adro 1127 Report post Posted November 12, 2020 (edited) E39 out, E46 in. Transported it up from Arrowtown last week, picked it up this week. 211,000km NZ New 2 previous owners. Last owner had it for 12 years/173,000km Known faults were the remote keys don't work and it has a vacuum leak under the intake manifold as diagnosed by an indy shop in Arrowtown. A few bits of service history but nothing significant. Fresh off the trailer: After talking to experts (forum members) I've started what looks to be a bit of a maintenance mission. Started with the PCV. It was dated as 2002 so original and very brittle. The oil return line disintegrated in half as I pulled out the dipstick tube. I left the manifold on in a bid to have a driveable car to pick my daughter up from day care in and in my haste I forgot to plug in a few things. Idle was smooth but it was real jerky and had a big dip in the throttle when you initially got on the gas. Scanned it and it came up with cam position sensor fault. So out came the airbox and it turned out I had forgotten to plug in the cam position sensor, alternator and something else...whoops...anyway, seems to be running alot better now. Revs are constant and it's not throwing misfire or rich codes. Did the classic air filter, cabin filter and oil + filter too. It's pretty oily down here... Pretty dusty up here.. ewwwww New stuff I went with 5W-40 just because I had 1.5L left over from the 540 so figured I might as well use it up. New Roundel. I got a cheap one off trademe last time and it wore really fast so went all in on the dealership one this time. Changed the plates over too. DQZ346 lives on. Things to do: - coolant system overhaul - vanos valve cover gasket oil filter housing gasket - New Disa valve (rebuilt) - Tints & chrome delete around the windows - Motor mounts - Get the remote locking working - Trans oil and filter Things I would like to do: - Tyres - Suspension Eibach prokit, Bilstein B4 shocks front and Sachs m sport rears - Xenons + black corner lights - Bluetooth hands free - Bavsound upgraded speakers Feel free to add to this never ending list ? Edited June 25, 2021 by adro 13 Quote Share this post Link to post Share on other sites
qube 3570 Report post Posted November 12, 2020 daquezee lives on! Quote Share this post Link to post Share on other sites
NZ BMW 368 Report post Posted November 12, 2020 Interior looks to be in great condition for the age! Quote Share this post Link to post Share on other sites
hqstu 780 Report post Posted November 12, 2020 Recent history suggests that is a very very small list... 1 1 Quote Share this post Link to post Share on other sites
adro 1127 Report post Posted November 12, 2020 2 minutes ago, hqstu said: Recent history suggests that is a very very small list... You know it ? Quote Share this post Link to post Share on other sites
qube 3570 Report post Posted November 12, 2020 msport conversion and different wheels? xenon headlights? black grills Quote Share this post Link to post Share on other sites
Olaf 3428 Report post Posted November 12, 2020 HPR5 is the right stuff for M54 IME. How's the oil filter housing gasket and valve cover gasket/seals? they're the prime culprits for oil leaks, followed by VANOS oil line, Power Steering Reservoir and hose, and sump gasket. It's a grand looking car, mate. Quote Share this post Link to post Share on other sites
Eagle 1788 Report post Posted November 12, 2020 Added things to do: Clean ICV, power steering and brake fluid change, camshaft sensor o-rings, fuel filter and belt pulleys Things ill eventually do: Replace most of the wearable parts on the car and fix any cosmetic issues 1 Quote Share this post Link to post Share on other sites
adro 1127 Report post Posted November 12, 2020 1 hour ago, Eagle said: Added things to do: Clean ICV, power steering and brake fluid change, camshaft sensor o-rings, fuel filter and belt pulleys Things ill eventually do: Replace most of the wearable parts on the car and fix any cosmetic issues Oh yeah I cleaned the ICV and throttle body when I did the PCV. They actually weren’t too bad ✅ Tried to do the fuel filter but obviously original as it had those weird special hose clamps, I’m guessing vice grips? so bailed out on that. The vac line down there could do with replacing. I broke the one that goes into that F connector in the upper elbow straight away. Quote Share this post Link to post Share on other sites
Olaf 3428 Report post Posted November 12, 2020 @Eagle - good tip, I never thought of doing CPS O-rings. @adro I bought a length of high pressure FI Fuel Hose, pre-cut and fitted short connector lengths, and used new stainless jubilee clips first time I replaced my e46 fuel filter. Managed to get the inlet and return hoses mixed up, won the no-start prize. Trap for new players. Quote Share this post Link to post Share on other sites
displayname 43 Report post Posted November 13, 2020 If this was the one on TM a few weeks back, I’m glad it went to a good home! 1 Quote Share this post Link to post Share on other sites
zero 1162 Report post Posted November 13, 2020 (edited) Yea, fuel filter, and new vacuum hoses and hose clamps for it. Vanos seals from besien systems or similar will recover some power and fuel economy. e46 Electric fan mod. msport front bumper. Black grills and shadowline. Just my opinion Also check and replace the little rubber bungs on the back of the manifold as they will be cracked or missing at this age and will create a vacuum leak. Edited November 13, 2020 by zero 1 Quote Share this post Link to post Share on other sites
lemusa 86 Report post Posted November 14, 2020 Bit of a change! Looks clean and no doubt in a couple of years it will be one of the cleanest in NZ 1 Quote Share this post Link to post Share on other sites
m325i 732 Report post Posted November 16, 2020 (edited) White LCI wagon is cool. The LCI is enough of a change it looks like a model half step. The aftermarket is so strong on e46 you can easily make this as modern, look and perform as well as cars 4x the price. Edited November 16, 2020 by m325i 1 Quote Share this post Link to post Share on other sites
adro 1127 Report post Posted March 14, 2021 (edited) 212 xxx km. I ran into a bit of a problem when I dropped the disa pin into the intake and it found it's way to cylinder 6. No compression in cylinder 6, Jon at auto38 advised that an engine swap would be his preferred option. Plug in cyl 6 off to Auto38 Old piston cyl 6 Head off old engine. Bought an engine before Christmas, organized a mate to put it in. He didn't get to it till the new year where he found 8.5L of milkshake in the sump instead of 6.5L of oil. So the vendor kindly refunded and i got one off Nick Weitz. Nick compression tested it before sending and it was algood. Came out of a running car so confidence was high. This engine was the older coil style so the manifold and valve cover from my original engine was swapped over (since CCV had just recently been repalced meant it didn't need to be pulled apart), along with the loom and headers. New parts that went in while engine was out Engine mounts Sump gasket Plastic coolant hoses under intake manifold x 2 upper and lower radiator hoses water pump (graf metal impeller) Thermostat Valve cover Gasket Oil filter housing gasket Vanos seals Spark Plugs Electric Fan from @zero upper intake boot oil filter Penrite 5W-40 rebuilt Disa Valve Car was running rough and was throwing lean codes for bank 1 and bank 2. Turns out the 02 sensors weren't plugged into their corresponding bank. Car is now running very smooth and I'm waiting for the vanos seals to break in. I replaced the seals in my old vanos unit to make it quicker to install. Also my solenoids were cosmetically in much nicer condition. New engine looks really clean. No idea of the mileage as it had been swapped into the car it came out of. Up at mt Vic watching the hill climb today. The list of things still to do: Gearbox filter and oil - have parts. Fuel filter - have parts and have replaced the vac line. Xenon - have parts but need to code LCM and there are still some wiring to do. Bilstein touring shocks and Eibach prokit springs. (these were in the post when the engine went bang) Remote key still isn't working despite changing the FTZ module Tints soundsystem/handsfree bluetooth. So been a bit of a mission, I was completely stumped by the lean codes and was pretty stressed out that the engine was toast. I'm really enjoying having it back on the road. Edited March 14, 2021 by adro photos 13 Quote Share this post Link to post Share on other sites
hunter 413 Report post Posted March 14, 2021 (edited) What a saga. Glad to hear it’s back in the road mate. Edited March 14, 2021 by hunter 1 Quote Share this post Link to post Share on other sites
balancerider 850 Report post Posted March 14, 2021 Looking good and happy to see it's back on the road. Can't have been too many white E46 tourings sold NZ new... 1 Quote Share this post Link to post Share on other sites
Sammo 2616 Report post Posted March 14, 2021 Oh wow, a lot of 'bonding' with the new wagon already 😐 Must feel great to have it sorted! Quote Share this post Link to post Share on other sites
adro 1127 Report post Posted March 14, 2021 3 minutes ago, Sammo said: Oh wow, a lot of 'bonding' with the new wagon already 😐 Must feel great to have it sorted! yeah, a bit of an introduction to the M54 for sure 🤪 1 Quote Share this post Link to post Share on other sites
Sammo 2616 Report post Posted March 14, 2021 12 minutes ago, adro said: yeah, a bit of an introduction to the M54 for sure 🤪 One of BMWs 'most reliable' motors haha Quote Share this post Link to post Share on other sites
adro 1127 Report post Posted March 17, 2021 (edited) Suspension upgrade Before the engine went bang I had just pulled the trigger on some Bilstein Touring shocks and Eibach Prokit springs from Demon Tweaks. I already had rear sachs shocks I purchased from @Eagle which were for the motorsport setup so went with the B4's which from the looks of realOEM are the factory motorsport package shocks. New bits Lemforder front shock mounts Bump stops and dust covers Bilstein B4 front shocks #BLS22-139948, BLS22-139931 Eibach Prokit springs #EIBE2067-140 Meyle HD rear shock mounts Sachs rear shocks #556 882 I got a shop to do the spring compressor part but i DIY'd the rest to try save on labour (the rear is pretty labour intensive) the rear shocks were completely dead. rear spring height comparison bit of trim removal Found 1 random Monroe up the front. New fronts After a few KM's they are settling in. So far I'm really impressed with the quality of the ride. Comfort vs handling I think it's a great combo for the daily driver. Edited March 17, 2021 by adro 11 Quote Share this post Link to post Share on other sites
Eagle 1788 Report post Posted March 20, 2021 Just ditched some flogged out Monroes on the Ti for B4's also. Always good $ spent. Quote Share this post Link to post Share on other sites
adro 1127 Report post Posted March 20, 2021 4 hours ago, Eagle said: Just ditched some flogged out Monroes on the Ti for B4's also. Always good $ spent. Nice. Yeah, great price too! Quote Share this post Link to post Share on other sites
adro 1127 Report post Posted March 27, 2021 (edited) Facelift. almost 1000km since the engine went in. Had a coolant light on last week. Not sure if it did a big burp or if it's leaking but either way i topped it up and am keeping an eye on it. Xenons sourced from Weitz and coded in by @promo. Black corner lights also installed with chrome bulbs. Black grilles are also in and a few stone chips fixed up. I've just noticed looking at these photos that there is a little bulb on in the passenger side light. This is consistent with a bulb out light on the dash on the drivers side. Anyone know what this is? I haven't wired up for bi-xenon functionality yet or self leveling...they will come down the line. Suspension has also settled. Dropped the car into auto38 this week for a gearbox flush. ZF filter and 12L of ZF oil. 212K trans oil was very black apparently. Edited March 28, 2021 by adro 4 1 Quote Share this post Link to post Share on other sites
hunter 413 Report post Posted March 27, 2021 The little bulb will be the tiny little guy used for park lights. This happened to me on my e46 and took a bit of looking to see it on the back of the light housing. It’s up the top towards the inner edge of the light housing from memory. Quote Share this post Link to post Share on other sites
