325_driver 422 Report post Posted June 5, 2021 Got the rear sub frame bolted up, and while i was at it, took all control arms off the donor hubs I got with the 325 axels in them. Came across this haha ... video-1622884653.mp4 Oddly enough none of the suspension components from it looked bent, but i guess a wheel alignment is going to tell when I get this wrapped up I've got plenty of spares for that side, hoping i'm not going to have to replace anything, I really did not enjoy bolting up that hub, got alot quicker at it second time round though i guess. 1 Quote Share this post Link to post Share on other sites
Olaf 3426 Report post Posted June 5, 2021 13 hours ago, E30 325i Rag-Top said: I guess you don’t mean of the house rennos? 🥺 Dropping the rear end on an E30 is pretty simple, most people have probably seen / done it.. Came out pretty easily and stripped down, the usual one stuck bolt was absent today which was nice. Now to push out the Delrin bushes and swap into the new beam.! Awesome. What's prompted the 5-stud conversion on the racecar, more brakes? I should note that's a decent collection of Resene cans there too. Waterborne enamels FTW! Quote Share this post Link to post Share on other sites
E30 325i Rag-Top 3043 Report post Posted June 5, 2021 6 hours ago, Olaf said: Awesome. What's prompted the 5-stud conversion on the racecar, more brakes? I should note that's a decent collection of Resene cans there too. Waterborne enamels FTW! Mainly because the E30 M3 was five stud, so looking to replicate that, plus the increase in rear track to fill the wider M3 arches without spacers. The extra brakes is a bonus, plus the ability to run 5 x 120 wheel styles that are used on the M3 - of which I have a few sets already! Quote Share this post Link to post Share on other sites
Driftit 2243 Report post Posted June 7, 2021 Changed the glow plugs on the E34 today. Pretty quick job. Though the gaskets I had were not correct so I used liquid gasket as a temporary solution. Fun times scrapping that off. Next is the leaking injector. Which is number 4. The hard one with the sensor. Diesels are fun. 1 1 Quote Share this post Link to post Share on other sites
euroriffic 630 Report post Posted June 7, 2021 Made more room for activities 6 Quote Share this post Link to post Share on other sites
M3AN 4192 Report post Posted June 7, 2021 There are some lovely wheels there @euroriffic! Quote Share this post Link to post Share on other sites
euroriffic 630 Report post Posted June 8, 2021 8 hours ago, M3AN said: There are some lovely wheels there @euroriffic! Is a struggle to decide what to run, so good to have options. Buying tyres is killing me though! Be cheaper buying a tyre machine I think 9 Quote Share this post Link to post Share on other sites
balancerider 845 Report post Posted June 8, 2021 @euroriffic Dakar is such a good colour on the e36 5 Quote Share this post Link to post Share on other sites
325_driver 422 Report post Posted June 10, 2021 The 320 is now something worth driving. A 325i Filled transmission at temperature Calibrated DSC pump no more DSC and abs lights Cleared check engine Replaced bank 1 post cat o2 sensor Nearly everything bolted back up, ran it to operation temperature no leaks... yet. just got to the odd braces front end, near enough camber/tow on rear end She's quiet and revs cleanly Quote Share this post Link to post Share on other sites
gjm 3300 Report post Posted June 14, 2021 Went to replace the front LCAs on the venerable E46 318i. Nut on top of the outer balljoint? No problem. Two bolts holding hte lollipop in place? Easy as. Nut on top of the inner balljoint...? Where the actual %Y$@ is it? Can't see it, can't feel it. Finally locate and find I can fit a recessed ring spanner on to it. 1/24th of a turn and... Can't get the spanner out as it is hard up against the underside of the something. Find an open-ended spanner - fiddle around until it gets on to the nut, get perhaps 1/24th of a turn on it before the spanner fouls on something - the aircon pump, the sway bar, sway bar bushing... Take the spanner off, turn it over, and... Nope won't go back on. Get another spanner with a slightly different head angle and yes! that'll do it. Move the nut another 1/24th of a turn, that is. Back to the first spanner, wrong way round, take it out again, turn it over, it fits, get another 1/24th of a turn, back to the second spanner, it's started raining... Stuff that. Lying on my back in a puddle isn't my idea of fun. It'll wait. For now. 1 Quote Share this post Link to post Share on other sites
gjm 3300 Report post Posted June 19, 2021 On 6/14/2021 at 8:20 PM, gjm said: Went to replace the front LCAs on the venerable E46 318i. etc... It's being a bit of a monkey, is the E46 318i. Arms and rear mounts replaced, but now there's a proper 'knock' on bumpy roads at slow speed (our driveway), and it's possible to turn the steering wheel too far - it feels as though the turning is fine and then there is a 'give' in the steering and it turns a bit further. Turning back, it feels as though the steering has to go over a hump (terrible description but if you've experienced this you'll know what I mean) before returning to a normal position. It also feels a little odd when turning right, especially at any speed. Alignment definitely needs sorting. To be expected. If it stops raining I'll get back under and see if I can identify what's wrong. In the meantime, the brake warning light didn't go away when the sensors were replaced. Good pads, discs, fluid and sensors. Took a 'read and reset' to sort it - I've since been advised that turning the ignition to position 3 (just before engaging the starter) and leaving it there for 2 minutes can clear faults like this, too. Having cleared it, it hasn't returned. Quote Share this post Link to post Share on other sites
Harper 615 Report post Posted June 29, 2021 (edited) Fitted, nothing better than fresh M-texture. In desperate need of some trim to replace my silver junk now though... Ordered an exciting package out of Germany over the weekend which should be here in 3 weeks, pilot sport 4S's arriving this week or early next, this car might finally start to actually take shape soon. Edited June 29, 2021 by Harper 3 Quote Share this post Link to post Share on other sites
freaknout 48 Report post Posted June 29, 2021 Interesting day today. Went to have a covid test where they serve you in your car. A big gust whipped through, picked up their tent and smashed it into my bonnet. At first we spotted just a few scratches, which may have buffed out, but then we spotted the impact dent smack bang in the middle. Ooops! Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted June 29, 2021 I bet that freaked you out 😇 1 Quote Share this post Link to post Share on other sites
freaknout 48 Report post Posted June 29, 2021 Ha! 😂 Quote Share this post Link to post Share on other sites
Olaf 3426 Report post Posted June 29, 2021 (edited) On 6/19/2021 at 6:16 PM, gjm said: It's being a bit of a monkey, is the E46 318i. Arms and rear mounts replaced, but now there's a proper 'knock' on bumpy roads at slow speed (our driveway), and it's possible to turn the steering wheel too far - it feels as though the turning is fine and then there is a 'give' in the steering and it turns a bit further. Turning back, it feels as though the steering has to go over a hump (terrible description but if you've experienced this you'll know what I mean) before returning to a normal position. It also feels a little odd when turning right, especially at any speed. Alignment definitely needs sorting. To be expected. If it stops raining I'll get back under and see if I can identify what's wrong. In the meantime, the brake warning light didn't go away when the sensors were replaced. Good pads, discs, fluid and sensors. Took a 'read and reset' to sort it - I've since been advised that turning the ignition to position 3 (just before engaging the starter) and leaving it there for 2 minutes can clear faults like this, too. Having cleared it, it hasn't returned. e46 and e60 CLONK out of driveways/over bumps is frequently the centre nut hasn't had enough ugga-duggas on it - if you've been changing shocks. Are your endlinks and balljoints etc correctly tightened? Worth checking. Is that castor/ackerman at work? and yes, you can reset the brake pad warning light with just the ignition key and the door, in the right sequence. Sorry can't remember or find it right now. Youtuber Bullshitkorner has a short video on how-to. HTH Edited June 29, 2021 by Olaf Quote Share this post Link to post Share on other sites
Jacko 2355 Report post Posted June 30, 2021 Dog helped me wash the dust off it.... 1 Quote Share this post Link to post Share on other sites
balancerider 845 Report post Posted July 2, 2021 Took my lead from @Jacko - dog was no help in my case though 1 Quote Share this post Link to post Share on other sites
aja540i 1925 Report post Posted July 2, 2021 Finished putting the M5 back together!! New thermostat, radiator hoses, radiator drain bungs, new coolant, 1 new intake boot and clamp, new sway bar bushes and end links, headlights polished and clear coated, freshly painted front bumper fitted. Also took the opportunity to vacuum 14 years worth of dead bugs out of the oil cooler and radiator!! Quick test drive tonight shows oil gets up to temp a lot faster so thermostat was past its best. 4 Quote Share this post Link to post Share on other sites
M3AN 4192 Report post Posted July 2, 2021 Should be able to beat an M440 now... 3 Quote Share this post Link to post Share on other sites
Sammo 2616 Report post Posted July 3, 2021 Gave the interior a good detail today - its never dirty, but went over the seats and wheel with CarPro 'Inside' (great product) and a shoe brush and came up fantastic. 5 Quote Share this post Link to post Share on other sites
Harper 615 Report post Posted July 3, 2021 (edited) Wheels on. Car is filthy and camera lens is broken on my phone so the photos are a bit shite but you get the idea. Square set of brand new Style 260M's in reflex silver. Michelin PS4S's 255/40/18 all round. Photos don't quite do it justice, looks mega. Need to dial the alignment in a little more, still getting a slight rub under compression on the front right so probably going to raise it + a little more camber. Been a really rough few weeks so this has definitely put a smile on my face Edited July 3, 2021 by Harper 8 Quote Share this post Link to post Share on other sites
str8_6 278 Report post Posted July 3, 2021 6 minutes ago, Harper said: Square set of brand new Style 260M's in reflex silver. Michelin PS4S's 255/40/18 all round. Photos don't quite do it justice, looks mega. Need to dial the alignment in a little more, still getting a slide rub under compression on the front right so probably going to raise it + a little more camber. Been a really rough few weeks so this has definitely put a smile on my face These look epic! 2 Quote Share this post Link to post Share on other sites
leichtbau 525 Report post Posted July 3, 2021 (edited) 19 minutes ago, str8_6 said: These look epic! Yep, that's the money shot. Shades of M3 GTR wheels. Edit: @Harper does this mean there's a set of x8.5" fronts floating about? Edited July 3, 2021 by leichtbau 1 Quote Share this post Link to post Share on other sites
Sammo 2616 Report post Posted July 3, 2021 @Harper Certainly looks snug in those arches! 👌 1 Quote Share this post Link to post Share on other sites
