013 I went on the hunt for a replacement lip for my e30. Called a wrecker to ask bout the volvo lip. Said it would cost $250. Yeah nah. Went to the pick a part near me and my luck was in. Even got change from a $20. Quote Share this post Link to post Share on other sites
Michael. 2313 Report post Posted January 27, 2013 Lol, $250... I got quoted $395 + gst at Strongs Honda for a used air box on some non vtec Honda a while back. Insanity... Quote Share this post Link to post Share on other sites
Greg111 13 Report post Posted January 28, 2013 Got the box out and the stupidly heavy dual mass flywheel and quite worn clutch and burnt pressure plate. Tomorrow the new light flywheel goes on along with clutch etc. Ordered all new shifter bushes for tomorrow too. Mmmm new bits. Cheers Mark for ya help, see you on wednesday. Quote Share this post Link to post Share on other sites
richard 384 Report post Posted January 28, 2013 Got the box out and the stupidly heavy dual mass flywheel and quite worn clutch and burnt pressure plate. Tomorrow the new light flywheel goes on along with clutch etc. Ordered all new shifter bushes for tomorrow too. Mmmm new bits. Cheers Mark for ya help, see you on wednesday. did you buy one , or have one made . I can't fine the post you started about your flywheel. Quote Share this post Link to post Share on other sites
E30-323ti 66 Report post Posted January 28, 2013 Finished welding up the new trans tunnel / firewall, got a coat of primer on it and ready for sealant. Engine Loom spread across the dinner table getting all un-necessary wires/plugs removed. Body Loom next. O'Joy Quote Share this post Link to post Share on other sites
Apex Effects 3 Report post Posted January 29, 2013 Finsihed cleaning inside and seats. yay it smells clean finally. got it back from auto electrician. it starts via the ignition switch now. but a few other bugs still present. fuel gague bounces. fan only goes on setting 4. indicators dont auto cancel. and horn stopped working hmmmm. slowly i getting closer to its first wof under my ownership Quote Share this post Link to post Share on other sites
Greg111 13 Report post Posted January 29, 2013 did you buy one , or have one made . I can't fine the post you started about your flywheel.Yep bought one. NZAD, forum sponser hooked us up. Half the weight of the dual mass. Quote Share this post Link to post Share on other sites
Michael. 2313 Report post Posted January 30, 2013 Looks like I am finally done programming the gearbox, smooth yet crisp shifts at low speeds with light throttle and quick, snappy shifts at higher speeds/rpm. Torque converter lock up control is also functional in 4-5th for cruising speeds. The engines stalling issue is now fixed too! Quote Share this post Link to post Share on other sites
Greg111 13 Report post Posted January 30, 2013 Sounds good Mike. I too have completed the flywheel conversion project. Negative results thus far though. No 5th and no reverse, maybe to do with new shifter bushes? Over it for now. Quote Share this post Link to post Share on other sites
Michael. 2313 Report post Posted January 30, 2013 (edited) Gahh, that's frustrating Greg. Is the selector set in the right position inside the box? Sounds like its not getting enough travel to select those gears...? On another note, I'll just leave this test telemetry clip here.... It's a few days old, performance is since improved. Youtube Clip Edited January 30, 2013 by Michael. Quote Share this post Link to post Share on other sites
charles28 142 Report post Posted January 30, 2013 (edited) Today Replaced Cam belt, Tensioner, Water pump (looked pretty rooted but was working fine), Front Cam and crank seals, viscous fan unit, drive belts, got a/c re gassed, replaced valve cover gasket, fuel filter, Temp sensor replaced. All 4 Brake discs, new brembo discs and CPLUS low dust Pads (Only need Street brakes) new brake fluid, new rear handbrake shoes. (Hand brake was useless). Old cambelt looked ok on the outside, but you could see cracking when you put it inside out. Edited January 30, 2013 by Charles32 Quote Share this post Link to post Share on other sites
Greg111 13 Report post Posted January 31, 2013 Issue sorted, was a misfitted shifter bush. My f**k up. Clearly saw it once on a hoist rather than on my back at home. My god it gets up and goes now! Quote Share this post Link to post Share on other sites
hybrid 1045 Report post Posted January 31, 2013 Welcome to the club .... a f**k ton better for the s50 and actually lets it rev with out that triquel feeling. Quote Share this post Link to post Share on other sites
euroriffic 630 Report post Posted January 31, 2013 Drove the 328i out to mosgiel to pickup pizza via 3mile hill, good times... Quote Share this post Link to post Share on other sites
Greg111 13 Report post Posted January 31, 2013 Welcome to the club .... a f**k ton better for the s50 and actually lets it rev with out that triquel feeling.Yep revs right out very freely. Needs to go back on hoist tomorrow though as the shifter is touching the driveshaft when in 2nd gear!With the new bushes the AC Schnitzer short shift has never felt so good. Quote Share this post Link to post Share on other sites
hybrid 1045 Report post Posted January 31, 2013 Nice one! Are you using the stock connecting rod. There are quite a few different types. I used some random bent looking one found at rays, had to modify the connector pins legnth on one of them ... was all good after that Quote Share this post Link to post Share on other sites
Greg111 13 Report post Posted January 31, 2013 Standard E36 shifter rod which is a factory bent rod. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted February 1, 2013 Standard E36 shifter rod which is a factory bent rod. Around the right way ?? Quote Share this post Link to post Share on other sites
Apex Effects 3 Report post Posted February 1, 2013 (edited) came home to this today saturday is going to be fun Edited February 1, 2013 by GASTKR Quote Share this post Link to post Share on other sites
APT 205 Report post Posted February 1, 2013 Lol, $250... I got quoted $395 + gst at Strongs Honda for a used air box on some non vtec Honda a while back. Insanity... It's funny because people will pay those prices all day. Quote Share this post Link to post Share on other sites
Greg111 13 Report post Posted February 1, 2013 Around the right way ??Haha always Glenn. Take a bit more notice than that.All the bushes were stuffed so new ones fiitted and now the shifter rod rubs on the driveshaft donut. Didn't get a chance to hoist it today. Will put up with it till monday. Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted February 1, 2013 (edited) pick up some new wheels for the drug dealers special car 98 750iL to replace the 20" MAC wheels. got these from some car wrecker that does mostly jap stuff . nicely pressented on the vehicle spent about a hour cleaning them up tonight. Edited February 1, 2013 by Brent HARTGE535i Quote Share this post Link to post Share on other sites
thorburn 123 Report post Posted February 1, 2013 What'd you use to clean them? other then plenty of elbow grease. They look great now. Good find Quote Share this post Link to post Share on other sites
