B.M.W Ltd 951 Report post Posted May 6, 2015 They don't work. Put your left hand on the ABS unit.... stick your right hand index finger up your arse and recheck. If that doesn't work first time put your right hand index finger down your throat. 6 Quote Share this post Link to post Share on other sites
BMTHUG 1112 Report post Posted May 6, 2015 They don't work. Put your left hand on the ABS unit.... stick your right hand index finger up your arse and recheck. If that doesn't work first time put your right hand index finger down your throat. bahahahahahahahahahaha this is gold! Quote Share this post Link to post Share on other sites
westy 614 Report post Posted May 6, 2015 No one's mentioned the dizzy cap yet? Quote Share this post Link to post Share on other sites
B.M.W Ltd 951 Report post Posted May 6, 2015 That's a different diagnostic issue Tony... people need to take their hand off their cock before they use the banana skins Quote Share this post Link to post Share on other sites
polley 916 Report post Posted May 6, 2015 They don't work. Put your left hand on the ABS unit.... stick your right hand index finger up your arse and recheck. If that doesn't work first time put your right hand index finger down your throat. Find nearest river, stick head under 3 times. Remove twice. 1 Quote Share this post Link to post Share on other sites
eliongater 718 Report post Posted May 8, 2015 Sorry if this is the wrong topic. What can people tell me about e30 b pillar rust? I'm looking at buying an e30 and it failed a WOF because of this rust. Any ideas if it would be fixable or terminal? Thanks Quote Share this post Link to post Share on other sites
gjm 3300 Report post Posted May 15, 2015 E30 PFL vs FL front lip What's the difference? Given they are specifically referred to, I guess either there is no interchangeability, or perhaps one model didn't have a front lip at all? Quote Share this post Link to post Share on other sites
qube 3570 Report post Posted May 15, 2015 (edited) e30 pfl http://autosfans.com/wp-content/uploads/2010/09/1983-BMW-E30.jpg e30 fl http://e30.bmwdiy.info/lip-spoiler/lip-spoiler-06.jpg comparison side by side pic http://images.bimmers.no/files/dthojuqte1juriqy9jqh.jpg Edited May 15, 2015 by QUBE Quote Share this post Link to post Share on other sites
gjm 3300 Report post Posted May 15, 2015 e30 pfl http://autosfans.com/wp-content/uploads/2010/09/1983-BMW-E30.jpg e30 fl http://e30.bmwdiy.info/lip-spoiler/lip-spoiler-06.jpg comparison side by side pic http://images.bimmers.no/files/dthojuqte1juriqy9jqh.jpg Any idea if they can swap? I've never had to look. Quote Share this post Link to post Share on other sites
qube 3570 Report post Posted May 15, 2015 dont think so but im sure anything can be made to fit. im pretty sure the lip i linked for the fl is called an "is" lip. e30 fans will clarify i guess 1 Quote Share this post Link to post Share on other sites
VADER 8 Report post Posted May 19, 2015 Fasteners & whatnot, i.e. inner guards etc, where's the best place to go for stuff like this please team (E60 5 Series)? I had a look at Repco, RAJ but it seemed a specialist place/eBay/overseas is a good option. TIA Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted May 19, 2015 BM WORLD in papakura 021433600 [email protected] http://bimmersport.co.nz/topic/52801-e60-530i-2006-parts-car-just-in-bmworld/ Quote Share this post Link to post Share on other sites
zero 1162 Report post Posted May 23, 2015 Where is the engine code on the n42 engines? I have found a whole heap of numbers cast onto the block, but none appear to be the engine code? I've been on google for the last hour but no joy so far....... Quote Share this post Link to post Share on other sites
allan 295 Report post Posted May 23, 2015 http://www.bimmerfest.com/forums/showthread.php?t=210016 http://www.bimmerfest.com/forums/showthread.php?t=416484 http://www.ehow.com/how_6820982_identify-bmw-engine.html 1 Quote Share this post Link to post Share on other sites
B.M.W Ltd 951 Report post Posted May 23, 2015 N42 is the engine code. You only need the last seven digits of the VIN number to order the correct parts for that engine in your car. You don't need the engine serial number. 1 Quote Share this post Link to post Share on other sites
zero 1162 Report post Posted May 23, 2015 Thanks, but I only have the engine and no info on the car it came from. Quote Share this post Link to post Share on other sites
B.M.W Ltd 951 Report post Posted May 24, 2015 What other info or warranties did you get with this engine ? I hope it's done less than 30k 2 Quote Share this post Link to post Share on other sites
zero 1162 Report post Posted May 24, 2015 What other info or warranties did you get with this engine ? I hope it's done less than 30k Its done 155kms, but I'm going to rebuild it anyway so I'm not overly worried about mileage. Plus, it was only $150. Then I will swap it over with the n46 motor in my car, and rebuild that engine and sell to recoup costs. Or, I might just swap the heads over after I have reconditioned the one I've bought. I'm trying to fix my valve stem seal problem in the most economic way possible (without cutting corners of course). Quote Share this post Link to post Share on other sites
Forrest 35 Report post Posted May 26, 2015 Do adjustable rear camber arms (non-oem) to suit a E36 require a cert? Quote Share this post Link to post Share on other sites
huff3r 347 Report post Posted May 27, 2015 Do adjustable rear camber arms (non-oem) to suit a E36 require a cert? As far as I can see from here http://www.lvvta.org.nz/documents/suplementary_information/LVVTA_LVV_Cert_Threshold.pdf They would require a cert. if it's not specifically allowed by the above publication then it automatically requires a cert. Quote Share this post Link to post Share on other sites
gjm 3300 Report post Posted May 27, 2015 Do adjustable rear camber arms (non-oem) to suit a E36 require a cert? As far as I can see from here http://www.lvvta.org.nz/documents/suplementary_information/LVVTA_LVV_Cert_Threshold.pdf They would require a cert. if it's not specifically allowed by the above publication then it automatically requires a cert. A rule of thumb seems to be that if you replace something non-adjustable with something adjustable, then you need a cert. Quote Share this post Link to post Share on other sites
huff3r 347 Report post Posted May 27, 2015 It's an interesting list... apparently my (airbag) steering wheel swap requires a cert but I can install motorcycle handlebars from a "reputable brand" without a cert as long as it doesn't interfere with my (illegal) airbag. Also - general question, since the WOF guys never lift my bonnet how could they tell if I have adjustable camber plates? They should be lifting your bonnet, to check the firewall for rust, and to check the integrity of the suspension mounts. So a proper wof would spot them, someone cutting corners most likely wouldn't. Quote Share this post Link to post Share on other sites
Allanw 1081 Report post Posted May 27, 2015 Interesting, my last WoF was sound but the one before that was with AA and I'm convinced they didn't lift the 'hood'. Maybe my recollection is poor. Sounds like the AA - know about as much about cars as my Mum. 2 Quote Share this post Link to post Share on other sites
benpaul12 62 Report post Posted June 1, 2015 My front left wheel/area on turning a slower speeds is making an intermittent rubbing/rumbling noise. Nothing is hanging off(!), any ideas? Quote Share this post Link to post Share on other sites
zero 1162 Report post Posted June 3, 2015 (edited) How do I disassemble the hydraulic lifters on the n42/n46 engine? I'm rebuilding them as part of my engine build, but cant figure out how to open them. I've seen diy's for the lifters in the 6 cylinder motors but not for mine. Edited to add; should I keep the lifters in order for when they are reinstalled? I have kept them in order anyway, but wondered if this is necessary? Edited June 3, 2015 by zero Quote Share this post Link to post Share on other sites
